On Wed, 21 Dec 2005 23:25:58 GMT, Rich Grise
wrote: On Wed, 21 Dec 2005 14:09:10 -0500, Steve Spence wrote: wrote: George Ghio wrote: Tell us why anyone would modify a sine wave. It's called "engineering," George. Nick Really... Wouldn't they rather modify a square wave to approximate a sine wave? What would be the point of modifying a sine wave, when a sine wave (or close approximation) is the required result? I only am posting this back to RAO as it's the only NG I receive out of the list. I hope you're not serious here. They don't make a sine wave and modify it, they make a rectangular wave and call it a "modified sine wave" because it passes enough tests for harmonics and crap that it will run most stuff, and they can get away with it. ;-) Switching supplies are very efficient. Unfortunately things making sin waves from DC are not. The faster you can turn the transistors on and off the less heat and more power you can get out of a still smaller, lighter, and *cheaper* power supply, or inverter. Without digging too deep, a square wave contains an almost infinite frequency range on the rise and fall times. Most likely many thousands of times higher in frequency than the fundamental square wave. If you poke said square wave with all it's noise into an L/C filter it'll round it off into more of an approximation of a sin wave. You only have to get rid of enough of the spikes/harmonics to keep from confusing what ever you plan on running off the thing. Anybody wanna do an FFT of various duty-cycle waveforms, and give us real THD information, and how that relates to power factor, and etc, and etc, and etc? You want power factor too? Lordy, when I think of the caps we used to switch in on the power mains at work depending on load. I doubt current and voltage were ever in phase. Well, maybe with the exception of the time we fired back up after doing PM on some switch gear and some one had forgotten to remove the jumpers. Boy, but that was noisy! It actually bent the cabinet doors into shallow U-shapes and those things were made of 1/8" thick steel and about 7 or 8 feet tall. The one inverter I've ever had my hands on the guts of made a waveform like this: ---- ---- ---- | | | | | | - - - - - - | | | | | etc. - ---- ---- And the regulator was just based on an ordinary rectifier - they didn't care about RMS, or it was scaled to get "close enough". They were just after "close enough". That's why the 400 watt PS in one computer here weighs about a pound. The 500 watt in two others are about 4# and the 630 is still heavier. BUT the 200 watt PS for my ham rig weighs over 30#. I have a 600 watt (12 VDC @ 50 A) PS under the desk that must weigh about 60 or 70#, None of the computer Power supplies cost much over $50. I think the 400 was about $35. The big one for the ham rig was several hundred dollars. I have seen inverters that did a pretty good job on the output wave form, but they were expensive and not nearly as efficient as the cheap ones as a good portion of their work went into heat. But I do wonder, what does the harmonic content really do when you vary the duty cycle? I would *guess* they would get pretty drastic at some portions depending on just how hard the thing is working. There's not much power in them so I'd expect to see them round off under load, but does the inverter use dynamic filtering or hard filtering? Which is a good way of saying I don't really know. :-)) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Some years ago, in the USAF, I saw some pulses on a spectrum analyzer, and they had some really pretty envelopes. :-) Thanks, Rich |
Question on 172 M electrics... (1974 Skyhawk II) | [email protected] | Piloting | 8 | April 10th 04 04:52 AM |
