"Icebound" wrote in
: "Michelle P" wrote in message .net... When I took off this morning the Altimeter was 30.45 or there abouts. As the day progressed it rose and rose and rose. By this evening it had topped 30.60 KDCA 080151Z COR 35009KT 10SM FEW250 M02/M10 A3065 RMK AO2 SLP377 T10171100 Michelle That's just 'cause you operate in that balmy DCA climate :-). I am betting that Jay's neck of the woods has seen greater that 30.90 in the winter time. Its hard to pin down what the all time record is, but somewhere in Siberia claims a 31.60 in 2001. According to: [see, clearly credited, and in advance!!!] ![]() http://en.wikipedia.org/wiki/Barometric_pressure "The highest recorded atmospheric pressure, 108.6 kPa (1086 mbar or 32.06 inches of mercury), occurred at Tosontsengel, Mongolia, 19 December 2001." Brian -- http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html Quake "predictions": http://www.skywise711.com/quakes/EQDB/index.html Sed quis custodiet ipsos Custodes? Like censorship and not getting support help? Switch to Supernews! They won't even answer questions through your ISP! |
![]() But is that altimeter setting or atmospheric pressure? The altimeter setting is the atmospheric pressure extrapolated to sea level. If Tosontsengel is above sea level, then the altimeter setting would have been higher than 32.06. BTW, in the U.S. you can't fly when the altimeter setting is above 31.00 (FAR 91.144) |
![]() "Andrew Sarangan" wrote in message ups.com... BTW, in the U.S. you can't fly when the altimeter setting is above 31.00 (FAR 91.144) It doesn't say you cannot fly, it just says you cannot "operate an aircraft or initiate a flight contrary to the requirements established by the Administrator and published in a Notice to Airmen issued under this section." In other words, you have to follow the NOTAMS and other special instructions... |
31.00 (FAR 91.144) Sure you can. You just have to comply with the NOTAM which would be issued. Jose -- You can choose whom to befriend, but you cannot choose whom to love. for Email, make the obvious change in the address. |
India Balloonist Sets Highest Flight Mark | Larry Dighera | Piloting | 0 | November 26th 05 03:37 PM |
Highest Houred LS1F | Sleigh | Soaring | 0 | November 25th 04 04:50 PM |
Highest glider flight June 21 | John Jones | Soaring | 3 | June 4th 04 05:29 AM |
A failure of leadership at the highest levels - U.S. ARMY TIMES | WalterM140 | Military Aviation | 0 | May 13th 04 10:56 AM |
~ U.S. DEATHS HIGHEST SINCE VIETNAM! ~ ["Mission Accomplised!"] | MORRIS434 | Military Aviation | 1 | April 23rd 04 07:25 PM |
