#31
![]() "Flyingmonk" wrote in message ups.com... Toks wrote: Perfect evidence on why you shouldn't trust media that much! Well, I never really trusted them. Don't trust them if you want, but don't blame them for this one. The infants are not ticketed passengers and therefore are not listed on the manifest given to the media. |
#32
ups.com... I'm wondering if fitting turbine engines on the old airframes didn't pull something loose in the wing/mount. Turbines run a whole lot smoother than the round Pratts that were on originally. They don't have the power pulses that radial engines have. I assume he was referring to the increased thrust that was probably obtained with the turbine installation, which would create higher forces on the structure transmitting that thrust to the airframe. Of course, one would think that in a turbine retro-fit, that structure would be upgraded to compensate. Hopefully, that's not actually the problem. But I don't think Otis was suggesting that turbines would cause more fatigue due to vibration than the original engines. Pete |
#33
with the turbine installation, which would create higher forces on the structure transmitting that thrust to the airframe. I assumed the same. The round Pratts were 550hp engines, and the STC'd PT6A-27 engines are flat-rated to 650hp. While the increased thrust might add stress, my assumption was the weight reduction of the turbines and their much smoother operation might nullify the power increase as it relates to airframe stresses. It seemed a safe assumption that that's what he was suggesting. |
#34
oups.com... I assume he was referring to the increased thrust that was probably obtained with the turbine installation, which would create higher forces on the structure transmitting that thrust to the airframe. I assumed the same. Curious you would introduce "run a whole lot smoother" and "power pulses" then, if you thought those issues weren't relevant. Very odd. Even stranger that those issues were the sum total of your rebuttal to his post. The round Pratts were 550hp engines, and the STC'd PT6A-27 engines are flat-rated to 650hp. While the increased thrust might add stress, my assumption was the weight reduction of the turbines and their much smoother operation might nullify the power increase as it relates to airframe stresses. It seemed a safe assumption that that's what he was suggesting. I don't see how the smoothness of the operation of the engine relates. As far as the weight reduction goes, if anything that would exacerbate the problem, especially if that weight reduction is permitted to be moved over to useful load. A heavier engine will dampen the initial acceleration (a certain amount of the thrust is applied to accelerating the engine, rather than the airframe to which it's attached), while a heavier airframe (ie higher useful load) will allow higher forces to occur during that initial acceleration. Of course, once acceleration is relatively constant, the only real difference is the difference in thrust, but again 100 more hp certainly translates to more acceleration, and thus more force on the airframe. All that said, as I mentioned before, I would expect certification of the engine to take all of that into account. Pete |
#35
One news report was watching last night mentioned 'the NTSB is attempting to
recover the cockpit voice recorder'. Are these small charter lines equipped with those? |
#36
Peter Duniho wrote:
A heavier engine will dampen the initial acceleration (a certain amount of the thrust is applied to accelerating the engine, rather than the airframe to which it's attached), while a heavier airframe (ie higher useful load) will allow higher forces to occur during that initial acceleration. Really? Just how elastic do you think the connections between the airframe and the engine are? When it comes to acceleration, they better form pretty much one piece, don't you think? Gross weight is what we accelerate, not components. Or are you speaking metaphysically? Jack |
#37
FAR 135 and 121 require cockpit voice recorders on turbine
powered aircraft. They are very simple, just a microphone and an armored box. -- James H. Macklin ATP,CFI,A&P "Michael Ware" wrote in message news ![]() NTSB is attempting to | recover the cockpit voice recorder'. Are these small charter lines equipped | with those? | | |
#38
![]() "Jay Honeck" wrote The wing clearly departed the airframe before the crash. I wonder if these old birds are simply fatigued? I wonder about catastrophic unconfined engine failure, severing the spar. There was an account of the sound and sight of an explosion before the wing departed, wasn't there? -- Jim in NC |
#39
then, if you thought those issues weren't relevant. Very odd. Even stranger that those issues were the sum total of your rebuttal to his post Ya got me there Pete... nothing escapes your eagle-eyed gaze, eh? Not really sure where I was going with that. On reflection, Otis' post would suggest the higher power turbine conversion might have have an adverse effect on the old Mallard airframe, even though as you mentioned the STC should include reinforcing mounts, spars etc. to allow for the increased stress on the airframe. If anything, I'd guess the smoother running turbines should stress the airframe less than the throbbing & vibrating radials in spite of their higher power. (Disclaimer: I'm not an engineer, just an aero turbine analyst) |
#40
Jay
A monday morning WAG. Turbine (disk) blew up and destroyed enough of the wing structure that it failed. Fuel tank(s) in wing then dumped fuel on hot parts of turbine and caught fire. Wingless (one wing) fuselage impacted water and broken off wing floated down burning until it hit the water. Lets see if my years of experience with accidents guessed right on this bad accident. Big John `````````````````````````````````````````````````` ````````````` On Tue, 20 Dec 2005 14:08:24 GMT, "Jay Honeck" wrote: My guess is that they had a loose or broken fuel line, caught fire and the fuel vapor exploded and the fire melted the spar enough for it to fail. Boy, I sure hope that's "all" it was. (Who'd ever think we'd be saying that kind of stuff?) With everyone describing an "explosion" (which the video tends to support) -- and Chalk's not having to do much in the way of security screening, as a small carrier -- this could easily have been some kind of a nut-job with a shoe bomb and a "cause". And *then* we'd start seeing all sorts of stupid proposals for "enhanced security" that we don't want or need. Sad to say, a mechanical problem is the best-case scenario. |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Seaplane Rating Add-On and Seaplane Rental | Peter Bauer | Piloting | 10 | May 29th 05 11:53 AM |
American Lake SPB Closing | C J Campbell | Piloting | 23 | December 27th 04 03:26 PM |
Copalis Beach State Airport threatened? | C J Campbell | Piloting | 1 | April 14th 04 10:04 PM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
