Flying through known or forecast icing
Old December 14th 05, 09:35 PM posted to rec.aviation.ifr,rec.aviation.piloting
Default Flying through known or forecast icing
No, the prohibition is in the FARs--specifically, 91.527, quoted in my
previous note in this thread.
That applies only to "large or turbine powered multi-engine" aircraft.
Jose
You can choose whom to befriend, but you cannot choose whom to love.
Old December 14th 05, 09:39 PM posted to rec.aviation.ifr,rec.aviation.piloting
Gary Drescher wrote:
No, there isn't any such loophole in the wording of the FARs: "91.527(b)
Sorry Garry...91.527 doesn't apply unless you are flying a large or
turbine powered aircraft.
Old December 14th 05, 09:44 PM posted to rec.aviation.ifr,rec.aviation.piloting
Sorry Gary...91.527 doesn't apply unless you are flying a large or
Oops, my mistake. Thanks for the correction.
--Gary
Old December 14th 05, 10:47 PM posted to rec.aviation.ifr,rec.aviation.piloting
According to Scott Dennstaedt's article in the latest IFR magazine, we won't
be seeing Airmets (or Area Forecasts) after early 2006. Better graphic
displays will take their place. Big plus is that the forecast area is more
precisely defined in both scope and time.
Bob Gardner
: No. Legally, forecast ice is "known icing."
Not to tangent too much, but doesn't that regulation regarding "prohibited
flight into known icing conditions" without certified de-ice equipment
loophole old
planes? I seem to recall something about if the POH for the aircraft does
not say the
magic words, "Flight into icing conditions prohibited," then it's not
illegal.
Certainly not a good idea and guaranteed to bite you on "careless and
wreckless" if
something happens, but strictly speaking not immediately illegal.
With the scAIRMETS for icing constituting "known-icing" everywhere north
of
the Carolinas for significant chunks out of the year, most GA planes are
operating
illegally.
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old December 14th 05, 11:18 PM posted to rec.aviation.ifr,rec.aviation.piloting
John Doe wrote:
Ok, I know this is one of those "it depends" answers, but I'm curious as to
what folks are willing to do in the winter time.
Assumptions:
Single engine piston aircraft with NO de-icing equipment.
Situation:
It's wintertime. You want to fly XC and there are midlevel clouds in the
forecast with the potential for icing to occur.
It looks like the band is thin enough to climb through and cruise in the
clear above the weather.
SO:
1) If the cloud layer is forecast to potentially have icing, can you legally
and would you climb through the layer to get up high for your trip? how
thick a layer, type of forecast, time spent in the layer, etc. What would
you be willing to risk transition through possible icing?
I believe the recent interpretations is that this would be illegal as
the cloud layer at below freezing temps would constitute an area of
"known" icing and thus penetrating it would not be legal. As to what I
would do personally ... well, I won't answer that here! :-)
2) Would that change any if those same conditions were now reported icing
from a recent PIREP?
It would change my personal view of the situation, but I don't think it
changes the legality.
3) If it's reported, can you transit the cloud layer legally?
I don't believe you can do so legally.
4) Let's say yoru trip starts off VFR but by the time you get to your
destination, a cloud layer has formed that has reported icing in it. Can or
or would you be willing to transit this layer to land at this destionation
or would you turn around or divert to land someplace to stay out of the
clouds?
Again it depends, but if I had sufficient fuel, I'd probably divert. If
I was low on fuel, I'd descend through the layer.
Matt
Old December 14th 05, 11:19 PM posted to rec.aviation.ifr,rec.aviation.piloting
How about the flight when you are VFR and encounter freezing rain with
resulting clear ice accumulation? Had it happen long about 1967 in a
brand new Cessna Cardinal in Louisiana and barely made it to the
overrun area at the approach end of the airport in Hammond, LA. Never
saw it coming and suddenly I was covered in ice......
Old December 14th 05, 11:22 PM posted to rec.aviation.ifr,rec.aviation.piloting
Bob Gardner wrote:
George, your heart is in the right place...but if you think that someone at
ATC has a pad of ticket forms just ready to write you up, you are sadly
mistaken. I was told by an officer of the controller's union that
controllers are not interested in the certification status of an airplane or
a pilot.
A former Assistant Administrator for Regulations and Certification told me
that it is the pilot who encounters icing conditions and makes no attempt to
escape who would get a violation...but only if that failure resulted in an
accident/incident or required special handling by ATC. No one at a Center
operating position knows if a pilot climbs or descends through a cloud.
This has certainly been my experience also. I recently flew from
Lebanon, NH to ELM on a day with the freezing level around 4,000 and an
MEA of 6,000 across the mountains of southern VT. I picked up some
light rime and requested higher and got between layers. The clouds
again arose to smite me, so I requested higher again and broke out on
top at 10,000. My requests were calm and matter of fact and the
controllers were extremely accomodating. There was never even a hint
that they questioned why I was flying an Arrow on such a day.
Matt
Old December 15th 05, 07:00 AM posted to rec.aviation.ifr,rec.aviation.piloting
The general icing AIRMET always contains the qualifier "in clouds and
precipitation". You're perfectly legal if you stay out of the clouds
and precipitation.
Old December 15th 05, 02:21 PM posted to rec.aviation.ifr,rec.aviation.piloting
In rec.aviation.ifr Matt Whiting wrote:
: This has certainly been my experience also. I recently flew from
: Lebanon, NH to ELM on a day with the freezing level around 4,000 and an
: MEA of 6,000 across the mountains of southern VT. I picked up some
: light rime and requested higher and got between layers. The clouds
: again arose to smite me, so I requested higher again and broke out on
: top at 10,000. My requests were calm and matter of fact and the
: controllers were extremely accomodating. There was never even a hint
: that they questioned why I was flying an Arrow on such a day.
Because you didn't have a problem, they don't have a problem. If you had
*had* a problem, they would have found this problem and busted you. Isn't it great?
-Cory
* Cory Papenfuss *
Have you ever... Jay Honeck Piloting 229 May 6th 05 08:26 PM
Known Icing requirements Jeffrey Ross Owning 1 November 20th 04 03:01 AM
Interesting. Life history of John Lear (Bill's son) Big John Piloting 7 September 20th 04 05:24 PM
Wife agrees to go flying Corky Scott Piloting 29 October 2nd 03 06:55 PM
