Bob Moore wrote:
"M. J. Powell" wrote Except ICs instead of valves? It wasn't the size of the electronics, but rather the large antenna array required of the VOR system. A VOR antenna must be permanently aligned to the earth, something not possible with such a large array onboard a ship. The TACAN system operating on a different principle than VOR solved the size and alignment problems. The writeup at http://www.radarpages.co.uk/mob/nava...can/tacan1.htm has already been mentioned. Aside from size and earth orientation, TACAN has two advantages over VOR for shipboard use. 1. TACAN uses a bearing reference direction of due east. For a shipboard installation, that means a properly corrected compass reference and a means of correcting the antenna orientation. 2. TACAN incorporates a ranging transponder (DME) in the transmitter site. The aircraft interrogates the system, and the site's transponder responds after a fixed 50 microsecond delay. The site's azimuth and range are typically displayed on a combined bearing/distance/heading indicator. The combination of bearing and range display clears up any of the to/from confusion possible with VOR sites. | George Ruch | "Is there life in Clovis after Clovis Man?" |
Bob Moore wrote:
A VOR antenna must be permanently aligned to the earth, Why? Why not have a heading indicator (or DG) to drive the 'angles' (i.e. phase) it sends out? Hilton |
Hilton wrote:
Bob Moore wrote: A VOR antenna must be permanently aligned to the earth, Why? Why not have a heading indicator (or DG) to drive the 'angles' (i.e. phase) it sends out? An advantage of VORs over TACANs is the VOR antenna does not physically more, whereas it does in a TACAN. Electronic "rotation" of the antenna intuitively makes shipboard use easier, but I might not understand ships enough! |
Stubby wrote:
Hilton wrote: Bob Moore wrote: A VOR antenna must be permanently aligned to the earth, Why? Why not have a heading indicator (or DG) to drive the 'angles' (i.e. phase) it sends out? An advantage of VORs over TACANs is the VOR antenna does not physically more, whereas it does in a TACAN. Electronic "rotation" of the antenna intuitively makes shipboard use easier, but I might not understand ships enough! Operating frequencies dictate the size of the antenna array. Compare this picture of a TACAN site at http://en.wikipedia.org/wiki/TACAN with this one of a VOR site at http://en.wikipedia.org/wiki/VOR. Other advantages: Range: TACAN DME has a maximum range of 300 NM miles. VOR reception range is limited to 25 - 130 NM, depending on the site's transmitter power. Bearing accuracy: TACAN can provide bearing resolution of +- 1 degree. Typical VOR bearing accuracy is +- 2 degrees. A bearing error of 1 degree at 100 miles isn't likely to be critical on land, but that same error at sea can mean the difference between finding your carrier and a very long swim home. | George Ruch | "Is there life in Clovis after Clovis Man?" |
George Ruch wrote
Operating frequencies dictate the size of the antenna array. Compare this picture of a TACAN site at http://en.wikipedia.org/wiki/TACAN with this one of a VOR site at http://en.wikipedia.org/wiki/VOR. Actually George, the first picture is a VORTAC, a TACAN and VOR installation. The TACAN is just the round cylinder part and that is what makes it so easy to mount onboard a ship. Bob Moore |
George Ruch wrote:
Other advantages: Range: TACAN DME has a maximum range of 300 NM miles. VOR reception range is limited to 25 - 130 NM, depending on the site's transmitter power. But, civil aircraft use the TACAN's DME, so they should see the same range for DME, shouldn't they Bearing accuracy: TACAN can provide bearing resolution of +- 1 degree. Typical VOR bearing accuracy is +- 2 degrees. A bearing error of 1 degree at 100 miles isn't likely to be critical on land, but that same error at sea can mean the difference between finding your carrier and a very long swim home. Help me with that one. The TACAN ground station is on the ship, right? If so, angular errors diminish as you approach the station and you should end up at the ship, whether you started at 150 miles out with a 1 or 2 degree error. |
I wonder if the TACAN has to move physically. That may be an old
design. Looking at the portable tacan posted later in the threads, it doesn't look very mechanical. Stubby wrote: Hilton wrote: Bob Moore wrote: A VOR antenna must be permanently aligned to the earth, Why? Why not have a heading indicator (or DG) to drive the 'angles' (i.e. phase) it sends out? An advantage of VORs over TACANs is the VOR antenna does not physically more, whereas it does in a TACAN. Electronic "rotation" of the antenna intuitively makes shipboard use easier, but I might not understand ships enough! |
Wherewhendid dual speed on ias come from | Gene Whitt | Instrument Flight Rules | 7 | October 27th 05 12:31 AM |
Idents on VOR+DME if one of them is inop | Robert M. Gary | Instrument Flight Rules | 14 | January 24th 05 10:10 AM |
KRMN ILS 33- Interesting Approach | Brad Z | Instrument Flight Rules | 11 | May 21st 04 10:53 PM |
