..Blueskies. wrote:
"Lou" wrote in message oups.com... So, let me get this right, acid bad Alodine good. Alodine is acid - chromic acid. I hear the confusion, Lou. Yes, alodine is also acid, but what your doing is using the acid in a CONTROLLED environment. You put the piece in the alodine bath for only a short time. Leaving it there for extended periods IS bad. It'll eat your part up. After you get the surface coated with a good layer of whatever chromium compound it is that the alodine leaves behind, you pull it out of the solution and wash it with clean water. As soon as it is good and dry, you put a coat of primer on it. The post about bases is spot on, except that you don't find them in the air much. Most of the acid in the rain is put there either by burning coal or diesel fuel. As Morgans pointed out, the air around diesel driven air carriers has given the Navy fits for decades. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Mercury another threat to aviation security? | Aviv Hod | Piloting | 2 | October 7th 04 06:24 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
