Curious incident :)
Old December 20th 05, 07:03 PM posted to rec.aviation.piloting
Default Curious incident :)
"Ramapriya" wrote in message
Paul Tomblin wrote:
Since when does smoke come of the tires of a plane starting its takeoff
roll? I can't think of any way that could happen.
My thoughts exactly.
Don't know about you but I've seen puffs come off aircraft tires, at
the start of the takeoff roll, often enough; it probably happens when
pilots advance the throttle a bit before releasing the brakes.
I've never seen that, nor even heard of it. The proposed explanation you
suggest certainly wouldn't do it. Smoke comes off the tires during
touchdown because of the speed difference between the tire and the pavement,
until the tire "catches up".
During takeoff, even if the brakes are held, and even if the tires slide a
bit (which is very unlikely...usually the locked wheels can hold the
airplane still), they wouldn't smoke. They'd just rub a bunch of rubber
onto the pavement.
If you saw smoke during the takeoff roll, it came from somewhere other than
the tires.
Pete
Old December 21st 05, 03:28 AM posted to rec.aviation.piloting
Pete
The F-101B had enough engine power that if you held the brakes and ran
up and plugged the burners in it rotated the tires on the rim(s) and
blew them.You could see smoke as they skidded down the R/W.
Technique was to run up to around 80% and check gauges and release
brakes and advance throttle(s) to 100% and plug the burners in.
TOR was less than 1000 feet on a standard day.
Big John
On Tue, 20 Dec 2005 11:03:22 -0800, "Peter Duniho"
roups.com...
onto the pavement.
the tires.
Pete
Old December 21st 05, 04:53 AM posted to rec.aviation.piloting
"Big John" wrote in message
Hardly relevant to the question of what happens at the *very start* of a
takeoff roll of a transport category airplane. Even in the case of the much
higher power-to-weight ratio of the F-101B (or other fighters, for that
matter), the smoke doesn't occur immediately upon power-up.
Pete
Old December 22nd 05, 01:29 AM posted to rec.aviation.piloting
Pete
Paul Tomblin posted:
quote
Since when does smoke come off the tires of a plane starting its
takeoff roll? I can't think of any way that could happen.
unquote
My post was only to show that it could and did happen based on my
experience.
Big John
On Tue, 20 Dec 2005 20:53:41 -0800, "Peter Duniho"
Pete
Old December 22nd 05, 01:59 AM posted to rec.aviation.piloting
experience.
I appreciate your input. Still, the key phrase in Paul's post is "starting
its takeoff roll". Even in your example, there's no suggestion that the
smoke occurs at the START of the takeoff roll, as described by the person
who started this thread.
Pete
Old December 21st 05, 04:21 AM posted to rec.aviation.piloting
onto the pavement.
the tires.
Pete
Could be a terminology error here, Pete
As I stated before, I've often seen puffs from behind tires. In fact,
when seeing aircraft readying for a takeoff from behind a glass pane
between the 5 o'clock and 7 o'clock positions, I look for tire puffs to
know that the craft has begun its roll. It could well be a spray of
water or sand off the tarmac, but I have seen it often, no doubt about
it.
Ramapriya
Old December 21st 05, 04:54 AM posted to rec.aviation.piloting
Well, if you are using the word "smoke" to describe something that is not
actually smoke, I can see how that would be a problem.
Old December 21st 05, 06:41 AM posted to rec.aviation.piloting
Ramapriya wrote:
...when seeing aircraft readying for a takeoff from behind a glass pane
it.
I don't doubt you've seen something. From five- or seven o'clock it
could be dust kicked up by wing-mounted jet intakes that might appear to
come from the main gear. I've watched a lot of large and heavy jet
departures from the number one position and I don't remember seeing
anything that could be interpreted as smoke from the tires under those
circumstances.
Curious, indeed.
Jack
Old December 21st 05, 09:18 AM posted to rec.aviation.piloting
circumstances.
Curious, indeed.
Jack
What began as a question to ascertain the frequency of aircraft landing
from above another has turned (due to my poor verbiage, possibly) to
how smoke emerged from the 747's wheels on takeoff
Is it common to see planes commencing their takeoff roll before a
just-landed aircraft has fully turned off into the exit? That clearly
happened in the incident I wrote about too...
Ramapriya
Old December 21st 05, 09:25 AM posted to rec.aviation.piloting
It happens --- more in some environments than others. Domestic US
operations are pretty standardized now, but there are a lot of
operations in many other parts of the world that would not be acceptable
to the FAA.
Jack
The Swearingen-TEB incident: control issues with twins R.L. Piloting 72 June 8th 05 04:08 AM
British Airways 747 incident on NPR Ron Garret Piloting 3 March 9th 05 07:38 PM
Quick question about an incident which happend today Chris Piloting 46 April 1st 04 04:15 PM
Bush/Hitler creates another phony "terrorist" incident to suppressus... Ronald Gardner Home Built 4 December 29th 03 09:19 PM
Indonesian Bawean Island Incident (2 F-16B vs 5 F/A-18s) Bram U. Kusuma Naval Aviation 6 September 7th 03 06:06 PM
