Javier Henderson wrote:
If I understood the OP correctly, the 747 was starting its takeoff roll as an MD11 landed in front of him. The 747 probably hit the brakes really hard. No, quite certain that that didn't happen. From what I saw, the 747 stood there waiting for the MD-11 to land and exit before taking off. He probably chose to enter the runway because that portion was beyond the threshold. Not sure if I've conveyanced in words correctly here :\ This has happened in the USA though. You may all remember the 737 that landed on top of a Brasilia (or some turboprop) at LAX in the late 80's. Ah, but there's likely a difference here, as I've said above. The aircraft in this instance was holding *beyond* the threshold. Ramapriya |
![]() "Ramapriya" wrote No, quite certain that that didn't happen. From what I saw, the 747 stood there waiting for the MD-11 to land and exit before taking off. He probably chose to enter the runway because that portion was beyond the threshold. Not sure if I've conveyanced in words correctly here :\ I also can not imagine what could cause what you said. You said smoke left the tires of the 747? What would cause tires of a stopped aircraft (just beginning to roll) to smoke? -- Jim in NC |
Morgans wrote:
I also can not imagine what could cause what you said. You said smoke left the tires of the 747? What would cause tires of a stopped aircraft (just beginning to roll) to smoke? Giving it full power before fully releasing the brakes? George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
![]() "George Patterson" wrote in message news:1P4qf.17527$l25.6310@trnddc03... Morgans wrote: I also can not imagine what could cause what you said. You said smoke left the tires of the 747? What would cause tires of a stopped aircraft (just beginning to roll) to smoke? Giving it full power before fully releasing the brakes? Not that it *couldn't* happen, but I think that it is unlikely. Generally, smoke only happens when there is a considerable speed difference between the rubber and the road. If you drag a tire from a standing start, you make a little noise, deposit some rubber (perhaps considerable), but you don't generate enough heat to make smoke. These are my observations, but YMMV. Anyway, I would like to see smoke from extended brake holding while spooling up. I would bet that it would have to drag 10 feet or more, to build up enough heat. It seems more likely, to me, that a little smoke came from the engine going to full power. A little (nah, really big) story along these lines, a long time ago on a 747. I was in "The Ohio State University Marching Band" (TBDBITL) when we went to the 1980 Rose Bowl. With all of the brass instruments, drums, and personal luggage and fuel for that long trip, I have no doubt that we were at, or very near max gross takeoff weight. I don't know how long Port Columbus (Rickenbacker Field) was at the time, but with the weight and size of the aircraft, and the length of the runway, it must have been close to minimum lengths. The pilot went to the departure end, and went down as far as he could before turning around and lining up on the runway centerline. After a brief hold, he spooled up the engines and held brakes for what seemed like *much* longer than usual. I am almost sure that there were some tires sliding. The brakes where finally released, but there was not the usual "kick in the back" acceleration, but we did roll on down the runway, getting airborne at what seemed like the last moment. Trip was completed successfully, but that takeoff was exciting, for sure. It was during the return trip that we dropped suddenly, and kicked sideways at the same time, just as flight attendants were clearing supper trays. I ended up with 5 or so plates held directly over my head, without a morsel spilling on my head. "Good catch, miss, thank you," says I !!! This was after sleeping on the floor of LAX for 5 or 6 hours, after our chartered plane was fogged in at San Francisco. Oh, we lost the game also, and had been up since 4:30 AM, to march in the Rose Bowl Parade. What a day! Sorry for my ramblings. It was a good time. -- Jim in NC |
The Swearingen-TEB incident: control issues with twins | R.L. | Piloting | 72 | June 8th 05 04:08 AM |
British Airways 747 incident on NPR | Ron Garret | Piloting | 3 | March 9th 05 07:38 PM |
Quick question about an incident which happend today | Chris | Piloting | 46 | April 1st 04 04:15 PM |
Bush/Hitler creates another phony "terrorist" incident to suppressus... | Ronald Gardner | Home Built | 4 | December 29th 03 09:19 PM |
Indonesian Bawean Island Incident (2 F-16B vs 5 F/A-18s) | Bram U. Kusuma | Naval Aviation | 6 | September 7th 03 06:06 PM |
