On Tue, 03 Jan 2006 02:14:09 GMT, Jose
wrote: Anyway. Imagine. There you are under your panel trying to solder a wire to a lug. You hold the wire firmly in place with your left hand and manipulate the soldering iron into position with your right hand. Wiggle things around to keep the little red light on. When the joint gets hot, you apply the solder with your third hand. And this differs from regular soldering how? With the soldering gun you are far more likely to be injured from a burn. With this device you are far more likely to be injured from the chain reaction of 1. Getting frustrated, 2. Getting ****ed!, 3. Throwing something due to item #2, 4. Hitting hand/fingers while in act of throwing, 5. Hitting head on underside of panel hard enough to require stitches while instinctively raising up to cuss at full volume in reaction to hand damage, 6. Damage to back requiring more stitches, caused while flailing about trying to get out from under panel with precious bodily fluids running in eyes from step 5 caused by step 4 caused by step 3 caused by step 2 which came from step one, which was due to being too cheap the hire someone qualified to do the job in the first place. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com ![]() |
![]() With the soldering gun you are far more likely to be injured from a burn. With this device you are far more likely to be injured from the chain reaction of 1. Getting frustrated, 2. Getting ****ed!, 3. Throwing something due to item #2, 4. Hitting hand/fingers while in act of throwing, As a lad I worked part time at a TV repair shop (they were cost effective to repair at one time ![]() CRTs and power supplies were to the hands; often resulting in broken bones and bad cuts. "How does shock cause that?" I asked. "Oh, it's not the shock - that's usually harmless. It's your reaction causing you to slam your hand on sharp objects." |
Don't forget to stop by your hospital & donate some blood folks. | Flyingmonk | Piloting | 30 | September 10th 05 03:52 AM |
Lucky folks | David Lesher | Owning | 9 | August 5th 05 02:11 PM |
Attention P4M-1Q folks | JJ McIntyre | Naval Aviation | 0 | June 4th 04 09:51 PM |
Thanks for your help, folks! | Jay Honeck | Piloting | 2 | July 16th 03 05:32 PM |
