"M. J. Powell" wrote
Is TACAN still in use? I worked on it briefly in 1956 when I was in the RAF. Of course. TACAN was developed by the US Navy for use on its aircraft carriers, the bearing component of VOR being too large for shipboard use. Nothing has changed. Bob Moore |
In message , Bob Moore
writes "M. J. Powell" wrote Is TACAN still in use? I worked on it briefly in 1956 when I was in the RAF. Of course. TACAN was developed by the US Navy for use on its aircraft carriers, the bearing component of VOR being too large for shipboard use. Nothing has changed. Except ICs instead of valves? Right. Thank you. Mike -- M.J.Powell |
Except ICs instead of valves? It wasn't the size of the electronics, but rather the large antenna array required of the VOR system. A VOR antenna must be permanently aligned to the earth, something not possible with such a large array onboard a ship. The TACAN system operating on a different principle than VOR solved the size and alignment problems. Bob Moore |
Bob Moore wrote:
"M. J. Powell" wrote Except ICs instead of valves? It wasn't the size of the electronics, but rather the large antenna array required of the VOR system. A VOR antenna must be permanently aligned to the earth, something not possible with such a large array onboard a ship. The TACAN system operating on a different principle than VOR solved the size and alignment problems. Bob Moore Can you either explain how a TACAN works or provide a reference? Thanks. |
In message , Stubby
writes Bob Moore wrote: "M. J. Powell" wrote Except ICs instead of valves? It wasn't the size of the electronics, but rather the large antenna array required of the VOR system. A VOR antenna must be permanently aligned to the earth, something not possible with such a large array onboard a ship. The TACAN system operating on a different principle than VOR solved the size and alignment problems. Bob Moore Can you either explain how a TACAN works or provide a reference? Thanks. I can't, sorry. I've long forgotten it. Even though I was supposed to write the Vol 1 for the RAF. After a fortnight they posted me! Mike -- M.J.Powell |
![]() "Stubby" wrote in message . .. Bob Moore wrote: "M. J. Powell" wrote Except ICs instead of valves? It wasn't the size of the electronics, but rather the large antenna array required of the VOR system. A VOR antenna must be permanently aligned to the earth, something not possible with such a large array onboard a ship. The TACAN system operating on a different principle than VOR solved the size and alignment problems. Bob Moore Can you either explain how a TACAN works or provide a reference? Thanks. There's a nice writeup at http://www.radarpages.co.uk/mob/nava...can/tacan1.htm Keith |
Keith W wrote:
"Stubby" wrote in message . .. Bob Moore wrote: "M. J. Powell" wrote Except ICs instead of valves? It wasn't the size of the electronics, but rather the large antenna array required of the VOR system. A VOR antenna must be permanently aligned to the earth, something not possible with such a large array onboard a ship. The TACAN system operating on a different principle than VOR solved the size and alignment problems. Bob Moore Can you either explain how a TACAN works or provide a reference? Thanks. There's a nice writeup at http://www.radarpages.co.uk/mob/nava...can/tacan1.htm Keith That's a fine reference. I saved a bookmark there. It looks as if the UK TACAN is the same as the USAF TACAN, but I'm still not clear as to the differences from a VOR. Maybe it's just the frequencies. Or, I believe all TACANs are supposed to have DME built in. |
Stubby wrote:
Keith W wrote: There's a nice writeup at http://www.radarpages.co.uk/mob/nava...can/tacan1.htm That's a fine reference. I saved a bookmark there. It looks as if the UK TACAN is the same as the USAF TACAN, but I'm still not clear as to the differences from a VOR. Maybe it's just the frequencies. Or, I believe all TACANs are supposed to have DME built in. There's a VOR reference at http://www.navfltsm.addr.com/vor-nav.htm. | George Ruch | "Is there life in Clovis after Clovis Man?" |
![]() "Keith W" wrote in message ... "Stubby" wrote in message . .. Bob Moore wrote: "M. J. Powell" wrote Except ICs instead of valves? It wasn't the size of the electronics, but rather the large antenna array required of the VOR system. A VOR antenna must be permanently aligned to the earth, something not possible with such a large array onboard a ship. The TACAN system operating on a different principle than VOR solved the size and alignment problems. Bob Moore Can you either explain how a TACAN works or provide a reference? Thanks. There's a nice writeup at http://www.radarpages.co.uk/mob/nava...can/tacan1.htm Here is another description that explains how the VOR ground station signals are used to determine the radial. http://www.answers.com/main/ntquery;...a&linktext=VOR |
writes "M. J. Powell" wrote Except ICs instead of valves? It wasn't the size of the electronics, but rather the large antenna array required of the VOR system. A VOR antenna must be permanently aligned to the earth, something not possible with such a large array onboard a ship. The TACAN system operating on a different principle than VOR solved the size and alignment problems. Right. Thank you, again. Mike -- M.J.Powell |
Wherewhendid dual speed on ias come from | Gene Whitt | Instrument Flight Rules | 7 | October 27th 05 12:31 AM |
Idents on VOR+DME if one of them is inop | Robert M. Gary | Instrument Flight Rules | 14 | January 24th 05 10:10 AM |
KRMN ILS 33- Interesting Approach | Brad Z | Instrument Flight Rules | 11 | May 21st 04 10:53 PM |
