It could be done, but you'll spend about $8-9 a watt with no rebates cause your not grid connected.
Vist the homepower news groups. Or www.homepower.com You'll need a generator backup, diesel preferred. Calculations for Autonomy, days with out sun. Calculations for collector plate angle, for winter months. Possibly a licensed electrician to install. Depends on local codes. All systems are only %70-74 of their actual panel ratings, So keep this in mind. (its an efficiency thing) And probably a large 1000's of amp hours battery bank to meet the autonomy specs. Assuming 8hrs for lighting, 2K @ 8hrs (24v) is 666AH, usually Autonomy is 4-5 days. So your looking at 2000-3000 of AH battery capacity. (no cheep truck deep cycles here) Plus you'll need to charge them with the PV's ;D. Cheers "RST Engineering" wrote in message .. . After much thought and ponderance, I've come to the conclusion that to electrify the hangar using Pacific Gas & Electricity (PG&E -- Pigs, Goats, and Elephants) isn't clever. By the time you get them to hang a meter ($5k), trench from the power pole to the end of the row of hangars, conduit romex to 35 hangars at a cost somewhere around $50k ($1500 per hangar), and then pay the monthly electric bill, you could buy a hell of a wind/solar system and perch it on the (flat) hangar roof. Before I flail about gathering data, has anybody on these ngs actually installed a design whereby a hefty solar panel charges a hefty battery to run a hefty inverter? It doesn't have to be absolutely "clean" sinewave power as all we are running are fluorescent shop lights (about 400 watts worth), every now and again a small compressor, a small drill press, a small grinder, but none of these last few at the same time. My hit on it is that a 2 kW inverter would be more than enough to handle the AC side of it, and a bank of 12 volt truck batteries would work for the DC side of it, but there are the problems of parallelling large batteries, how to combine the outputs of solar cells and wind generators, and a reasonable source for all this stuff. There are issues around protecting the solar cells from hail, which we do get from time to time, battery acidic gases inside a hangar where a very expensive lump of aluminum is sitting for months on end, sizing the solar cell and wind generators, and other considerations along these lines. Comments appreciated. Jim |
Question on 172 M electrics... (1974 Skyhawk II) | [email protected] | Piloting | 8 | April 10th 04 04:52 AM |
