Dan Truesdell wrote
My view is that currency is not just about time and numbers, but rather is about are your skills current and safe for a foray into the clouds. I agree - which is why I feel the discussions about what meets the minimum definition of 6 approaches is silly. But when it comes to holds, I take a somewhat different view. In my opinion, the only holds that really matter are the ones where a hold is done in lieu of PT for course reversal. Those must be flown competently if one is to become adequately established on the FAC. All other holds are just a way of being in some defined chunk of airspace until it's time to do something different. Taking a few trips around a hold, especially on a day with a bit of wind, takes very little time, and will sharpen your skills to the point of not just meeting the regs, but goes a long way in making you really "current". The skill you need to sharpen is being established on the holding course before you cross the holding fix. Realistically, anyone flying anything that goes fast enough that remaining in the protected airspace is an issue is getting regular recurrent sim training anyway - for our purposes, as long as you can get yourself established on the inbound course before you cross the holding fix, you're good to go. Going around the hold multiple times is pretty much a waste of time. If you made a good entry - meaning you were properly established on the inbound course before crossing the fix - call it good. If not, exit the hold and do it again. The hot tip is to simply combine this with shooting approaches - use a hold in lieu of PT to do the course reversal whether it's charted that way or not. Recall that a charted PT allows you to reverse course in any way you like as long as you're on the protected side, so this is legal. It will also make it really obvious whether you did a decent enough job in the hold - because if you didn't, you will hose the approach. Michael |
Battery Requirements | jgarner | Home Built | 3 | March 28th 04 06:32 AM |
Alternate requirements | Anthony Chambers | Instrument Flight Rules | 8 | September 17th 03 09:45 PM |
