![]() "Matt Whiting" wrote in message ... .Blueskies. wrote: "Mike Schumann" wrote in message k.net... Landing in BOS in crummy conditions with a tailwind may be OK due to longer runways. Landing with a 9 knot tailwind in a blizard with fair to poor braking on a 6,500' runway was obviously not a good idea. Mike Schumann What did the performance numbers indicate for the conditions the pilot landed in? What was the final approach speed calculated to? What distance was required to stop? Don't know the numbers? You cannot take the stance that this was obviously not a good idea... The fact that the airplane ended up past the end of the runway is sufficient evidence that this landing was not a good idea. How much more evidence does one need? Matt I need more evidence than some Monday night wannabe quarterback making a WAG. Could be a multitude of mechanical, electrical, electronic or other problems that caused the accident. Time will tell. |
WAG. Could be a multitude of mechanical, electrical, electronic or other problems that caused the accident. Time will tell. This is all speculation, that is all true. Something that bugs me is that the ILS for 31C requires RVR of 4000 or 3/4 of mile visibility. The METAR from just before the accident pegged visibility at 1/2 mile. Seems to me that the approach shouldn't have even started. Charles Oppermann www.coppersoftware.com |
Charles wrote:
I need more evidence than some Monday night wannabe quarterback making a WAG. Could be a multitude of mechanical, electrical, electronic or other problems that caused the accident. Time will tell. This is all speculation, that is all true. Something that bugs me is that the ILS for 31C requires RVR of 4000 or 3/4 of mile visibility. The METAR from just before the accident pegged visibility at 1/2 mile. Seems to me that the approach shouldn't have even started. On the face of it yes, but you're ignoring all the other potential sources of *updated* weather info. Hilton |
Charles Oppermann wrote:
Something that bugs me is that the ILS for 31C requires RVR of 4000 or 3/4 of mile visibility. The METAR from just before the accident pegged visibility at 1/2 mile. Seems to me that the approach shouldn't have even started. Possibly. However, the RVR report is not the same as prevailing visibility reported in the METAR. It's not unusual for the two to be quite different when there is a reduced visibility condition on or near the airport. Jack |
"Jack" wrote in message
. net... Charles Oppermann wrote: Something that bugs me is that the ILS for 31C requires RVR of 4000 or 3/4 of mile visibility. The METAR from just before the accident pegged visibility at 1/2 mile. Seems to me that the approach shouldn't have even started. Possibly. However, the RVR report is not the same as prevailing visibility reported in the METAR. It's not unusual for the two to be quite different when there is a reduced visibility condition on or near the airport. And, particularly with snow ands fog, the view from the cockpit doesn't match either. They're a very good wakeup call. But the are often irrelevant on final. moo |
In article , Charles Oppermann
wrote: This is all speculation, that is all true. Something that bugs me is that the ILS for 31C requires RVR of 4000 or 3/4 of mile visibility. The METAR from just before the accident pegged visibility at 1/2 mile. Seems to me that the approach shouldn't have even started. Well, for starters, prevailing visibility and a specific runway's RVR can often differ by quite a bit. That's why RVR is controlling for an airliner. It also changes minute by minute, and the hourly ATIS isn't at all a good indicator of what the RVR was when that airplane landed. Second, Southwest's 737-700 airplanes have a heads-up display that lets them use 3000 RVR on that runway at MDW. |
that the ILS for 31C requires RVR of 4000 or 3/4 of mile visibility. The METAR from just before the accident pegged visibility at 1/2 mile. Seems to me that the approach shouldn't have even started. Well, for starters, prevailing visibility and a specific runway's RVR can often differ by quite a bit. That's why RVR is controlling for an airliner. It also changes minute by minute, and the hourly ATIS isn't at all a good indicator of what the RVR was when that airplane landed. Yep, thanks for that. The hourly METAR was: KMDW 090053Z 10011KT 1/2SM SN FZFG BKN004 OVC014 M03/M05 A3006 RMK AO2 SLP196 R31C/4500FT SNINCR 1/10 P0000 T10331050 $ Showing the field visibilty as 1/2-mile and 31C's RVR as 4,500 feet - greater than minimum. The FAA accident report has the following for the weather: 0115 11007KT 1/2SM SN FZFG VV003 M04/M05 A3006 R31C/4500V500 This doesn't appear properly formatted, as with a V separator, it's supposed to be minimum and maximum. It's possible that it's supposed to be a minimum of 4,500 and a maximum of 5,000 feet, and the extra zero was dropped off. Or it could be that visibility ranged from 500 feet to 4,500 feet. That I find less likely. It'll be interesting to get the CVR and ATC transcripts and find out what the pilots were told. Second, Southwest's 737-700 airplanes have a heads-up display that lets them use 3000 RVR on that runway at MDW. Interesting! Do you any additional info on that? |
wrote: The FAA accident report has the following for the weather: 0115 11007KT 1/2SM SN FZFG VV003 M04/M05 A3006 R31C/4500V500 This doesn't appear properly formatted, as with a V separator, it's supposed to be minimum and maximum. It's possible that it's supposed to be a minimum of 4,500 and a maximum of 5,000 feet, and the extra zero was dropped off. That's incorrect -- it's not minimum to maximum. It's 4500, variable to 500. In the ops specs for every airline operation with which I'm familiar, including my current 121 airline, the "variable" portion is advisory only. So as far as weather for starting the approach, it was 4500. It'll be interesting to get the CVR and ATC transcripts and find out what the pilots were told. Yep. If the tower gave them a more up-to-date RVR (which is pretty likely), that's controlling over the sequence weather you posted above. Second, Southwest's 737-700 airplanes have a heads-up display that lets them use 3000 RVR on that runway at MDW. Interesting! Do you any additional info on that? I don't have much info beyond that, specific to SWA. The HUD is an option on the next-generation 737s, and many of SWA's are so-equipped. It's a real safety enhancement in low visibility. (That should also discredit the notion that the airline skimps on safety equipment -- it doesn't.) Here's a picture of it in one of their cockpits: http://www.airliners.net/open.file/868375/L/ |
to 500. In the ops specs for every airline operation with which I'm familiar, including my current 121 airline, the "variable" portion is advisory only. So as far as weather for starting the approach, it was 4500. Hmmm, I was going by the various METAR decoders I have and a look at the FAA's Aviation Weather Services publication (AC 00-45E). A detailed breakdown at the following link: http://www.met.tamu.edu/class/METAR/metar-pg8-RVR.html This is academic parsing, and may not reflect actual practice. I don't have much info beyond that, specific to SWA. The HUD is an option on the next-generation 737s, and many of SWA's are so-equipped. It's a real safety enhancement in low visibility. (That should also discredit the notion that the airline skimps on safety equipment -- it doesn't.) Here's a picture of it in one of their cockpits: http://www.airliners.net/open.file/868375/L/ Very cool, thanks. Since it only exists on the captain's side, I wonder what the CRM procedure is to shift roles if the first officer is the Pilot Flying. Thanks for the link. |
On Mon, 12 Dec 2005 19:05:33 -0800, "Charles Oppermann"
wrote: I don't have much info beyond that, specific to SWA. The HUD is an option on the next-generation 737s, and many of SWA's are so-equipped. It's a real safety enhancement in low visibility. (That should also discredit the notion that the airline skimps on safety equipment -- it doesn't.) Here's a picture of it in one of their cockpits: http://www.airliners.net/open.file/868375/L/ Very cool, thanks. Since it only exists on the captain's side, I wonder what the CRM procedure is to shift roles if the first officer is the Pilot Flying. I think the OPSPEC generally requires the captain to handle landing if the weather is that bad. |
