Needing some high-strength 7/16ths bolts, over the holidays I visited
one of the unofficial RV assembly plants here in San Diego county. Located in an industrial park adjacent to the airport, the fellow has set-up permanent fixtures just like a real aircraft factory, allowing him to assemble an RV with perfect accuracy in remarkably little time. RV's use NAS bolts to hold the wings on and I'd come a'begging. He had a new helper, a guy about my age. He was over at the leading-edge fixture, struggling to install a cleco. From his body language I guessed the thing was bent. I would have tossed it but he kept wrestling with it, finally got it in and went on to the next. But damned if he didn't do the same thing. I found my friend in his cubby hole, told him what I was after, showed him what I had to trade. He poked around in his cabinets, found what I needed and gave me four. Looking past me he saw the fellow working on the leading edge. Heaved a big sigh and shook his head. The guy was struggling with yet another cleco. "Somebody bend all your clecos?" I asked. My friend gave a bark of laughter. "There's nothing wrong with the clecos," he said shaking his head. We both watched the guy. He finally got it in, flexed his hand and started doing an other in the same awkward manner. We watched him put in three then the fellow must of sensed he was being watched because he looked up. "He doesn't know how to cleco," I said in surprise. "Yeah," my friend agreed. He told me how the fellow was ex-military, had his ticket and a zillion years experience. "But nobody ever showed him how to set a cleco," he sighed. I tucked my bolts in my pocket and got the hell outta there, not wanting to be around when my friend, who was never in the military and isn't an A&P, tried to explain to a card-carrying sixty year old A&P that he doesn't know how to cleco. - - - - - - - - - - - - - - - - - - I can't remember how old I was when my dad let me help him rivet. About nine, I think. Unless you're using PK's, knowing how to cleco is a required part of knowing how to rivet. Clecos are spring-loaded temporary fasteners. They get inserted through the hole where the rivet goes and serve to hold the parts in alignment for drilling and riveting. Once everything is aligned, you set rivets in the holes between the clecos, then remove the clecos and set a rivet in that hole too. The cleco is installed and removed with a pair of special pliers referred to as forceps in the trade. Because of the spring, it takes a certain amount of strength to use them. But not much, as shown by Rosy the Riveter and her million sisters. To use clecos, you insert the tang into the hole, press the cleco flush against the visible part then squeeze the handles whilst maintaining a moderate amount of pressure on the cleco. The pair of shaped wires are squeezed past the tang and through the hole in the INVISIBLE part with a slight click, telling you it's okay to relax your grip and go on to the next one. Doing a panel, you'll have a handful of clecos in one hand, the forceps in the other, shooting a cleco into every third or fourth hole at the rate of about one every five seconds or less. Do it right, it takes just that one, quick squeeze. Since you aren't trying to hold the cleco compressed, and since you only have to compress it far enough to let the shaped wires through the hole, it doesn't take a lot of strength - - even a kid can do it. What the fellow at the RV factory was doing was putting a cleco into the forceps then squeezing until the locking wires were fully extended. Holding it with the spring fully compressed, he was trying to fly the pair of locking wires through the hole in the two layers of metal, which he eventually did. But he was spending a minute or more per cleco. In the time he took to do one row a real tin-bender would have secured the entire panel. - - - - - - - - - - - - - - - - - - - - - - - - - - - - - I've reached an age where I'm no longer surprised at the things people don't know but should. My visit to the RV factory showed me yet another reason why some folks think riveting is hard. And why others take years to complete a six-month project. -R.S.Hoover PS - PK's are hex-head sheet-metal screws fitted with a non-marring washer. That what we used before clecos came along. |
"Bret Ludwig" wrote in message
oups.com... Dick van Grunsven knows this is going on. He knows it isn't really right. but I don't blame Dick even though he is becoming a multimillionaire from this scam. I blame the FAA. Plonk! Rich S. |
Thanks again Hoover.
Hoover, Do I have to 'smooth out' the hole after removing the PK's before putting in the rivets? I'd think that the various 'cuts' in the material due to the PK's might be a good starting point for a crack/rip to develope. The Monk |
"Forceps"???...what the hell are "FORCEPS"???
I been in the "trade" for 30 years and I never heard of nuttin called forceps!!!...that had anything to do with cleco's... ....wait a minute. You talkin' 'bout Cleco pliers???...you know... the cleco pliers you put the cleco's in with...that wut your callin a "forcep"? Ohhhh...I admit...ahm' a little slow on them big wurds. Dr. Dave (in his "other" trade) :-) wrote in message oups.com... Needing some high-strength 7/16ths bolts, over the holidays I visited one of the unofficial RV assembly plants here in San Diego county. Located in an industrial park adjacent to the airport, the fellow has set-up permanent fixtures just like a real aircraft factory, allowing him to assemble an RV with perfect accuracy in remarkably little time. RV's use NAS bolts to hold the wings on and I'd come a'begging. He had a new helper, a guy about my age. He was over at the leading-edge fixture, struggling to install a cleco. From his body language I guessed the thing was bent. I would have tossed it but he kept wrestling with it, finally got it in and went on to the next. But damned if he didn't do the same thing. I found my friend in his cubby hole, told him what I was after, showed him what I had to trade. He poked around in his cabinets, found what I needed and gave me four. Looking past me he saw the fellow working on the leading edge. Heaved a big sigh and shook his head. The guy was struggling with yet another cleco. "Somebody bend all your clecos?" I asked. My friend gave a bark of laughter. "There's nothing wrong with the clecos," he said shaking his head. We both watched the guy. He finally got it in, flexed his hand and started doing an other in the same awkward manner. We watched him put in three then the fellow must of sensed he was being watched because he looked up. "He doesn't know how to cleco," I said in surprise. "Yeah," my friend agreed. He told me how the fellow was ex-military, had his ticket and a zillion years experience. "But nobody ever showed him how to set a cleco," he sighed. I tucked my bolts in my pocket and got the hell outta there, not wanting to be around when my friend, who was never in the military and isn't an A&P, tried to explain to a card-carrying sixty year old A&P that he doesn't know how to cleco. - - - - - - - - - - - - - - - - - - I can't remember how old I was when my dad let me help him rivet. About nine, I think. Unless you're using PK's, knowing how to cleco is a required part of knowing how to rivet. Clecos are spring-loaded temporary fasteners. They get inserted through the hole where the rivet goes and serve to hold the parts in alignment for drilling and riveting. Once everything is aligned, you set rivets in the holes between the clecos, then remove the clecos and set a rivet in that hole too. The cleco is installed and removed with a pair of special pliers referred to as forceps in the trade. Because of the spring, it takes a certain amount of strength to use them. But not much, as shown by Rosy the Riveter and her million sisters. To use clecos, you insert the tang into the hole, press the cleco flush against the visible part then squeeze the handles whilst maintaining a moderate amount of pressure on the cleco. The pair of shaped wires are squeezed past the tang and through the hole in the INVISIBLE part with a slight click, telling you it's okay to relax your grip and go on to the next one. Doing a panel, you'll have a handful of clecos in one hand, the forceps in the other, shooting a cleco into every third or fourth hole at the rate of about one every five seconds or less. Do it right, it takes just that one, quick squeeze. Since you aren't trying to hold the cleco compressed, and since you only have to compress it far enough to let the shaped wires through the hole, it doesn't take a lot of strength - - even a kid can do it. What the fellow at the RV factory was doing was putting a cleco into the forceps then squeezing until the locking wires were fully extended. Holding it with the spring fully compressed, he was trying to fly the pair of locking wires through the hole in the two layers of metal, which he eventually did. But he was spending a minute or more per cleco. In the time he took to do one row a real tin-bender would have secured the entire panel. - - - - - - - - - - - - - - - - - - - - - - - - - - - - - I've reached an age where I'm no longer surprised at the things people don't know but should. My visit to the RV factory showed me yet another reason why some folks think riveting is hard. And why others take years to complete a six-month project. -R.S.Hoover PS - PK's are hex-head sheet-metal screws fitted with a non-marring washer. That what we used before clecos came along. |
![]() D.Reid wrote: "Forceps"???...what the hell are "FORCEPS"??? I been in the "trade" for 30 years and I never heard of nuttin called forceps!!!...that had anything to do with cleco's... I'm willing to wager that you were never in the Navy. I know Bob was & I have heard other Navy guys call them forceps. Different lingo in different circles. Given theat the tool isn't used to ply anything, forceps might even be a more accurate term. Sorry that the world doesn't conform to your expectations. Daniel |
oups.com... D.Reid wrote: "Forceps"???...what the hell are "FORCEPS"??? I been in the "trade" for 30 years and I never heard of nuttin called forceps!!!...that had anything to do with cleco's... I'm willing to wager that you were never in the Navy. I know Bob was & I have heard other Navy guys call them forceps. Different lingo in different circles. Given theat the tool isn't used to ply anything, forceps might even be a more accurate term. Sorry that the world doesn't conform to your expectations. Daniel If someone at work ask to borrow my forceps, he or she would get a deer in the headlight look. However, third drawer down on the right is my CLECO pliers. Oh yeah, 23 years in the NAVY. |
