Dawley Aviation PIREP, or: Atlas is BACK
Old January 2nd 06, 03:09 PM posted to rec.aviation.owning
Default Dawley Aviation PIREP, or: Atlas is BACK
"Matt Barrow" wrote in message
Jay is merely parroting the OWT and misinformation that has been running
around out there for _years_.
Jay quotes an expert in the field and you accuse him of parroting
misinformation? LOP is good when properly done, but I think the statement
from Dawley says it is NOT being properly done for the most part. The
company I work for overhauls 400+ aircraft engines a year. Our teardown
shop can tell you which ones have been ran LOP and which have not.
Allen
Old January 2nd 06, 03:13 PM posted to rec.aviation.owning
"A. Smith" wrote in message
. net...
misinformation?
And expert on...what?
LOP is good when properly done, but I think the statement from Dawley says
it is NOT being properly done for the most part. The company I work for
overhauls 400+ aircraft engines a year. Our teardown shop can tell you
Really? How?
Old January 2nd 06, 03:30 PM posted to rec.aviation.owning
. net...
misinformation?
An expert on repairing aircraft exhaust. Isn't that what Dawley does?
says it is NOT being properly done for the most part. The company I work
for overhauls 400+ aircraft engines a year. Our teardown shop can tell
Really? How?
I suggest that if you are really interested in this you get with Lycoming or
TCM and see what they suggest for your engine. There are only a handful of
engines that were designed to be ran LOP.
Old January 2nd 06, 03:53 PM posted to rec.aviation.owning
y.net...
misinformation?
Really? How?
How do you design an engine to run LOP?
Matt
Old January 2nd 06, 11:43 PM posted to rec.aviation.owning
"Matt Whiting" wrote in message
Matt
Compression ratio, cumbustion chamber shape, valve placement, valve
material, crankshaft counterweight design...............................
Old January 3rd 06, 12:25 AM posted to rec.aviation.owning
Matt
Example?
Matt
Old January 3rd 06, 01:40 AM posted to rec.aviation.owning
Example?
The original Continental in the original Malibu.
Old January 3rd 06, 01:52 PM posted to rec.aviation.owning
A. Smith wrote:
Really? How?
or TCM and see what they suggest for your engine. There are only a
handful of engines that were designed to be ran LOP.
So much for "expertise".
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old January 2nd 06, 03:52 PM posted to rec.aviation.owning
I think the point is that it is the temperatue seen by the exhaust pipe
that matters, not whether it is LOP or ROP. And the temps mentioned by
Mr. Dawley sound more like runnint at peak, rather than either side.
People seem to automatically blame running on the lead side and that
simply isn't supported by the data. It is an old wives tale pure and
simple.
Matt
statement from Dawley says it is NOT being properly done for the most
part. The company I work for overhauls 400+ aircraft engines a year.
Our teardown shop can tell you which ones have been ran LOP and which
have not.
simple.
Matt
Which is my point, people think they know how to run LOP but actually are
running at peak, causing damage. The guy at Dawley didn't say running LOP
did the damage, just that when the LOP operation began being pushed is when
the damage started showing up.
Allen
Prairie Aviation Museum PIREP Jay Honeck Piloting 6 October 19th 05 09:18 PM
Atlas Air N-522-MC will be back into LUX. ellx Instrument Flight Rules 0 January 4th 05 07:47 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 10:43 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 04:02 PM
