"Al" wrote in message
news:1135013678.12351f0117238d0d81fe8dc627be130d@r oc.usenetexchange.com... With all of the new EFIS(Electronic flight Instrumentation Systems), has anyone seen one that stores the flight path for replay? It looks like all of the information is there, and this would be a tremendous help in instrument instructing, or even "pattern review". If downloaded to a simulator on a pc, this would be a good help answer post flight review questions. Al CFIAMI Is this what you're looking for? http://www.appareo.com/ -Mike |
![]() "Mike Murdock" wrote in message ... "Al" wrote in message news:1135013678.12351f0117238d0d81fe8dc627be130d@r oc.usenetexchange.com... With all of the new EFIS(Electronic flight Instrumentation Systems), has anyone seen one that stores the flight path for replay? It looks like all of the information is there, and this would be a tremendous help in instrument instructing, or even "pattern review". If downloaded to a simulator on a pc, this would be a good help answer post flight review questions. Al CFIAMI Is this what you're looking for? http://www.appareo.com/ -Mike Yes. The output is exactly what I was thinking of. I was thinking of an output port on the EFIS systems, maybe even including engine or configuration information. Something like a mini flight recorder. I had not considered making it a stand alone unit, but this makes it very flexible. Use it in any aircraft. Use it on models. Use it where no power supply exists, like gliders. Heck, tape it to the side of half pipe bicycle riders. One could use this anywhere things were going to happen quickly, in several dimensions, and you want know what happened. Thanks for the link. How did you learn of this? Al |
Al I saw it at Oshkosh this year. They had a unit connected to a PC. You could pick up the unit and rotate it a few degrees, or translate it a few inches and the PC screen tracked its motion precisely. Very impressive. -Mike |
The Chelton Flight Logic system logs 19 parameters once every second. Data
is in comma-delimited format, and can be transferred to a data card. I don't know if there is some way to represent this information in a pictoral format. Bernie "Mike Murdock" wrote in message ... "Al" wrote in message news:1135013678.12351f0117238d0d81fe8dc627be130d@r oc.usenetexchange.com... With all of the new EFIS(Electronic flight Instrumentation Systems), has anyone seen one that stores the flight path for replay? It looks like all of the information is there, and this would be a tremendous help in instrument instructing, or even "pattern review". If downloaded to a simulator on a pc, this would be a good help answer post flight review questions. Al CFIAMI Is this what you're looking for? http://www.appareo.com/ -Mike |
Comma delimited format [ CSV ] should import into EXCEL and
you could graph it as pie or bar charts. -- James H. Macklin ATP,CFI,A&P "baltobernie" wrote in message news:32htf.359$yW1.158@trnddc05... | The Chelton Flight Logic system logs 19 parameters once every second. Data | is in comma-delimited format, and can be transferred to a data card. I | don't know if there is some way to represent this information in a pictoral | format. | | Bernie | | | "Mike Murdock" wrote in message | ... | "Al" wrote in message | news:1135013678.12351f0117238d0d81fe8dc627be130d@r oc.usenetexchange.com... | With all of the new EFIS(Electronic flight Instrumentation Systems), | has anyone seen one that stores the flight path for replay? It looks like | all of the information is there, and this would be a tremendous help in | instrument instructing, or even "pattern review". If downloaded to a | simulator on a pc, this would be a good help answer post flight review | questions. Al CFIAMI | | Is this what you're looking for? http://www.appareo.com/ | | -Mike | | | |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
CRS: V-22 Osprey Tilt-Rotor Aircraft | Mike | Naval Aviation | 0 | October 14th 05 08:14 PM |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
IGC Bureau announcement - Review of World Record procedures and of legacy types of GNSS Recorders | Ian Strachan | Soaring | 0 | August 29th 04 07:33 PM |
