Wind/Solar Electrics ???
Old December 15th 05, 04:06 PM posted to rec.aviation.owning,sci.electronics.design
Default Wind/Solar Electrics ???
Hey Jim,
Try looking through this.
http://www.homepower.com/
My son has provide me some literature on renewable energy and I am
convinced with some up front spending you can survive anywere without
the power grid. You may need a 5KW generator at time when the wind,
solar, etc give out.
Regards, Ross
C-172F 180HP
KSWI
RST Engineering wrote:
After much thought and ponderance, I've come to the conclusion that to
electrify the hangar using Pacific Gas & Electricity (PG&E -- Pigs, Goats,
and Elephants) isn't clever. By the time you get them to hang a meter
($5k), trench from the power pole to the end of the row of hangars, conduit
romex to 35 hangars at a cost somewhere around $50k ($1500 per hangar), and
then pay the monthly electric bill, you could buy a hell of a wind/solar
system and perch it on the (flat) hangar roof.
Before I flail about gathering data, has anybody on these ngs actually
installed a design whereby a hefty solar panel charges a hefty battery to
run a hefty inverter? It doesn't have to be absolutely "clean" sinewave
power as all we are running are fluorescent shop lights (about 400 watts
worth), every now and again a small compressor, a small drill press, a small
grinder, but none of these last few at the same time.
My hit on it is that a 2 kW inverter would be more than enough to handle the
AC side of it, and a bank of 12 volt truck batteries would work for the DC
side of it, but there are the problems of parallelling large batteries, how
to combine the outputs of solar cells and wind generators, and a reasonable
source for all this stuff.
There are issues around protecting the solar cells from hail, which we do
get from time to time, battery acidic gases inside a hangar where a very
expensive lump of aluminum is sitting for months on end, sizing the solar
cell and wind generators, and other considerations along these lines.
Comments appreciated.
Old December 16th 05, 05:36 PM posted to rec.aviation.owning,sci.electronics.design
Ross Richardson wrote:
Hey Jim,
Regards, Ross
C-172F 180HP
KSWI
Goats, and Elephants) isn't clever. By the time you get them to hang
a meter ($5k), trench from the power pole to the end of the row of
hangars, conduit romex to 35 hangars at a cost somewhere around $50k
($1500 per hangar), and then pay the monthly electric bill, you could
buy a hell of a wind/solar system and perch it on the (flat) hangar roof.
to run a hefty inverter? It doesn't have to be absolutely "clean"
sinewave power as all we are running are fluorescent shop lights
(about 400 watts worth), every now and again a small compressor, a
small drill press, a small grinder, but none of these last few at the
same time.
handle the AC side of it, and a bank of 12 volt truck batteries would
work for the DC side of it, but there are the problems of parallelling
large batteries, how to combine the outputs of solar cells and wind
generators, and a reasonable source for all this stuff.
do get from time to time, battery acidic gases inside a hangar where a
very expensive lump of aluminum is sitting for months on end, sizing
the solar cell and wind generators, and other considerations along
these lines.
http://www.tinaja.com/glib/energfun.pdf
Many thanks,
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss: http://www.tinaja.com/whtnu.xml email:
Please visit my GURU's LAIR web site at
Question on 172 M electrics... (1974 Skyhawk II) [email protected] Piloting 8 April 10th 04 04:52 AM
