Seaplane down off Miami Beach....
Old December 20th 05, 04:13 AM posted to rec.aviation.piloting
Default Seaplane down off Miami Beach....
Just saw the news clip of the airplane going into the water.
Got an URL for that?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old December 20th 05, 06:50 AM posted to rec.aviation.piloting
http://news.google.com/news?sourceid...ws-miami&hl=en
"Jay Honeck" wrote in message
news:ExLpf.414921$084.377502@attbi_s22...
water.
| Jay Honeck
| Iowa City, IA
| Pathfinder N56993
Old December 20th 05, 12:13 PM posted to rec.aviation.piloting
Thanks, Jim.
Here's the write-up that contains the actual video URL:
http://www.cnn.com/2005/US/12/20/miami.crash/
(You have to suffer through a Dodge truck commercial to see it, though...)
The wing clearly departed the airframe before the crash. I wonder if these
old birds are simply fatigued?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 20th 05, 12:27 PM posted to rec.aviation.piloting
My guess is that they had a loose or broken fuel line,
caught fire and the fuel vapor exploded and the fire melted
the spar enough for it to fail.. The airplane seems to have
been very sturdy, since the fuselage is intact after the
impact.
Thanks.
Merry Christmas
Have a Safe and Happy New Year
Live Long and Prosper
Jim Macklin
James H. Macklin
ATP,CFI,A&P
news:aASpf.660077$xm3.524670@attbi_s21...
| Thanks, Jim.
see it, though...)
I wonder if these
| Jay Honeck
| Iowa City, IA
| Pathfinder N56993
Old December 20th 05, 02:08 PM posted to rec.aviation.piloting
Boy, I sure hope that's "all" it was. (Who'd ever think we'd be saying that
kind of stuff?)
With everyone describing an "explosion" (which the video tends to
support) -- and Chalk's not having to do much in the way of security
screening, as a small carrier -- this could easily have been some kind of a
nut-job with a shoe bomb and a "cause".
And *then* we'd start seeing all sorts of stupid proposals for "enhanced
security" that we don't want or need.
Sad to say, a mechanical problem is the best-case scenario.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 20th 05, 02:41 PM posted to rec.aviation.piloting
kind of stuff?)
That seems unlikely as the video seems to show the fuselage pretty well
intact and the wing separated. Unless the wing has a luggage locker, I
doubt it was a bomb.
Matt
Old December 21st 05, 03:09 AM posted to rec.aviation.piloting
Jay
A monday morning WAG.
Turbine (disk) blew up and destroyed enough of the wing structure that
it failed.
Fuel tank(s) in wing then dumped fuel on hot parts of turbine and
caught fire.
Wingless (one wing) fuselage impacted water and broken off wing
floated down burning until it hit the water.
Lets see if my years of experience with accidents guessed right on
this bad accident.
Big John
On Tue, 20 Dec 2005 14:08:24 GMT, "Jay Honeck"
kind of stuff?)
Old December 21st 05, 03:44 AM posted to rec.aviation.piloting
The PT6 is mounted above and forward of the wing leading
edge, if the turbine had a failure, the bits and pieces are
not likely to impact the wing. But, if that happened
there will be positive evidence.
The PT6 is a pretty small turbine, they don't have many
problems internal to the engine.
James H. Macklin
ATP,CFI,A&P
Merry Christmas
Jim Macklin
"Big John" wrote in message
| Jay
structure that
| it failed.
turbine and
| caught fire.
wing
right on
| this bad accident.
| Big John
melted
we'd be saying that
| kind of stuff?)
tends to
of security
been some kind of a
scenario.
Old December 20th 05, 02:28 PM posted to rec.aviation.piloting
I'm wondering if fitting turbine engines on the old airframes
didn't pull something loose in the wing/mount.
This thing's just a heart breaker. I see them flying all the
time when I'm in Miami. They've been flying off Watson Island
forever. I've always thought it would be fun to fly with them
over to the Bahamas.
impact.
Thanks.
Old December 20th 05, 03:20 PM posted to rec.aviation.piloting
More likely that a fuel line was not properly safetied or
otherwise failed. Turbine engines have fuel pressures as
high a 1,000 PSI, so the fuel system in the engine is highly
stressed. The fuel supply pumps are high capacity and 50 to
100 PSI, so again, the fuel connections and lines are
stressed.
If there was a fuel leak into the nacelle, wing root area,
any source of ignition could cause an explosion and the
resulting fire would soften the aluminum spar quickly. The
emergency procedure for a fire is to shut off the fuel
valves, but if the failure was between the tank and fuel
tank or the valve was damaged, it might not be possible to
shut the fuel off.
The NTSB is very good at investigating this type of failure,
the will track melted and bent metal, see the pattern of
soot and follow the fractures in the metal.
James H. Macklin
ATP,CFI,A&P
Merry Christmas
Jim Macklin
"Otis Winslow" wrote in message
airframes
Island
them
melted
have
| impact.
| Thanks.
Seaplane Rating Add-On and Seaplane Rental Peter Bauer Piloting 10 May 29th 05 11:53 AM
American Lake SPB Closing C J Campbell Piloting 23 December 27th 04 03:26 PM
Copalis Beach State Airport threatened? C J Campbell Piloting 1 April 14th 04 10:04 PM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
