The highest I have seen it
Old December 8th 05, 02:10 AM posted to rec.aviation.piloting
Default The highest I have seen it
When I took off this morning the Altimeter was 30.45 or there abouts. As
the day progressed it rose and rose and rose. By this evening it had
topped 30.60
KDCA 080151Z COR 35009KT 10SM FEW250 M02/M10 A3065 RMK AO2 SLP377 T10171100
Michelle
Old December 10th 05, 03:55 AM posted to rec.aviation.piloting
"Michelle P" wrote in message
.net...
topped 30.60
T10171100
Michelle
That's just 'cause you operate in that balmy DCA climate :-). I am betting
that Jay's neck of the woods has seen greater that 30.90 in the winter time.
Its hard to pin down what the all time record is, but somewhere in Siberia
claims a 31.60 in 2001.
Old December 10th 05, 06:22 AM posted to rec.aviation.piloting
"Icebound" wrote in
.net...
As the day progressed it rose and rose and rose. By this evening it had
topped 30.60
T10171100
Michelle
betting that Jay's neck of the woods has seen greater that 30.90 in the
winter time.
Siberia claims a 31.60 in 2001.
According to: [see, clearly credited, and in advance!!!]
http://en.wikipedia.org/wiki/Barometric_pressure
"The highest recorded atmospheric pressure, 108.6 kPa (1086 mbar
or 32.06 inches of mercury), occurred at Tosontsengel, Mongolia,
19 December 2001."
Brian
http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism
Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html
Quake "predictions": http://www.skywise711.com/quakes/EQDB/index.html
Sed quis custodiet ipsos Custodes?
Like censorship and not getting support help? Switch to Supernews!
They won't even answer questions through your ISP!
Old December 10th 05, 03:56 PM posted to rec.aviation.piloting
But is that altimeter setting or atmospheric pressure? The altimeter
setting is the atmospheric pressure extrapolated to sea level. If
Tosontsengel is above sea level, then the altimeter setting would have
been higher than 32.06.
BTW, in the U.S. you can't fly when the altimeter setting is above
31.00 (FAR 91.144)
Old December 10th 05, 04:02 PM posted to rec.aviation.piloting
"Andrew Sarangan" wrote in message ups.com...
31.00 (FAR 91.144)
It doesn't say you cannot fly, it just says you cannot "operate an aircraft or initiate a flight contrary to the
requirements established by the Administrator and published in a Notice to Airmen issued under this section." In other
words, you have to follow the NOTAMS and other special instructions...
Old December 10th 05, 04:14 PM posted to rec.aviation.piloting
31.00 (FAR 91.144)
Sure you can. You just have to comply with the NOTAM which would be issued.
Jose
You can choose whom to befriend, but you cannot choose whom to love.
India Balloonist Sets Highest Flight Mark Larry Dighera Piloting 0 November 26th 05 03:37 PM
Highest Houred LS1F Sleigh Soaring 0 November 25th 04 04:50 PM
Highest glider flight June 21 John Jones Soaring 3 June 4th 04 05:29 AM
A failure of leadership at the highest levels - U.S. ARMY TIMES WalterM140 Military Aviation 0 May 13th 04 10:56 AM
~ U.S. DEATHS HIGHEST SINCE VIETNAM! ~ ["Mission Accomplised!"] MORRIS434 Military Aviation 1 April 23rd 04 07:25 PM
