#21
![]() "Flyingmonk" wrote in message oups.com... I hear that IAD (Dulles International Airport, in Northern Virginia) will be replaced by a bigger international airport also. I live ten minutes away from IAD. Dulles is going to be replaced? Or just expanded? |
They are on-off mircroswitches, the switch completes the
circuit when the strut is compressed to the static ground position. -- James H. Macklin ATP,CFI,A&P "Marc CYBW" wrote in message news:fAZmf.251433$ir4.208268@edtnps90... | But a smooth landing and lowering | the nose may have been to delicate to trigger the automatic | deployment of the systems. | | | My goodness. How sensitive are those gear load sensing switches? | | Marc | | | "Jim Macklin" wrote in message | news:lSYmf.22834$QW2.3354@dukeread08... | Jet Crew: Reverse Thrusters Failed in Chicago | | Associated Press | Sunday, December 11, 2005; A12 | | | | CHICAGO, Dec. 10 -- The reverse thrusters that should have | slowed a Southwest Airlines jetliner before it slid off a | runway at Midway International Airport and into the street | did not immediately kick in when the pilots tried to deploy | them, federal investigators said Saturday after interviewing | the crew. | | How much of a role that braking equipment played in | Thursday's deadly accident was not immediately clear, | though, and the investigation is continuing. | | The plane's flight attendants told investigators that the | Boeing 737 did not appear to slow after it touched down at | Midway in a snowstorm Thursday, said Robert Benzon, the | National Transportation Safety Board's investigator in | charge. | | "They all said it was a smooth landing, but they could sense | a lack of deceleration," Benzon said. | | He said the pilots told investigators they began applying | the brakes manually as soon as they noticed that the plane | was not slowing properly. The plane, with 98 passengers | aboard, slid through a fence and into street traffic, where | it killed a 6-year-old boy in a car. | | Because of the blowing snow, none of the air traffic | controllers actually saw the plane land, but more than 10 | cameras could provide additional information. | | © 2005 The Washington Post Company | | | Automatic deployment of spoilers and thrust reversers | depends on compression of the main gear struts and probably | also the nose wheel strut. The description of a "smooth | landing" indicates pilot error in the technique usewd for | the landing. If the aircraft was flown on the ILS to just | above the surface, a slight flare and a very firm landing to | compress the mains, followed by quickly lowering the nose | they might have been OK. But a smooth landing and lowering | the nose may have been to delicate to trigger the automatic | deployment of the systems. | | | | "Marc CYBW" wrote | in message news:cCWmf.145990$S4.8066@edtnps84... | | | | | http://www.washingtonpost.com/wp-dyn...121001562.html | | | | | | | | -- | | M. Lattoni | | Calgary, Canada | | | | Skype: marc_lattoni | | Phone: 403.238.3731 | | eMail: | | | | | | | | |
A greaser landing would not necessarily compress the main
gear struts, which is what controls the auto-spoilers and unlocks the gate on the power levers for reverse. Lowering the nose gear will put the weight on three points and not just the two main gear, which could allow the struts to stay extended a little longer time. In a light aircraft, maximum braking comes with the aircraft on all three wheel and the elevator full back because the tail down force is pushing the main tires into the ground. It a transport with lift dump spoilers, the elevator position is not as critical. -- James H. Macklin ATP,CFI,A&P "Jim Carter" wrote in message t... | Well, The Washington Post being the source explains a lot. I was | wondering how they get the spoilers deployed with that nose wheel still | in the air. Seen it done dozens of times as I'm sure most on the | newsgroup have also. | | Regards, | | James A. (Jim) Carter | | | -----Original Message----- | From: Matt Whiting ] | Posted At: Sunday, December 11, 2005 12:50 PM | Posted To: rec.aviation.piloting | Conversation: Jet Crew: Reverse Thrusters Failed in Chicago - Washington | Post | Subject: Jet Crew: Reverse Thrusters Failed in Chicago - Washington | Post | | Marc CYBW wrote: | | But a smooth landing and lowering | the nose may have been to delicate to trigger the automatic | deployment of the systems. | | | | My goodness. How sensitive are those gear load sensing switches? | | The source was the Washington Post. | | | Matt | |
Jet blast deflectors, news media calls them sound barriers
(stupid news media). If a jet was a break-away or take-off thrust it would be blowing cars off the road, those curved steel plates deflect the jet blast upward. -- James H. Macklin ATP,CFI,A&P wrote in message ups.com... | | Toks Desalu wrote: | snip............... I could see that the plane barely missed | the wind breakers. Since I am a pilot, I easily recognized the no landing | zone. | | I'm a pilot too. What's a wind breaker? | | Frank | | | Toks Desalu | | "Marc CYBW" wrote in message | news:cCWmf.145990$S4.8066@edtnps84... | | | http://www.washingtonpost.com/wp-dyn...121001562.html | | | | -- | M. Lattoni | Calgary, Canada | | Skype: marc_lattoni | Phone: 403.238.3731 | eMail: | | | |
Sounds plausible to me, I've never flown anything bigger
than the BE1900 and the Beechjet BE400, so the exact operational sequence is only generally known to me. I do know that a "carrier landing" is the way to get the struts compressed ASAP. You raise a question about technique...If the pilot applied brakes manually before the wheels spun up to what ever rpm was required, wouldn't that block any further automatic spoiler deployment? -- James H. Macklin ATP,CFI,A&P "John Gaquin" wrote in message ... | | "Jim Macklin" wrote in message | | Automatic deployment of spoilers and thrust reversers | depends on compression of the main gear struts and probably | also the nose wheel strut. | | I've never flown the 737, but have the 727 and 747. Boeing used to be | pretty consistent in running systems through the models. On both the 727 | and 747, main gear compression *and* main wheel spin-up are both necessary | for operation of certain ground systems like reverse thrust, autospoilers, | autobraking, etc. IIRC, on the 727, nose gear compression is also required | for autospoiler deployment. Without a trip to the basement for research, I | can't recall the details. I *could* believe that after a landing in several | inches of snow, certain main wheels may not have spun up enough to release | the reverse actuators. | | |
"Flight spoilers (2 -1/2/3/4/500; 4 -NG's) augment the ailerons and are
powered by hydraulic system A (inboard) & B (outboard). Spoilers will continue to operate with speedbrake deployed. Ground spoilers are also from hydraulic system A. Only the outboard flight spoilers are powered by hydraulic sys B On landing, if armed, all spoilers will deploy when the thrust levers are at idle and any two wheels have spun up or right gear is compressed. If not armed, the speedbrakes will deploy when reverse thrust is selected." While airborne you will only see flight spoiler. On landing flight spoilers and ground spoilers deploy. On an 737 NG -With the Speed Brake handle in the up position and on the ground... Gnd Spoilers #1,6,7, & 12 between 52 & 60 degrees Flt. Spoilers # 2,3,4,5,8,9,10 &11 between 33 & 38 degrees The photos show the spoilers not deployeed-SOP when configuring the aircraft for emergency evacuation. Deployed spoilers would inhibit overwing emergency evacuation. |
Not a "windbreaker". They are called "blast fences". "Windbreakers" a
males full of gas!!!!!! As a passenger in the back, it is impossible to evaluate whether a pilot barely missed the blast fence or not. With two decades of part 121 flying, I do not second guess professional pilots when I am a passenger nor do I second guess the NTSB. Not much room for errors at LGA, Reagan, or Orange County. Of course with AA, CAL, DAL, LCC using LGA, and not SWA, you won't hear how dangerous LGA is. |
#28
Above 10 feet radar altimeter, you can manually deploy the flight
spoilers (8 panels). Below 10 feet radar altimeter and engines idle, flight (8 panels) and GROUND spoilers (4 panels) are armed and can be manually deployed prior to touchdown, wheels spin-up, or Rt. strut compression. |
#29
Sounds like something that should have been done.
-- James H. Macklin ATP,CFI,A&P "lynn" wrote in message oups.com... | Above 10 feet radar altimeter, you can manually deploy the flight | spoilers (8 panels). | | Below 10 feet radar altimeter and engines idle, flight (8 panels) and | GROUND spoilers (4 panels) are armed and can be manually deployed prior | to touchdown, wheels spin-up, or Rt. strut compression. | |
#30
I thought I heard it was gonna be replaced. I don't remember where I
heard it from. |
11 Nov 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | November 11th 03 11:58 PM |
08 Nov 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | November 9th 03 01:51 AM |
Washington Post Article | Tex Houston | Military Aviation | 4 | September 26th 03 03:35 PM |
18 Sep 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | September 19th 03 03:47 AM |
PFC Lynch gets a Bronze Star? | Brian | Military Aviation | 77 | August 2nd 03 11:15 AM |
