Video from the plane
Old December 15th 05, 12:06 PM posted to rec.aviation.soaring
Default Video from the plane
But how do you attatch it ??.. just a lot of ducktape ??
skrev i en meddelelse
This is what I used to make the silentflight acro vids..
http://www.mars-cam.com/cameras/bull...eras/v2217.htm
Al
Old December 15th 05, 12:31 PM posted to rec.aviation.soaring
I've attached bullet cameras and larger video cameras by making a
fiberglass mount that wraps the leading edge of fins and wings or
replaces a hatch w/ a more posative connection then using a lot of
duct tape. Tape can come loose and the camera will pound the crap out
of the aircraft. Not to mention the camera gets trashed or you might
brain someone on the ground. The adhesive on duct tape is also a bitch
to remove. There have been other posts regarding the best tape for
mounts. I seem to remember some sort of super gaffer's tape.
On Thu, 15 Dec 2005 13:06:46 +0100, "Jacob Olsen" jeo @
roups.com...
Al
Old December 15th 05, 04:51 PM posted to rec.aviation.soaring
There are a huge number of cameras at www.supercircuits.com. Note -
almost all need a separate mic. If you are using a miniDV camera to
record with a lipstick camera, get a lipstick camera with a horizontal
resolution as close to 500 lines, or more if possible. These
camera/mics will need a separate power supply, usually 12 volts. An
easy solution is a battey holder from Radio Shack that takes 8 - AA
alkaline batteries.
I usually make a mount from expanded polypropelene shaped as a bed
for the camera and secure it to the wing with duct tape. I've also
used zip ties to secure the camera to the side of my sunglasses for a
pilots-eye-view. I also have a clamp used for mounting a SLR camera
on a hang glider and clamp it to the wing pin carry thru, pointing the
camera either over my shoulder or down the wing. I use a small miniDV
camera as the tape deck and tuck it under my right elbow...
Bill
Recovery parachutes again! Cub Driver Piloting 35 July 8th 05 12:47 AM
My first aerobatic lesson Marco Rispoli Piloting 6 April 13th 05 02:21 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
