Minimum Safe Altitude (MSA) Standards
Old March 8th 04, 02:13 PM
Andrew Sarangan wrote:
I realize that that is what the AIM says, but why are they to be used
for emergencies only? I always interpreted the MSA as the minimum
altitude to use when flying off-feeder routes (direct to the IAF),
sort of like the OROCA when flying off-airways.
In many countries MSAs are operational altitudes. They are not in the United States. And, in a
designated mountainous area you are required by 91.177 to have 2,000 feet vertically or 4 miles
laterally when off a published route or segment. MSAs are not IFR altitudes, routes, or segments.
Old March 10th 04, 12:58 PM
I agree that MSA does not satisfy the altitudes in mountainous areas.
But in nonmountainous areas MSA does satisfy the altitude
requirements. What am I missing here?
That they are not published as IFR altitudes under either of the pertinent IFR alitude regulations, Part
95 or Part 97.
Old March 10th 04, 01:34 PM
Gary Drescher
wrote in message ...
IFR alitude regulations, Part 95 or Part 97.
True, but under the circumstances Andrew described (flying off-route direct
to an IAF), Parts 95 and 97 do not prescribe a minimum altitude. Hence,
91.177a2 applies. In a non-mountainous area, 91.177a2ii specifies a
condition that can be assured by reference to the MSA.
--Gary
Old March 10th 04, 02:14 PM
--Gary
Your responsibilities under the off-route provisions of 91.177 you site are
absolute. OTOH, the design of MSAs by the FAA are done with sectional charts
and are not assessed with the precision that are accorded IFR altitudes.
Old March 10th 04, 03:14 PM
Gary Drescher
areas.
pertinent
direct
--Gary
are
charts
Which is typically how I'd ascertain an off-route minimum altitude in accord
with 91.177a2.
I'm not sure what you mean by "precision" here. The parameters are clearly
specified: 1000' above any obstacle in the designated sector. (The MSA
doesn't assure navaid reception, though, so that has to be assessed
separately.)
--Gary
Old March 10th 04, 04:03 PM
separately.)
The folks who design approach procedures at the FAA use very precise
topographical information to design the published segments of an instrument
approach procedure. For MSAs, though, they simply use sectionals, which may not
provide the required obstacle clearance at all times, simply because sectionals
do not have the accuracy that USGS 1:24,000 topos have.
Plus, when the FAA assesses the published segments they add 200 feet of assumed
adverse obstacle ("AAO") pad, because folks can construct towers, etc, up to 200
feet high without notifying the FAA, unless the towers are within certain
distances of an airport. There is no AAO assessment made for MSAs, though.
Also, spot elevations on sectionals can be off by a fair abount, without
adversly affecting their stated purpose; i.e., VFR navigation charts. And,
contours on sectionals are very coarse, although that isn't usually an issue in
non-mountainous areas.
Old March 20th 04, 08:13 PM
J Haggerty wrote:
MSA's do not ensure NAVAID or radio reception, and may even contain
sectors that are known areas of no signal coverage. They just ensure 951
feet of obstacle clearance within the specified distance from the NAVAID.
True, except 951 is no longer permitted per AFS-420. No more rounding down on TERPs ROC.
Reasoning behind course reversal Michael 182 Instrument Flight Rules 26 February 27th 04 03:27 PM
Requirement to fly departure procedures [email protected] Instrument Flight Rules 77 October 15th 03 06:39 PM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
