![]() "Jim Macklin" wrote in message news:vVpmf.17957$QW2.13192@dukeread08... Agreed, but it was a stupid thing to do, MDW is marginal on good VFR days. IFR caused by low ceilings and visibilities are not really a problem either, you either see and land on a dry or wet runway or make a missed approach. But snow and icy runways have poor braking, runway light obscured, white-out conditions with attendant landing problems. Airline pilots are well trained and regimented. This can be good or bad. When "company pressure" makes non-operational needs, such as the companies bottom line or on-time record, more important issues can take a backseat. PIC means that you take the heat, if necessary, from passengers, chief pilot and upper management when you spend a few hundred or thousands of dollars diverting. A good chief pilot will support a well reasoned decision to divert. There should be a pat on the back for a good safe diversion, but often it is "chicken, we got in OK, why did everybody else except you land." [The fact is that is rarely true, lots of pilots divert or delay, but since they didn't crash, who knows.] You need to call the NTSB. They say it could take them a year to determine the cause of the accident. You seem to have figured it out without having been there. I am sure they will appreciate the help. -- James H. Macklin ATP,CFI,A&P "beavis" wrote in message ... | The fact that this is the airline's first fatal crash in nearly 35 | years of operation speaks volumes about its safety culture. I'd put | its record up against any airline's. |
If I had a spare $10, to bet, you can send my winnings to me
when the NTSB is finished. I correctly described the final report of the JFK,Jr. NTSB report the day of the crash. I may be very smart or psychic (or is that psycho) but in any case, I have no official standing or any reason to withhold my opinion. I do KNOW the length of the runway and the configuration of an ILS. The last time I personally landed at MDW it was in a blizzard with snow deep enough that the tips of the props on the King Air 300 were cutting into the snow on the unplowed taxiways. I will tell you that 90% of the nose wheel tires on most airplanes below 40,000 pounds are worn out on the right side [left side when viewed from the front] and I can teach you why this is so and improve all your flying technique, but you'll need to send me more than $10 for that. -- James H. Macklin ATP,CFI,A&P "Dave Stadt" wrote in message . com... | | "Jim Macklin" wrote in message | news:vVpmf.17957$QW2.13192@dukeread08... | Agreed, but it was a stupid thing to do, MDW is marginal on | good VFR days. IFR caused by low ceilings and visibilities | are not really a problem either, you either see and land on | a dry or wet runway or make a missed approach. But snow and | icy runways have poor braking, runway light obscured, | white-out conditions with attendant landing problems. | Airline pilots are well trained and regimented. This can be | good or bad. When "company pressure" makes non-operational | needs, such as the companies bottom line or on-time record, | more important issues can take a backseat. | | PIC means that you take the heat, if necessary, from | passengers, chief pilot and upper management when you spend | a few hundred or thousands of dollars diverting. A good | chief pilot will support a well reasoned decision to divert. | There should be a pat on the back for a good safe diversion, | but often it is "chicken, we got in OK, why did everybody | else except you land." [The fact is that is rarely true, | lots of pilots divert or delay, but since they didn't crash, | who knows.] | | You need to call the NTSB. They say it could take them a year to determine | the cause of the accident. You seem to have figured it out without having | been there. I am sure they will appreciate the help. | | -- | James H. Macklin | ATP,CFI,A&P | | "beavis" wrote in message | ... | | The fact that this is the airline's first fatal crash in | nearly 35 | | years of operation speaks volumes about its safety | culture. I'd put | | its record up against any airline's. | | | | |
airplanes below 40,000 pounds are worn out on the right side [left side when viewed from the front] and I can teach you why this is so and improve all your flying technique, but you'll need to send me more than $10 for that. Okay, 'fess up. Why is this so? (You'll earn ten bucks off your next stay at the Inn... :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Pilots tend to sit on the left side and not look truly
straight ahead, but look a few degrees toward the center of the airplane. Thus they think the airplane's longitudinal axis is not aligned with the direction of travel, since their reference point is incorrect. I've even seen pilots, in calm wind conditions, setup a slip to align their incorrect aim point. Then since they also fail to properly flare and follow through with the landing, allowing the nose to slam down when the torque from main wheel spin-up occurs, the nose wheel tire makes hard contact with the ground while swinging to the right as the CG corrects their direction of travel. The cure is to first get an accurate reference point directly in front of the pilot, parallel and off-set from the centerline; Then always get that point pointed straight down the runway;And follow through with the flare so that the pilot controls the nose wheel touchdown. That will also make your airwork better, since that same reference point is used for in-flight maneuvers and the attention to detail makes you a better pilot. BTW, I've actually had a professional pilot, CFI taking a flight review want to come to blows when I told him what he was doing. It took a few trips around the pattern before he saw his error. This is not just a problem with SE trainers, look at the tires on a Lear or King Air next time you have the chance, it isn't uncommon to see all the tire wear on the co-pilot's side because the Captain does all the landings. -- James H. Macklin ATP,CFI,A&P "Jay Honeck" wrote in message news:HxCmf.394396$084.134791@attbi_s22... | I will tell you that 90% of the nose wheel tires on most | airplanes below 40,000 pounds are worn out on the right side | [left side when viewed from the front] and I can teach you | why this is so and improve all your flying technique, but | you'll need to send me more than $10 for that. | | Okay, 'fess up. Why is this so? | | (You'll earn ten bucks off your next stay at the Inn... :-) | -- | Jay Honeck | Iowa City, IA | Pathfinder N56993 | www.AlexisParkInn.com | "Your Aviation Destination" | | |
look at the tires on a Lear or King Air next time you have the chance, it isn't uncommon to see all the tire wear on the co-pilot's side because the Captain does all the landings. Interesting observation, Jim -- thanks. As a new pilot I used to occasionally have trouble landing in a slight crab, even when there was no crosswind. (In fact, it was sometimes worse with NO wind at all.) I cured that problem by consciously aligning the nose and tail of the plane with the runway, not just aligning *me* with the runway. Now, it's second nature, but it took some analysis to figure out what I was doing wrong. It never dawned on me that this was common, and would result in uneven nose-tire wear! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
It is not stressed during check-outs, to get a true sight
picture. In many airplanes the pilot sits about 5 degrees from his eye to the only visible part of the cowl/nose and that is the hump over the prop. Unless to conscientiously avoid using it as a reference, your eye will use it as a default reference for alignment. It is very easy to fix as a pilot or instructor if you know to look for the signs. If you are an instructor giving a flight review to an owner, you can gain extra points by telling him about his landing problem even before you start the engine. A grease penciled mark (I like crosshairs on the spot) makes it easy to cure the pilot and teach the student. Soon they won't need it. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm "Jay Honeck" wrote in message news ![]() | This is not just a problem with SE trainers, | look at the tires on a Lear or King Air next time you have | the chance, it isn't uncommon to see all the tire wear on | the co-pilot's side because the Captain does all the | landings. | | Interesting observation, Jim -- thanks. | | As a new pilot I used to occasionally have trouble landing in a slight crab, | even when there was no crosswind. (In fact, it was sometimes worse with NO | wind at all.) I cured that problem by consciously aligning the nose and | tail of the plane with the runway, not just aligning *me* with the runway. | | Now, it's second nature, but it took some analysis to figure out what I was | doing wrong. It never dawned on me that this was common, and would result | in uneven nose-tire wear! | -- | Jay Honeck | Iowa City, IA | Pathfinder N56993 | www.AlexisParkInn.com | "Your Aviation Destination" | | |
I look down the piano hinge line on the left side of the cowl..
Places the nose wheel on the centerline every time.. Well.... every time I have the hinge lined up anyway... ![]() Dave On Sat, 10 Dec 2005 18:45:55 GMT, "Jay Honeck" wrote: This is not just a problem with SE trainers, look at the tires on a Lear or King Air next time you have the chance, it isn't uncommon to see all the tire wear on the co-pilot's side because the Captain does all the landings. Interesting observation, Jim -- thanks. As a new pilot I used to occasionally have trouble landing in a slight crab, even when there was no crosswind. (In fact, it was sometimes worse with NO wind at all.) I cured that problem by consciously aligning the nose and tail of the plane with the runway, not just aligning *me* with the runway. Now, it's second nature, but it took some analysis to figure out what I was doing wrong. It never dawned on me that this was common, and would result in uneven nose-tire wear! |
A hinge or painted line is always nice. But some airplanes
don't have such, sometimes you can't see any part of the nose past the window frame. But what ever you fly you have to find something to use as references. -- James H. Macklin ATP,CFI,A&P "Dave" wrote in message ... |I look down the piano hinge line on the left side of the cowl.. | | Places the nose wheel on the centerline every time.. | | Well.... every time I have the hinge lined up anyway... ![]() | | Dave | | | | On Sat, 10 Dec 2005 18:45:55 GMT, "Jay Honeck" | wrote: | | This is not just a problem with SE trainers, | look at the tires on a Lear or King Air next time you have | the chance, it isn't uncommon to see all the tire wear on | the co-pilot's side because the Captain does all the | landings. | | Interesting observation, Jim -- thanks. | | As a new pilot I used to occasionally have trouble landing in a slight crab, | even when there was no crosswind. (In fact, it was sometimes worse with NO | wind at all.) I cured that problem by consciously aligning the nose and | tail of the plane with the runway, not just aligning *me* with the runway. | | Now, it's second nature, but it took some analysis to figure out what I was | doing wrong. It never dawned on me that this was common, and would result | in uneven nose-tire wear! | |
Jim Macklin wrote:
Pilots tend to sit on the left side and not look truly straight ahead, but look a few degrees toward the center of the airplane. A few hours with a taildragger will do wonders to fix this. The cure is to first get an accurate reference point directly in front of the pilot, parallel and off-set from the centerline; This is exactly correct. In my Maule, this point was the upper left mounting screw for the AI. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
Tailwheel airplanes are wonderful teachers, maybe the new
Legacy Cubs will spark a renewal of landing skills. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm "George Patterson" wrote in message news:l1Nmf.9752$Wo2.5041@trnddc04... | Jim Macklin wrote: | | Pilots tend to sit on the left side and not look truly | straight ahead, but look a few degrees toward the center of | the airplane. | | A few hours with a taildragger will do wonders to fix this. | | The cure is to first get an accurate reference point | directly in front of the pilot, parallel and off-set from | the centerline; | | This is exactly correct. In my Maule, this point was the upper left mounting | screw for the AI. | | George Patterson | Coffee is only a way of stealing time that should by rights belong to | your slightly older self. |
