Yikes, glad I don't have a Pegasus!
Old December 8th 05, 11:29 AM posted to rec.aviation.soaring
Default Yikes, glad I don't have a Pegasus!
Looks like a good opertunity to me. The value goes down so its less
expensive to purchase. You buy a 1500 hour ship and its still a
lifetime of use for most pilots. As long as the insurance is not
effected by the AD it shouldn't matter too much.
On Wed, 07 Dec 2005 18:44:37 -0800, Greg Arnold
Do I correctly understand the AD below to mean that any Pegasus in the
US with 3000 hours cannot be flown after January 6, 2006? Certainly
would have an effect of the market value of this glider, even one with
significantly less than 3000 hours. I notice that someone put one on
the market today on the SSA site at $15,000 (it has 3300 hours), which
seems somewhat high for glider that can only be flown for the next month.
http://www.airweb.faa.gov/Regulatory...E?OpenDocument
Old December 8th 05, 12:08 PM posted to rec.aviation.soaring
I spoke with Greg Davison at the FAA in Oklahoma City the other day and
he gave me the scoop on the AD and its implications.
Yes, technically there is a 3000 hour life limit on all Pegasus gliders
sold in the US. This is not an FAA rule- it came from Centrair. The
glider is certified to 12,000 hours in Europe, but the US STC was only
for 3000 hours. As a result, the AD had to be issued.
Don't panic, though. Greg has met with Centrair and they have agreed to
issue a 3000 hr. inspection protocol like other gliders require. Once
this inspection reqirement is issued (probably in the Spring of 2006),
the FAA will put out another AD that will supersede this one.
Greg realized that the 3000 hr. limit is not realistic, and Centrair
agrees. It was just a screwup when the glider was originally certified
in the early 1980's. I have been assured that the problem WILL be
fixed. It is just that the FAA had to comply with the original
manufacturer's intent and the resulting limit.
Greg was extremely helpful in explaining the situation. He has promised
to keep poking at Centrair until they come up with the 3000 hr.
inspection regimen. Greg suggested I call him in February 2006 to check
on Centrair's progress.
My Pegasus has around 2400 hrs. so I was more than just a little
concerned. Especially because I usually put 200+ hrs per year on my
glider. I am encouraged by his response, and I am back to getting a
decent night's sleep.
An email to Centrair urging them to work on the inspection protocol
might be a good idea. )
Mark Mocho
Old December 8th 05, 07:10 PM posted to rec.aviation.soaring
300 000 hours ( yes 3 hundred k ) is a 'realistic' lifespan for a
plastic glider. Read the recent OSTIV proceedings if you dont believe
me.
Ian
Old December 8th 05, 07:54 PM posted to rec.aviation.soaring
me.
Better start that flight instruction fund for the great grand kids.
Old December 8th 05, 08:50 PM posted to rec.aviation.soaring
That's ~34 years of flight. Under day/VFR conditions, it would take well
over a century to accumulate if you flew every day. That many years of
exposing a composite structure to sunlight and ozone would worry me a bit,
OSTIV not withstanding. Add turbulence and hard knocks (not to mention
parts availability) and I suspect the lifespan would be significantly less
than 300K hours.
I guess we'll just have to wait and see how it all turns out.
Ray Warshaw (tongue firmly in cheek)
1LK
me.
Ian
Old December 9th 05, 01:15 PM posted to rec.aviation.soaring
Among many well-reasoned points, Mark wrote:
...It is just that the FAA had to comply with the original
manufacturer's intent and the resulting limit...
This isn't true at all. FAA doesn't have to do anything more specific
than "keeping the airways safe." They do whatever they feel like
doing.
-Pat
Old December 12th 05, 09:31 PM posted to rec.aviation.soaring
SNIP
OK, this thread probably has limited interest for most glider pilots.
But I've still been waiting for several days for someone to jump in
with, "Hey, this FAA guy sounds like a breath of fresh air. Yeah, the
FAA feels compelled (surprise) to enforce the manufacturer's life limit
but they seem to have a very practical attitude about it. And they're
working to get it fixed. Things haven't always been so. Thanks, FAA."
Sure, it would be nice if the Feds ignored the useless rules and
enforced only the ones that really make sense. But then how do they
look in front of Congress if some yo-yo goes into cloud trying to climb
through a wave window, pulls the wings off a Pegasus, and drops the
debris into a crowded schoolyard? And he shouldn't even have been
flying the aircraft because the manufacturer said it was dangerous!!!!!
We don't always have it so good. Let's give the FAA a little slack on
this one. Sounds like they know what needs to be done even if it will
take longer than anyone likes.
Or maybe it's not the FAA, it's just some relatively clear-headed guys
who work there and know us. Even more reason to say "thank you."
Chip Bearden
Old December 13th 05, 05:17 PM posted to rec.aviation.soaring
SNIP
Chip Bearden
I second what Chip wrote. While I'm no fan of bloated, CYA-driven
bureaucracies I get to pay for whether I want to or not, and while I
find the humor in "We're from the government; we're here to help,"
disturbingly and frequently too close to the mark, I found Greg
Davison's attitude refreshingly common-sense, and arguably as pro-active
as is likely to be found in a Federal bureaucracy.
Though not a Pegasus owner, I had already been thinking prior to Chip's
post - and belatedly now say - "Thank you, Greg!" for picking up and
running with this particular ball.
Bob Whelan
FS: Pegasus [email protected] Soaring 1 October 4th 05 10:05 PM
US Centrair Pegasus group? jphoenix Soaring 2 July 15th 05 06:01 PM
Hinge pins for Pegasus AD tooromeo Soaring 0 May 17th 05 02:56 PM
Has anyone gotten a response from Centrair on Pegasus parts? tooromeo Soaring 23 May 11th 05 05:29 PM
Pegasus comparisons sought Ted Wagner Soaring 9 January 24th 04 04:36 AM
