Benjamin Gawert wrote:
Charles Talleyrand schrieb: Suppose a smaller airplane with it's fly-by-wire controls goes runs out of fuel. All the engines quit. On a larger jet a ram air turbine would drop into the airstream and power the controls. How does it work on smaller planes like the Dassault Falcon or the F-16? The Panavia 200 Tornado has a EPS battery (one shot battery) that in case of double engine out situations supplies a few instruments and an electric pump to have some hydraulic pressure. This allows maintaining control over the a/c for ~5-7 (max 10) minutes. These EPS (Emergency Power System) Batteries are usually known as "Thermal Batteries". They have an eutectic electrolyte of salts that are melted by a pyrotechnical charge. Because the electrolyte is inert and sold untill melted shelf lives of 20+ years are possible. Because of the high opperating temperature very high power densities are possible. 20 years would not be full life for an airliner and a ram air turbine I suggest would require less maintenance. (ie it doesn't ever need replacement) Thermal batteries appear to be the battery of choice for missiles. I did read though that the early MANPAD Stingers handed over to the Mujahidine had thermal batteries that would now be failing and thus (thankfully) rendering the missiles inopperational. The Panavia Tornado also has Nickel Cadmium Secondary rechargeable batteries (perhaps upgraded to NiMH now?) for APU starting and other power. I suspect that these could keep the system up for a few minutes on their own if in good condition. Alternatively, I've always wondered if one could not keep a special reserve tank for the APU. When the engines quit, the APU automatically starts to power the controls. Would such a system be safe and would it be certifiable? Would it weigh less than the existing system? I a lot of airplanes the APUs (resp. their intakes and exhausts) are mounted in a way that they can't be used inflight. This would hardly apply to the Tornado. Tornado however uses its entire slab sided botton fueselage for weapons: there is little room for ram air turbine. Besides that, if there still is fuel in the tanks it's better served for keeping the engine alive than just the APU... Benjamin |
Eunometic schrieb:
These EPS (Emergency Power System) Batteries are usually known as "Thermal Batteries". They have an eutectic electrolyte of salts that are melted by a pyrotechnical charge. Because the electrolyte is inert and sold untill melted shelf lives of 20+ years are possible. Because of the high opperating temperature very high power densities are possible. The original PA200 EPS battery used liquid acid which when activated flowed in precharged battery chambers. Due to several hazards that these batteries incorporate they have been replaced by thermal batteries. 20 years would not be full life for an airliner and a ram air turbine I suggest would require less maintenance. (ie it doesn't ever need replacement) Nope. A RAM air turbine _does_ indeed need maintenance, not only because of aging seals and other items that have to be replaced from time to time but also because it's a quite complicated mechanical part that has to be checked in certain intervals to make sure it is in working condition. RAM air turbines are certainly not a put-it-in-and-forget-it thing... The Panavia Tornado also has Nickel Cadmium Secondary rechargeable batteries (perhaps upgraded to NiMH now?) for APU starting and other power. I suspect that these could keep the system up for a few minutes on their own if in good condition. Nope, the master battery (which is indeed NiMH now) only feeds certain busbars that are required for start and is not suitable for emergency operation... I a lot of airplanes the APUs (resp. their intakes and exhausts) are mounted in a way that they can't be used inflight. This would hardly apply to the Tornado. It does apply for the PA200 Tornado. The APU is not operable in-flight, if you loose both engines and the one-shot battery is down you have to get out of that thing... Tornado however uses its entire slab sided botton fueselage for weapons: there is little room for ram air turbine. Nope. It would be possible to integrate a RAM air turbine into the PA200 Tornado by relocating and re-arranging equipment in the lower electronics bays. However, the efforts and also the cost are not justifyable because a RAM air turbine would bring no real safety imrpovement on the Tornado which already has a really very good safety record, not to forget that it's old now and most airforces are planning and/or already working on replacing it. Benjamin |
![]() "Benjamin Gawert" wrote in message ... Eunometic schrieb: These EPS (Emergency Power System) Batteries are usually known as "Thermal Batteries". They have an eutectic electrolyte of salts that are melted by a pyrotechnical charge. Because the electrolyte is inert and sold untill melted shelf lives of 20+ years are possible. Because of the high opperating temperature very high power densities are possible. The original PA200 EPS battery used liquid acid which when activated flowed in precharged battery chambers. Due to several hazards that these batteries incorporate they have been replaced by thermal batteries. 20 years would not be full life for an airliner and a ram air turbine I suggest would require less maintenance. (ie it doesn't ever need replacement) Nope. A RAM air turbine _does_ indeed need maintenance, not only because of aging seals and other items that have to be replaced from time to time but also because it's a quite complicated mechanical part that has to be checked in certain intervals to make sure it is in working condition. RAM air turbines are certainly not a put-it-in-and-forget-it thing... The Panavia Tornado also has Nickel Cadmium Secondary rechargeable batteries (perhaps upgraded to NiMH now?) for APU starting and other power. I suspect that these could keep the system up for a few minutes on their own if in good condition. Nope, the master battery (which is indeed NiMH now) only feeds certain busbars that are required for start and is not suitable for emergency operation... I a lot of airplanes the APUs (resp. their intakes and exhausts) are mounted in a way that they can't be used inflight. This would hardly apply to the Tornado. It does apply for the PA200 Tornado. The APU is not operable in-flight, if you loose both engines and the one-shot battery is down you have to get out of that thing... Tornado however uses its entire slab sided botton fueselage for weapons: there is little room for ram air turbine. Nope. It would be possible to integrate a RAM air turbine into the PA200 Tornado by relocating and re-arranging equipment in the lower electronics bays. However, the efforts and also the cost are not justifyable because a RAM air turbine would bring no real safety imrpovement on the Tornado which already has a really very good safety record, not to forget that it's old now and most airforces are planning and/or already working on replacing it. The F3 (ADV) has a RAT |
Ian schrieb:
The F3 (ADV) has a RAT Really? Well, I only have experience with the GR versions which have a one shot battery... Benjamin |
![]() "Benjamin Gawert" wrote in message ... Ian schrieb: The F3 (ADV) has a RAT Really? Well, I only have experience with the GR versions which have a one shot battery... Benjamin Can't find a pic of where it is, but here's a pic of one of the external gauges checked during pre-flight http://www.tornado-data.com/History/.../pressures.htm |
Ian schrieb:
The F3 (ADV) has a RAT Really? Well, I only have experience with the GR versions which have a one shot battery... Benjamin Can't find a pic of where it is, but here's a pic of one of the external gauges checked during pre-flight http://www.tornado-data.com/History/.../pressures.htm Thanks for the picture. It's really interesting, I never had to do with the F series Tornados... Benjamin |
On Fri, 16 Dec 2005 22:57:37 +0100, Benjamin Gawert wrote:
Ian schrieb: The F3 (ADV) has a RAT Really? Well, I only have experience with the GR versions which have a one shot battery... Its located just behind the left main wheel but stalls when the gear is lowered, so its a wheels up landing if you've got the balls. ![]() -- Steve. |
Steve schrieb:
Its located just behind the left main wheel but stalls when the gear is lowered, so its a wheels up landing if you've got the balls. ![]() Well done ;-) Benjamin |
On Mon, 19 Dec 2005 00:47:23 +0100, Benjamin Gawert wrote:
Steve schrieb: Its located just behind the left main wheel but stalls when the gear is lowered, so its a wheels up landing if you've got the balls. ![]() Well done ;-) Thankyou :-) And for a bonus point, its not much use below 200Kts anyway. -- Steve. |
![]() Benjamin Gawert wrote: Eunometic schrieb: It does apply for the PA200 Tornado. The APU is not operable in-flight, if you loose both engines and the one-shot battery is down you have to get out of that thing... I didn't think Tornado was fully FBW? |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Thunderstorm - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 11:05 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
