![]() wrote in message oups.com... Is your 6061 alclad? Most of my sheet aluminum use is 2024, which is almost universally alclad. As you probably know, 6061 is more corrosion resistant than 2024. If the corrosion is not deep or pitted, alodine it and go on. I. e., use phosphoric acid treatment to remove the stain and then passivate the surface with a chromic acid etch. Thanks, there isn't any pitting at all just a surface layer of white powder but it is hard to get off. 6061 rules! |
Gig says, 6061 rules!
Well, yeah, I guess so. It's not quite as strong as 2024 but excellent aircraft aluminum preferred by Chris Heintz. |
On Wed, 14 Dec 2005 16:12:57 -0600, "Gig 601XL Builder"
wrDOTgiaconaATcox.net wrote: wrote in message roups.com... Is your 6061 alclad? Most of my sheet aluminum use is 2024, which is almost universally alclad. As you probably know, 6061 is more corrosion resistant than 2024. If the corrosion is not deep or pitted, alodine it and go on. I. e., use phosphoric acid treatment to remove the stain and then passivate the surface with a chromic acid etch. Thanks, there isn't any pitting at all just a surface layer of white powder but it is hard to get off. 6061 rules! My rebel is mostly 6061 as well. Just rub it off with a scochbrite pad. |
Mercury another threat to aviation security? | Aviv Hod | Piloting | 2 | October 7th 04 06:24 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
