Is there a good place on the web that describes the basics and
terminology of piston engines? I understand the basic concepts, but some of the terms I read, like journals and bosses, etc., are a bit beyond me and I'd like to get a little bit better knowledge of the concepts. I'm definitely not looking to get to mechanic level knowledge, but to get beyond the "pistons go up and get blown down and turn the crankshaft" level of knowledge. |
terminology of piston engines? None that I've found. I've learned a lot on the Lycoming site, although their main purpose seems to be avoiding liability rather than educating their customers. Your A&P can be an excellent source of knowledge. My A&P has been remarkably patient, explaining everything to me multiple times. I've learned a lot here, too, but, again, it's hit and miss. If you find an all-inclusive "engine website", please share it with us all. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Read aircraft engine manuals. They can be bought on Ebay. Read the
material at Sacramento Sky Ranch. Also try this: http://www.answers.com/topic/journal...?hl=crankshaft http://www.100megsfree4.com/dictiona...dicb.htm#Board Comment: I found this 2nd one by googling mechanic's dictionary. It is a humongous resource with megs and megs of info. Thanks for the intellectual stimulation. |
What about your local library? An gasoline engine is a gasoline engine
regardless of application. Once you understand engines then focus on aircraft specifics. "jls" wrote in message oups.com... Read aircraft engine manuals. They can be bought on Ebay. Read the material at Sacramento Sky Ranch. Also try this: http://www.answers.com/topic/journal...?hl=crankshaft http://www.100megsfree4.com/dictiona...dicb.htm#Board Comment: I found this 2nd one by googling mechanic's dictionary. It is a humongous resource with megs and megs of info. Thanks for the intellectual stimulation. |
http://flash.aopa.org/asf/engine_prop/flash.cfm
wrote in message oups.com... Is there a good place on the web that describes the basics and terminology of piston engines? I understand the basic concepts, but some of the terms I read, like journals and bosses, etc., are a bit beyond me and I'd like to get a little bit better knowledge of the concepts. I'm definitely not looking to get to mechanic level knowledge, but to get beyond the "pistons go up and get blown down and turn the crankshaft" level of knowledge. |
Not exactly what you seem to have in mind, but for the operation of
piston engines, the engine management columns by John Deakin at www.avweb.com are a must-read. -- Thomas Borchert (EDDH) |
INTAKE STROKE: The piston goesdown, creating a vacuum in the cylinder
which draws gas through open intake valve into the space above the piston. COMPRESSION STROKE: The piston comes up with both valves closed, highly compressing the gas into the space left between thetop of the piston and cylinder head. POWER STROKE: At this point the magneto sends high tension current to the spark plug, firing or exploding the compressed gas and driving the piston down. EXHAUST STROKE: Exhaust valve opens and theupward stroke of the piston forces out all of the burnt gases, thus completing the power cycle. |
I'm not sure you answered the question...
" I understand the basic concepts, but some of the terms I read, like journals and bosses, etc., are a bit beyond me and I'd like to get a little bit better knowledge of the concepts." |
http://auto.howstuffworks.com/engine.htm
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 07:36 PM |
ROP masking of engine problems | Roger Long | Piloting | 1 | September 25th 04 07:13 PM |
Piston engine 101 Course? | [email protected] | Owning | 9 | October 28th 03 02:35 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
