Charles Oppermann wrote:
I'll be curious to know how the Autobrakes usage (if in fact that is true) affects the outcome. On one hand, the Autobrakes can prevent wheel lockup and keep the aircraft under control. On the otherhand, manual braking should be able to result in shorter ground rolls, generally. I disagree that this is true generally. Everything I've read about anti-lock braking systems suggests that they will outperform humans under all but a few special conditions. The special conditions are the cases where locking the wheels is beneficial to a short stop. These conditions are basically deep snow or other soft material such as sand. In these cases, the material builds up in front of the lock tires and increases the resistance of the tire moving through the material (forms a bow wave essential). However on dry or wet pavement, ice, light snow, light layer of sand or loose dirt, etc., the ABS wins. I have seen a few tests (auto and motorcycle, not airplane) where very highly skilled racers have been able to outbrake and ABS vehicle on dry pavement. However, the margin of winning was very small, and only a few REALLY skilled drivers/riders could beat the ABS with any regularity. And through in a patch of loose dirt or oil, etc., and, at least with the motorcycles, the ABS would allow control to be maintained. Matt |
anti-lock braking systems suggests that they will outperform humans under all but a few special conditions. The special conditions are the cases where locking the wheels is beneficial to a short stop. This is good info, thanks. Here's a nugget from the NTSB report on the SWA accident at Burbank: "At the request of the Safety Board.s Airplane Performance Group, Boeing ran stopping distance simulations for this accident wherein maximum, medium, and minimum 737 autobrake applications, as well as maximum manual brake applications, were simulated for wet runway conditions after the 182-knot touchdown. These data indicate that the accident airplane would have required about 5,000 feet of runway length after touchdown to stop using maximum autobrakes and about 4,700 feet of runway length after touchdown to stop using maximum manual brakes." Still, that's not to say that manual braking would always result in shaving off 300 feet of the ground roll. I guess it depends on the exact conditions and pilot experience and technique. My current opinion is that stomping on the brakes would have been worse than allowing the Autobrake system, but that's just a WAG. Charles Oppermann http://spaces.msn.com/members/chuckop/ |
I disagree that this is true generally. Everything I've read about anti-lock braking systems suggests that they will outperform humans under all but a few special conditions. The special conditions are the cases where locking the wheels is beneficial to a short stop. This is good info, thanks. Here's a nugget from the NTSB report on the SWA accident at Burbank: "At the request of the Safety Board.s Airplane Performance Group, Boeing ran stopping distance simulations for this accident wherein maximum, medium, and minimum 737 autobrake applications, as well as maximum manual brake applications, were simulated for wet runway conditions after the 182-knot touchdown. These data indicate that the accident airplane would have required about 5,000 feet of runway length after touchdown to stop using maximum autobrakes and about 4,700 feet of runway length after touchdown to stop using maximum manual brakes." These were simulations, though, and not tests. It would be curious to see actual test data to see if the simulations are relatively accurate. Still, that's not to say that manual braking would always result in shaving off 300 feet of the ground roll. I guess it depends on the exact conditions and pilot experience and technique. Yes, every situation is somewhat unique. My current opinion is that stomping on the brakes would have been worse than allowing the Autobrake system, but that's just a WAG. Impossible to know for sure. This is one case where it actually might have been better if the airplane had left the runway earlier and got into some grass or softer area. That might well have allowed a shorter stop than did staying on the runway. Then again, if they'd have hit something more solid by doing this, they might have saved the child's life, but lost lives on the aircraft. No way to know. Matt |
Air Force Spy Trial to Proceed Despite Modified Evidence | Otis Willie | Military Aviation | 0 | September 13th 04 01:31 AM |
Flying Magazine Subscriptions Trial Offer | Keith | Aviation Marketplace | 0 | July 1st 04 05:24 PM |
Stars and Stripes Offers Free Electronic Newspaper, By Sgt. 1st Class Doug Sample, USA | Otis Willie | Naval Aviation | 0 | April 30th 04 09:45 PM |
Stars and Stripes Offers Free Electronic Newspaper, By Sgt. 1st Class Doug Sample, USA | Otis Willie | Military Aviation | 0 | April 30th 04 09:45 PM |
Trial Of Woman Accused Of Killing Military Husband Postponed | Otis Willie | Military Aviation | 0 | January 24th 04 12:05 AM |
