Aspen at night
Old January 3rd 06, 03:52 PM
clipclip clipclip is offline
Junior Member
First recorded activity by AviationBanter: Nov 2005
Quote:
Originally Posted by Ron Garret
In article N9luf.38962$QW2.6921@dukeread08,
"Jim Macklin" wrote:
Private non-published approach.
Cool. How do I get me one of those?
rg
it's not hard. all it takes is $75-150G's of loose change available to burn rather quickly. then you hire a consulting firm specialised in approaches to draw one up and with minimums tailored to your specific on board equipment and flight crew experience levels (and hope that the minimums are not so high that they're actually useful). then you submit about 50 pounds of paper adorned with letters, numbers and pictures arranged in nice color coordinated patters to the FAA, convince them that you've met all the requirements, fly it a few times with an approved FAA rep, and wallah! you (and your co-pilot) can now take your FLIR equipped G5 in at night.
frank
Old January 3rd 06, 06:26 PM posted to rec.aviation.ifr
Default Aspen at night
Of course someone fails to see the humor in my post which was in
response to the humor of the prior poster (no smiley needed to detect
sarcasm)
Ron Lee
You design an approach, have special equipment and training,
have the FAA flight check the approach. You do not just
look at a sectional and make up something.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Ron Lee" wrote in message
| "Jim Macklin"
| You look at a sectional of that area and plot a course.
Input
| appropriate points into your GPS unit flight plan. With
each point is
| an associated minimum altitude. Flight check in VFR
conditions before
| use. Verify that you won't kill anyone on the ground if
off course.
| Don't carry passengers when in IMC conditions flying the
approach. Of
| course this would be "illegal."
| I just read the full narrative of the screwup (accident).
I missed
| where they went wrong. Since they impacted short of the
runway I
| would have to assume that they went below MDA too soon.
However it
| seemed like they were saying they had the airport in
sight.
| Ron Lee
Old January 3rd 06, 07:50 PM posted to rec.aviation.ifr
Ron Lee wrote:
Since they impacted short of the runway I
would have to assume that they went below MDA too soon. However it
seemed like they were saying they had the airport in sight.
I recall reading that the pilots never really positively sighted the
runway. Instead, the cockpit voice recorder captured the pilots speaking
in an uncertain tone that they thought they saw it.
Peter
Old January 3rd 06, 08:25 PM posted to rec.aviation.ifr
"Ron Lee" wrote in message ...
I just read the full narrative of the screwup (accident). I missed
where they went wrong. Since they impacted short of the runway I
Ron Lee
The MDA at KASE is more than 2000 feet above the airport surface.
I wouldn't simplistically blame descending "below MDA too soon".
I think there probably was more to it than that.
I've flown approaches into Aspen several times, and they're not easy.
All of the approaches to KASE follow the Roaring Fork valley upstream.
I can definitely assure you that it gets dark early in the Aspen Valley,
and also that the final descent is very steep.
A complicating feature is the upsloping runway 15, which can give the
visual illusion to the pilot of seeming to be higher than actual.
Not only that, but also the 7000-foot runway is only 100 feet wide.
That can further aggravate the tendency to feel too high on final.
Under marginal visual conditions, it would be quite easy to drop too low
into the river valley, lose visual contact with the runway lights,
and then impact the highway on the high southwest bank of the river,
a fraction of a mile short of the runway.
There's good cause for that note on the KASE Airport chart which reads:
"Operations during periods of reduced visibility discouraged
for pilots unfamiliar with area."
Old January 3rd 06, 10:29 PM posted to rec.aviation.ifr
They saw the freeway and thought it was the runway as I recall. They
got off the gauges too soon. A mistake most of us have made at least
once in our career (not the aiming for the highway part, the getting
off the gauges too soon part). For part 135 IFR operations one pilot is
required to stay on the guages while the other pilot is allowed to look
outside for a positive ID on the airport. Not a good thing when both
start looking outside.
-Robert
Old January 3rd 06, 11:05 PM posted to rec.aviation.ifr
I've been talking with a number of aircraft accident
investigators who have found the homemade approach in the
cockpit that led directly to the accident.
Don't find that much humor in giving instruction for
suicide.
James H. Macklin
ATP,CFI,A&P
some support
was in
needed to detect
| sarcasm)
| Ron Lee
| "Jim Macklin"
training,
| James H. Macklin
| ATP,CFI,A&P
| some support
duties.
| | "Jim Macklin"
| Input
With
| each point is
| conditions before
if
| off course.
| approach. Of
(accident).
| I missed
| runway I
| However it
| sight.
| | Ron Lee
Old January 4th 06, 02:12 AM posted to rec.aviation.ifr
You look at a sectional of that area and plot a course. Input
appropriate points into your GPS unit flight plan. With each point is
an associated minimum altitude. Flight check in VFR conditions before
use. Verify that you won't kill anyone on the ground if off course.
Don't carry passengers when in IMC conditions flying the approach. Of
Nor to mention the topographical resolution of a sectional doesn't quite
cut it.
Old January 4th 06, 02:13 AM posted to rec.aviation.ifr
Before the FAA will flight-check the approach, they will examine every
bit of your design's obstacle clearance, which they well should.
....especially at Aspen....
Old January 4th 06, 02:18 AM posted to rec.aviation.ifr
rg
frank
I like your spin. ;-)
Actually, NetJets has been trying for about three years to get an RNP
advanced procedure into ASE. Their approach path is great, but the
missed approach requires sterling, uninterrupted climb performance.
And, even as good as their concept is, once you get below MDA (or
perhaps DA) and get further behind, missed approach wise, at ASE you are
screw blue missing in a balked landing scenerio.
ASE simply should not be an IFR airport, politics aside.
Old January 4th 06, 02:47 AM posted to rec.aviation.ifr
An AV-8B should have no real problem, if the engine works.
some support
news:VeGuf.5672$V.531@fed1read04...
| clipclip wrote:
| "Jim Macklin"
| rg
change available to
specialised in
your specific
(and hope that the
then you submit
and pictures
convince them
with an
can now take your
| frank
get an RNP
great, but the
performance.
MDA (or
at ASE you are
FAA PPL night flight requirement - does it have to be DUAL? Peter Clark Piloting 21 January 6th 05 12:38 AM
Night solo XC? G. Burkhart Piloting 51 October 14th 04 03:11 PM
Night of the bombers - the most daring special mission of Finnishbombers in WW2 Jukka O. Kauppinen Military Aviation 4 March 22nd 04 11:19 PM
