In rec.aviation.ifr Matt Whiting wrote:
: This has certainly been my experience also. I recently flew from : Lebanon, NH to ELM on a day with the freezing level around 4,000 and an : MEA of 6,000 across the mountains of southern VT. I picked up some : light rime and requested higher and got between layers. The clouds : again arose to smite me, so I requested higher again and broke out on : top at 10,000. My requests were calm and matter of fact and the : controllers were extremely accomodating. There was never even a hint : that they questioned why I was flying an Arrow on such a day. Because you didn't have a problem, they don't have a problem. If you had *had* a problem, they would have found this problem and busted you. Isn't it great? -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Maybe, but I really doubt it unless my problem resulted in an accident
or maybe a "deal" for the controller if I had to make a descent that they couldn't clear quickly enough. Even though I've flown in northeast winters for 28 years and tend to "take a look" even if icing is a possibility, I've only once ever gotten into anything I'd call trouble. Even then, I didn't need to declare, I just needed a block altitude clearance so I could descend until I could maintain altitude. Fortunately, I reached the equilibrium altitude prior to reaching ground elevation. :-) So what you're saying is that you're lucky to be alive. |
Paul Folbrecht wrote:
Maybe, but I really doubt it unless my problem resulted in an accident or maybe a "deal" for the controller if I had to make a descent that they couldn't clear quickly enough. Even though I've flown in northeast winters for 28 years and tend to "take a look" even if icing is a possibility, I've only once ever gotten into anything I'd call trouble. Even then, I didn't need to declare, I just needed a block altitude clearance so I could descend until I could maintain altitude. Fortunately, I reached the equilibrium altitude prior to reaching ground elevation. :-) So what you're saying is that you're lucky to be alive. In that case, yes, luck played a role. But I was also starting out at a very high altitude (11,000', which was 2,000 feet above where any icing was forecast) and flying away from the icing conditions (Lake Erie) with a 60K tailwind, so I did have many things in my favor. Hitting ice that high certainly wasn't expected though or I would have deviated farther south of the Lake. Matt |
Issues around de-ice on a 182 | Andrew Gideon | Piloting | 87 | September 27th 05 11:46 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Have you ever... | Jay Honeck | Piloting | 229 | May 6th 05 08:26 PM |
Known Icing requirements | Jeffrey Ross | Owning | 1 | November 20th 04 03:01 AM |
Wife agrees to go flying | Corky Scott | Piloting | 29 | October 2nd 03 06:55 PM |
