![]() "Juanjo (sevilla)" wrote in message ... Binky escribió: A friend and I are having difficulty connecting to each other in multiplayer in Falcon 4. We both have the same build of the software (unpatched). He is connected to the internet directly, I am trying to connect using a gateway connection and a direct connection with no luck. Both of us are running XP, additional firewalls to XP's own are turned off, the game has been 'unblocked' by XP's firewall, IP addresses are correct etc. Any pointers appreciated. Binky. Not really sure why we can't see each other. LAN multiplayer works fine. If you are using Falcon 4.0 from Microprose you should use the command line option "-IP ###.###.###.###" (replace the hashes with the apropiate number) in the PC connecting through a gateway. The PC using the gateway has a local IP (a private one) and the gateway has a public (internet) IP. Thus, the Falcon running in the PC behind the gateway is sending it's IP (the private one) and the other PC can't find it (because it's not an internet IP). The command line option explained tells the Falcon software to use that IP instead of the local one, solving the connection problem. Sorry, I should have been more accurate - it's Falcon 4: Allied Force by Lead Pursuit |
![]() "Binky" wrote in message ... Sorry, I should have been more accurate - it's Falcon 4: Allied Force by Lead Pursuit You need to upgrade. AFAIK the release version had buggy multiplayer, and it was improved dramaticaly for 1.03. TVirta |
![]() Sorry, I should have been more accurate - it's Falcon 4: Allied Force by Lead Pursuit You need to upgrade. AFAIK the release version had buggy multiplayer, and it was improved dramaticaly for 1.03. TVirta Thanks. I have managed to do it, but my friend has suffered the same problems as others with the patch failing using both the auto install program and the exe file itself. Maybe this will cure our woes! |
Mark 12D Problem??? | three-eight-hotel | Owning | 24 | June 10th 16 12:18 AM |
OT - Internet and on-line booking questions for the group | Jay Honeck | Piloting | 99 | January 22nd 05 08:17 PM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
FWD: Look at this internet patch for Microsoft Internet Explorer | Charles S | Home Built | 15 | October 2nd 03 08:08 PM |
Millionaire at 31... on the Internet. Listen to how he's doing it. | ower | Home Built | 0 | August 2nd 03 10:23 AM |
