Fly wrote:
Before starting the last engine I put together, I borrowed a oil pressure pot to fill the galleys. I did something similar when I replaced the engine in a van I owned long ago. I scavenged an empty freon tank, removed the valve, and poured four quarts of oil into it with a funnel (seemed to take forever). Then I put the valve back in and hooked it up to an air compressor. Once I got it pressurized, I turned it upside down, hooked it up to the hole for the oil pressure sending unit, and opened the valve. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
scavenged an empty freon tank, removed the valve, and poured four quarts of oil into it with a funnel (seemed to take forever). Then I put the valve back in and hooked it up to an air compressor. Once I got it pressurized, I turned it upside down, hooked it up to the hole for the oil pressure sending unit, and opened the valve. Probably think you're clever don't you asshole? |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Chevy LS2 and Trans??? any real issues besides weight | MrV | Home Built | 82 | November 18th 05 03:11 AM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
