![]() wrote in message ups.com... I should clarify. I don't mean the small acrylic stub on Cessna wings that lets you see the nav light from the cockpit. What I mean is a lightpipe to send the light from an LED illuminator lcoated inside the fuselage to the tip of the rudder (or wings).\ I don't see the advantage of doing what you are proposing. The typical nav LED nav light has a cluster of several LED's, both for pattern, and for brightness. I don't believe you could get the necessary brightness for one location, let alone multiple locations, using a single LED, or even a couple. Even if you clustered the LED's at a central location, and piped them out to the remote locations using fiber optics, do you think the weight or complexity would be less? I can't imagine how. You might need lenses to correctly distibute the light also, which would not be needed with the LED's out at the locations. -- Jim in NC |
Panel Lights - Need Help | Barnyard BOb - | Home Built | 2 | May 29th 04 07:51 PM |
Anti collision light mod for Piper Arrow 1968 model? | Frode Berg | Owning | 4 | May 20th 04 05:16 AM |
Building chasing airport lights -- Attn: Jim Weir? | Jay Honeck | Owning | 79 | February 29th 04 02:10 PM |
