Prop Indexing
Old January 3rd 06, 04:10 AM posted to rec.aviation.owning,rec.aviation.piloting
Default Prop Indexing
Why are fixed-pitch props on PA-28s indexed to the 10-4 position from
the front?
a) To help hand propping?
b) To minimize vibration?
c) To improve performance?
My money is on (a) but others disagree.
Old January 3rd 06, 04:33 AM posted to rec.aviation.owning,rec.aviation.piloting
Airplanes without starters have the prop indexed for hand
propping, engines with starters have the blades on a two
bladed prop aligned with the crank throw.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Mike Granby" wrote in message
position from
| the front?
Old January 3rd 06, 02:59 PM posted to rec.aviation.owning,rec.aviation.piloting
Jim, we learn something every day !
Is there a reason that the 2 blade prop is aligned with the crank throws ?
Roy
N5804F Piper Archer
"I have had some bad landings but I have never missed the runway"
"Jim Macklin" wrote in message
news:y9nuf.38976$QW2.20013@dukeread08...
James H. Macklin
ATP,CFI,A&P
some support
position from
| the front?
Old January 3rd 06, 03:11 PM posted to rec.aviation.owning,rec.aviation.piloting
I recall something about harmonics and power pulses. For
hand propping, the blade angle should be such that you bring
the piston to TDC with the blade above the shoulder so you
can pull it through as you step back, when hand propping a
plane with a starter, the piston is at TDC with the blade
angle lower and the person is more likely to be in a
position to fall into the prop rotational plane.
Of course, I could have made it all up or simply remembered
some details, IF I cared I'd look up the answer in one or
more texts/web pages from a reliable source.
James H. Macklin
ATP,CFI,A&P
some support
"Roy Page"
ink.net...
the crank throws ?
| Roy
| N5804F Piper Archer
runway"
| "Jim Macklin" wrote
in message
hand
| James H. Macklin
| ATP,CFI,A&P
| some support
duties.
10-4
| position from
| | the front?
Old January 3rd 06, 03:46 PM posted to rec.aviation.owning,rec.aviation.piloting
I was in a 172M club that had a bad first order shake appear after an
engine overhaul. It turned out the prop had to be indexed to 45
degrees @ TDC to get rid of it. The orientation requirements are in
the Cessna manual, but there is no explanation.
As an ME with some background in dynamics, this is the only reason I
can see for this:
All 4 cylinder horizontally opposed engines with offset (in contrast to
directly opposite) cylinders will have a second harmonic yaw motion
about their CG due to the short connecting rods. Without a double
crank speed counterbalance shaft system, there is no way to eliminate
this. This causes a yaw vibration or swinging of the engine at 80 Hz
at 2400 rpm for example. I think it is also the reason the vibration
environment on the front of a Lycoming engine is so severe.
A two blade propeller has to present the same yawing moment of inertia
in response to the 80 Hz engine swing. It can do so only if it is
phased such that it is oriented 45 degrees to the plane of the crank
throws.
If it is phased in the plane of the crank throws, the engine swinging
will present different yaw inertias to alternating second harmonic
inputs ( i. e. every other one), causing a first order response of the
system. This first order response will appear as a shake at crankshaft
frequency.
This would not be a problem we had three blade propellers, or 6
cylinder engines.
Anybody want to challenge this? I'd be interested in further
discussions on this topic
Old January 3rd 06, 03:54 PM posted to rec.aviation.owning,rec.aviation.piloting
Some do, some don't. A four-cylinder engine will stop with all of the pistons
very close to half-way down the bores. If the prop is aligned with the crank
throw, it will stop in a vertical position. My Maule did this, my C150 did not.
It is not possible to align a two-bladed prop with all the crank throws of a six
cylinder engine.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old January 3rd 06, 04:11 PM posted to rec.aviation.owning,rec.aviation.piloting
This is a very interesting discussion.
I have never had my prop off the Archer.
Is it possible to fit a prop on a PA28 indexed incorrectly or is there a
definite radial locator ?
Roy
N5804F Piper Archer
"I have had some bad landings but I have never missed the runway .... yet"
"George Patterson" wrote in message
news:37xuf.19929$z45.8314@trnddc02...
Jim Macklin wrote:
Airplanes without starters have the prop indexed for hand propping,
engines with starters have the blades on a two bladed prop aligned with
the crank throw.
pistons very close to half-way down the bores. If the prop is aligned with
the crank throw, it will stop in a vertical position. My Maule did this,
my C150 did not.
a six cylinder engine.
George Patterson
Old January 3rd 06, 06:33 PM posted to rec.aviation.owning,rec.aviation.piloting
not.
of a six
cylinder engine.
My 172M (a different one from my earlier posting) stops with the prop
@ 45 degrees, and is at TDC @ 135 degrees.
I don't think a 6 cyl engine has any reason to be sensitive to prop
orientation when it comes to smooth operation, although I can
appreciate that they might for some other unknown reason.
Old January 3rd 06, 08:37 PM posted to rec.aviation.owning,rec.aviation.piloting
Me, too! My original post came as a result of a discussion I'm having
elsewhere. My assertion was that since most service manuals specify
10-4 as the right position, they are simply repeating "old lore" with
respect to hand propping. My interlocutor feels that whatever the
manual specifies is as a result of wanting to get the best performance
from the airplane. My response to this is that performance won't be
impacted, and that if anything, vibration would be the other issue, but
that this would be better addressed with a 12-6 positioning.
Old January 3rd 06, 11:50 PM posted to rec.aviation.owning,rec.aviation.piloting
Sorry guys -
In reflecting my earlier post, I now think my earlier reasoning is
invalid. Yes there is a second harmonic (80 Hz) yaw moment generated
within the engine, but the rotating propeller will also change the
reflected yaw inertia at 80 Hz.
Therefore, now I don't see how this coupling could make a 40 Hz shake.
Can somebody shed some more light on this? I know the orientation is
critical on a 172M, and I've seen a couple of homebuilts that had
similar prop orientation problems too.
Prop Indexing Mike Granby Piloting 10 January 9th 06 06:46 PM
Prop Indexing Mike Granby Owning 10 January 9th 06 06:46 PM
Prop Indexing Mike Granby Piloting 15 January 8th 06 04:46 PM
Why does a prop ice up so apparently readily? Mike Rapoport Piloting 2 November 8th 05 02:52 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
