My First Time In Severe Turbulence (Long)
Old March 4th 04, 09:29 PM
David B. Cole
Default My First Time In Severe Turbulence (Long)
Tuesday's forecast for my neck of NJ was for a high of 63, light rain,
and 1500 overcast. The perfect day to get some actual IMC. My
instructor and I had planned on going to Hartford, CT to fly the LDA
Rwy 2 approach. However, by the time I made it to the airport the
layers were mostly scattered to broken at about 1500-2000 feet, but we
decided to go anyway. The forecast winds aloft were out of the
southwest at approximately 30 knots at 6000. However, there was a
weak cold front predicted to move through later in the day. We filed
for 7000, preflighted, and were on our way. We passed through a
broken layer at about 1200 and soon were on top on our way to our
initial altitude of 6000.
Because we had GPS we were cleared direct to our first intersection,
Brezy. After Brezy we flew direct to the Carmel VOR and I decided to
switch back to VOR Nav at that point. While it was fairly smooth at
altitude, the winds were strong and variable enough to make any wind
correction valid for only a few seconds. I never had to make so many
corrections to keep the CDI from going fully deflected. Because of
the tailwind we had a groundspeed of close to 160 kts. By the time I
figured out the winds we were being given vectors for the LDA and were
told to descend from 7000 to 2500. After leveling at 2500, the bumps
started to really pick up, but it was nothing too scary. I flew the
LDA as I would a normal LOC and managed to keep the CDI fairly
centered despite the bumps. We passed through a few clouds on the way
down and leveled at the circling minimums. I spotted what I thought
to be the airport, but it turned out to be another airport that
happened to be closed, but which was very close by. My instructor
admitted that he once made the same mistake so I didn't feel too bad.
After finally acquiring the right airport we circled to Rwy 20 and
landed uneventfully.
We went inside the FBO, checked the weather, and I spent even more
money by purchasing a couple of books. One happened to be Bob
Gardner's "The Complete Advanced Pilot", which appears to be excellent
in the portion I've read. Anyway, the briefer told us that the front
had moved in faster than expected and that winds aloft would be 40 kts
at 4000 and as high as 50 kts in some locations.
On the departure we turned to the southwest and had a GS of 30 kts in
the climb! The only time I'd gone that slow was during my private
training where we actually had a headwind strong enough to push us
backwards while doing slow flight. It seemed like we were literally
standing still on the climb back to 6000. In cruise, max groundspeed
was about 80 kts and sometimes as low as 60 kts. We had plenty of
fuel so we weren't concerned about running out, at least not then.
But we kept our eyes on the fuel gauges and the clock. My instructor
wanted to see if the winds were better at 4000, so we asked for
permission to switch to Flight Watch on 122.0 and report back when
done.
The winds aloft at 4000 were only 2 kts lower than at 6000, so we
decided to stay where we were. We gave a PIREP and reported back to
the NY approach controller. I had never used Flight Watch or given a
PIREP before, so this was good experience. I also received my first
amended clearance, which was also interesting. And despite the slow
going, it was still fairly smooth at altitude. But that's where the
fun ended. Approximately 30 miles NW of the airport we were lowered
to 2500. It was from there on out that I experienced the worst
turbulence I had ever experienced in a small plane. My head hit the
ceiling at least four times. I kept the airspeed below Va as the
plane essentially did what it wanted. We rolled 25-30 degrees
uncommanded on several occasions and once the sudden movement of the
yoke nearly took my wrist with it.
This was the first time I could say that I was somewhat nervous in
turbulence. The bigger boys going into Newark were reporting moderate
turbulence and before switching to the tower my instructor reported
that we had severe turbulence. Yet he remained calm and somehow I
still managed to keep altitude to within 100 feet, with the exception
of a few excursions down 150 feet.
We were vectored for LOC Rwy 22 approach at CDW. I tuned and ID'ed
the localizer, but was so whipped that I forgot to set the OBS head
from GPS to Nav. When I finally figured this out, thanks to my
instructor, the needle was centered and I still had a 30 degree
intercept. To make a long story even longer, I eventually got on
course, although we were still getting smacked around fairly hard.
The surface winds were from 260 at 12 kts, so we circled to Rwy 27,
although I made the mistake of descending to the straight-in minimums.
Back on the ground, my instructor complimented me on a good landing as
we taxied back. We were just in time for his next student, with whom
he of course cancelled. He also told me that he could tell I was
fatigued and if that happened on a solo flight I had to recognize it
and possibly land somewhere else until I was ok to fly. He also told
me that if I needed to use the autopilot, meaning himself, that I
shouldn't be embarrassed to say so. So between the weather, flying a
LDA, contacting Flight Watch, and getting an amended clearance, it was
still a very good lesson. If you've made it this far, thanks for
listening.
Dave
Old March 4th 04, 09:44 PM
Dale
In article , Ron Parsons
Hate to tell you, but by definition, Severe Turbulence means parts were
coming off of your aircraft.
Hate to tell you....that's incorrect.
Severe is described as:
Turbulence that causes large, abrupt changes in altitude and/or attitude. It
usually causes large variations in indicated airspeed. Aircraft may be
momentarily out of control.
The reaction in the airplane will be:
Occupants are forced violently against seat belts or shoulder straps. Unsecured
objects are tossed about. Food service and walking impossible.
Extreme turbulence may cause structural damage...but even that isn't a sure
thing.
Dale L. Falk
Old March 4th 04, 11:31 PM
Bob Gardner
Thanks for the kind words.
Bob Gardner
"David B. Cole" wrote in message
m...
done.
listening.
Dave
Old March 5th 04, 12:15 AM
Cecil E. Chapman
EXCELLENT account!!! Sounds like you handled it like a 'seasoned pro',,
congratulations! Don't know much about the N.J. area but my wife grew up in
Rariton (sp?) and she told me that she remembers some 'interesting' weather
in your neck of the woods!
Take care and once again congrats on a job well-done!
Good Flights!
Cecil
PP-ASEL
Student-IASEL
Check out my personal flying adventures from my first flight to the
checkride AND the continuing adventures beyond!
Complete with pictures and text at: www.bayareapilot.com
"I fly because it releases my mind from the tyranny of petty things."
- Antoine de Saint-Exupery -
"We who fly, do so for the love of flying. We are alive in the air with
this miracle that lies in our hands and beneath our feet"
- Cecil Day Lewis -
m...
done.
listening.
Dave
Old March 5th 04, 04:05 PM
Andrew Gideon
David B. Cole wrote:
My instructor
Your instructor brought you there specifically to make that mistake. I
know. My instructor did the same to me, and my instructor is your
instructor.
It's a good lesson. There are plenty of airports around with nearby
neighbors, even just in our area (northern NJ). It's not so likely on a
straight-in approach (though my person definition of "straight-in" doesn't
agree with TERPs {8^), but through in an angle like you have there and it
becomes a serious possibility.
Think, for example, about the VOR-27 into SWF. Unless you know where to
look at MDA, you could miss the airport. Now, stick another airport in the
vicinity...
So much for a light, two-fingered grip on the yoke, right?
Actually, you should have Stanley show you the AP in DR if he hasn't
already. It's a good one, and - like all other tools - you should be very
familiar with it.
Anyway: Nicely done.
- Andrew
Old March 10th 04, 10:21 PM
Michael
Just FYI - if you were managing to hold altitude within 100 ft most of
the time, and the worst deviation was 150 ft, this was not severe
turbulence. Severe turbulence is when unsecured objects are flying
about the cabin, the airplane is often uncontrollable, etc. What you
experienced was moderate turbulence. As a rough rule of thumb, if you
are hitting your head on the ceiling, that's moderate turbulence.
Anything less is light. When you can't keep your chart on your lap or
the airplane on course and altitude, that's severe.
The major hazard of moderate turbulence is fatigue, and fatigue is a
recipe for pilot error. You made several, but of course that's what
training is all about. I'm glat to see that your instructor point
this out for you, but I'm going to offer you a slightly different
perspective.
It's all very well to say that when you recognize fatigue you should
land, but the reality is you are eventually going to fly IFR fatigued,
just like you have driven in bad weather fatigued. You will sit in
some pilot lounge for several hours, being safety conscious and
waiting for the really bad weather to pass. You will then decide that
the weather isn't that bad anymore, and you're not that tired, and it
will all be OK. Then you will find yourself being beaten up, tired,
and needing to shoot an approach to get home - possibly with some
equipment failure. Of course you could always decide to only fly for
fun, and never fly when there's any pressure to be anywhere at any
particular time - but then what's the point of the instrument rating?
So assuming you are actually going to use the rating and stay current,
you need to be prepared for the day you will have to use it when you
are not at your best - without making the mistakes you did on that
last approach. How do you get to that point? Practice, man,
practice.
Michael
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
Simpy One of Many Stories of a Time Not So Long Ago Badwater Bill Home Built 40 March 16th 04 06:35 PM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 07:51 PM
