#51
![]() "Steven P. McNicoll" wrote in message link.net... None of that matters, all operations are governed by the same order. And subject to local letters of agreement, individual Center policies, etc. For example, several times I have requested a VFR-On-Top altitude assignment in the New York area and I have been told flat out by the controllers that their policies do not permit them to issue such clearances. Similarly, there are areas of the country where as Visual Climb to a new IFR altitude can be a very useful tool, yet in other areas of the country I have again been told flat out that they never issue such clearances. -- Richard Kaplan, CFII www.flyimc.com |
#52
Newps wrote in
news:qpl3c.160015$4o.202529@attbi_s52: No. An approach clearance clears you for any altitude required by the approach, including landing. A visual approach clearance clears you to the ground. In that respect there is no difference between a visual approach and any other type of approach. Yes, the way I said it was redundant. -- Regards, Stan |
#53
![]() "Richard Kaplan" wrote in message s.com... And subject to local letters of agreement, individual Center policies, etc. Please post some of them. |
#54
![]() "Stan Gosnell" me@work wrote in message ... You can descend from 7000' to 3000' whenever you're ready, but you need to report when you do. You would report leaving 7000' Where is it written that any report is needed other than the initial acknowledgment of the pilot discretion clearance? I would maintain that acknowledging the pilot discretion clearance satisfies the requirement to report leaving the altitude. In fact, I have on a number of occasions done just that and not reported to ATC when I began a pilot-discretion descent, with no complaint from anyone. Has anyone here ever acknowledged a pilot discretion clearance and then started a descent at some later point and received a complaint from ATC that a second report was needed prior to beginning a descent? -- -------------------- Richard Kaplan, CFII www.flyimc.com |
#55
![]() wrote in message ... I can certainly descend to an intermediate altitude on a curise clearance, then level off. But, "bob back up?" not me. That is fine if you choose not to do so, but the AIM is very clear that such "bobbing back up" is permissible. -------------------- Richard Kaplan, CFII www.flyimc.com |
#56
I suspect the lack of complaint from ATC is no indication that ATC is pleased with a pilot's behavior. Probably for the same reason that I no longer chastise people for improper pattern behavior: The supply of knuckleheads is inexhaustable, and trying to educate them is like trying to drain the ocean using a thimble. |
#57
![]() "Richard Kaplan" wrote in message s.com... "Stan Gosnell" me@work wrote in message ... You can descend from 7000' to 3000' whenever you're ready, but you need to report when you do. You would report leaving 7000' Where is it written that any report is needed other than the initial acknowledgment of the pilot discretion clearance? I would maintain that acknowledging the pilot discretion clearance satisfies the requirement to report leaving the altitude. In fact, I have on a number of occasions done just that and not reported to ATC when I began a pilot-discretion descent, with no complaint from anyone. Has anyone here ever acknowledged a pilot discretion clearance and then started a descent at some later point and received a complaint from ATC that a second report was needed prior to beginning a descent? -- -------------------- Richard Kaplan, CFII www.flyimc.com No. That is what the black letters all in a row that translate to "pilot discretion" mean. I've done hundreds of them in small aircraft and heavy (450,000+ lbs). |
#58
![]() "Greg Esres" wrote in message ... I suspect the lack of complaint from ATC is no indication that ATC is pleased with a pilot's behavior. Why would that behavior displease ATC? |
#59
![]() No. That is what the black letters all in a row that translate to "pilot discretion" mean. I've done hundreds of them in small aircraft and heavy (450,000+ lbs). I have a similar background. When I was flying the air carrier aircraft, the company I worked for had as policy that its crews would report leaving a previously assigned altitude, whether PD or not. There reasoning was it removed any possibility of ambiguity. When there are two options, and there is any doubt as to which is right (or wrong) exercise the option that has the least cost if wrong. |
#60
![]() wrote in message ... I have a similar background. When I was flying the air carrier aircraft, the company I worked for had as policy that its crews would report leaving a previously assigned altitude, whether PD or not. There reasoning was it removed any possibility of ambiguity. Where was ambiguity possible? When there are two options, and there is any doubt as to which is right (or wrong) exercise the option that has the least cost if wrong. What is the cost? |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
ALTRAK pitch system flight report | optics student | Home Built | 2 | September 21st 03 11:49 PM |
