G1000 Check out
Old January 3rd 06, 04:46 PM posted to rec.aviation.piloting
Default G1000 Check out
The diesels cost significantly more money to buy and the fuel isn't that much cheaper than gasoline.
but isn't the engine lighter, leading to more payload?
Jose
You can choose whom to befriend, but you cannot choose whom to love.
Old January 4th 06, 04:47 PM posted to rec.aviation.piloting
Jose,
Nope.
Thomas Borchert (EDDH)
Old January 4th 06, 04:55 PM posted to rec.aviation.piloting
Nope.
Is the fuel lighter, or does it use less fuel per mile or per hour (for
the same power)? I seem to remember two things about considering a
diesel conversion for our Dakota - that the engine would need to be
moved far forward to preserve CG, and that because of performance, we'd
get more range.
Jose
Old January 5th 06, 03:06 PM posted to rec.aviation.piloting
Jose,
the same power)?
Diesel has more energy per weight than Avgas. And the modern diesel
engines use less fuel for the same power. Much less. But the engines, at
least the ones certificated, are not lighter. Some are heavier than
comparable Avgas engines.
Old January 5th 06, 04:06 PM posted to rec.aviation.piloting
Thomas Borchert wrote:
Jose,
the same power)?
The thermal energy per weight unit is roughly the same for
all hydro-carbon liquids, AVGAS and JET-A1 (used by aviation
diesels) included.
What makes for the better fuel economy of a Diesel engine (compared
to the gasoline engine Otto process) is from two sources:
- the greater compression ratio makes an ideal thermal
engine (Carnot process) work with better efficiency,
- the long combustion in a Diesel engine makes the process
approximate the ideal process better (constant pressure).
Tauno Voipio
tauno voipio (at) iki fi
Old January 6th 06, 01:03 AM posted to rec.aviation.piloting
It can be argued that an aviation diesel can be much smaller than an
aviation gas engine, displacement wise, and still perform the same. The
superior torque of a diesel, plus the longer duration of the power stroke
just seems to turn a prop better. Thus, you can come closer with the weight
comparison.
Jim in NC
Fuel selector or two check valves? Rob Turk Home Built 13 July 1st 05 12:21 AM
Changes in Instrument Proficiency Check Requirements Richard Kaplan Instrument Flight Rules 71 June 10th 04 08:02 PM
Use of hand-held GPS on FAA check ride Barry Rotorcraft 1 August 30th 03 01:24 AM
Use of hand-held GPS on FAA check ride Barry Piloting 3 August 9th 03 10:14 PM
Use of hand-held GPS on FAA check ride Barry Instrument Flight Rules 1 August 9th 03 09:25 PM
