TACAN
Old January 3rd 06, 09:43 PM posted to rec.aviation.ifr,rec.aviation.military
Default TACAN
Bob Moore wrote:
"M. J. Powell" wrote
Except ICs instead of valves?
It wasn't the size of the electronics, but rather the
large antenna array required of the VOR system. A VOR
antenna must be permanently aligned to the earth,
something not possible with such a large array onboard
a ship. The TACAN system operating on a different
principle than VOR solved the size and alignment problems.
Bob Moore
Can you either explain how a TACAN works or provide a reference? Thanks.
Old January 3rd 06, 11:19 PM posted to rec.aviation.ifr,rec.aviation.military
Default TACAN
In message , Bob Moore
writes
Right. Thank you, again.
Mike
M.J.Powell
Old January 3rd 06, 11:20 PM posted to rec.aviation.ifr,rec.aviation.military
Default TACAN
In message , Stubby
writes
a ship. The TACAN system operating on a different principle than VOR
Bob Moore
I can't, sorry. I've long forgotten it. Even though I was supposed to
write the Vol 1 for the RAF. After a fortnight they posted me!
Mike
M.J.Powell
Old January 3rd 06, 11:43 PM posted to rec.aviation.ifr,rec.aviation.military
Default TACAN
"Stubby" wrote in message
Bob Moore
There's a nice writeup at
http://www.radarpages.co.uk/mob/nava...can/tacan1.htm
Keith
Old January 4th 06, 01:31 AM posted to rec.aviation.ifr,rec.aviation.military
Default TACAN
The writeup at
has already been mentioned.
Aside from size and earth orientation, TACAN has two advantages
over VOR for shipboard use.
1. TACAN uses a bearing reference direction of due east. For a
shipboard installation, that means a properly corrected compass
reference and a means of correcting the antenna orientation.
2. TACAN incorporates a ranging transponder (DME) in the
transmitter site. The aircraft interrogates the system, and the
site's transponder responds after a fixed 50 microsecond delay.
The site's azimuth and range are typically displayed on a
combined bearing/distance/heading indicator. The combination of
bearing and range display clears up any of the to/from confusion
possible with VOR sites.
| George Ruch
| "Is there life in Clovis after Clovis Man?"
Old January 4th 06, 01:32 AM posted to rec.aviation.ifr,rec.aviation.military
Default TACAN
Bob Moore
Keith
That's a fine reference. I saved a bookmark there. It looks as if the
UK TACAN is the same as the USAF TACAN, but I'm still not clear as to
the differences from a VOR. Maybe it's just the frequencies. Or, I
believe all TACANs are supposed to have DME built in.
Old January 4th 06, 01:42 AM posted to rec.aviation.ifr,rec.aviation.military
Default TACAN
There's a VOR reference at
http://www.navfltsm.addr.com/vor-nav.htm.
| George Ruch
Old January 4th 06, 02:35 AM posted to rec.aviation.ifr,rec.aviation.military
Default TACAN
"Keith W" wrote in message
Bob Moore
Here is another description that explains how the VOR ground station signals
are used to determine the radial.
http://www.answers.com/main/ntquery;...a&linktext=VOR
Old January 4th 06, 05:40 AM posted to rec.aviation.ifr,rec.aviation.military
Default TACAN
Bob Moore wrote:
A VOR
Why? Why not have a heading indicator (or DG) to drive the 'angles' (i.e.
phase) it sends out?
Hilton
Old January 4th 06, 03:06 PM posted to rec.aviation.ifr,rec.aviation.military
Default TACAN
Hilton wrote:
Bob Moore wrote:
A VOR
An advantage of VORs over TACANs is the VOR antenna does not physically
more, whereas it does in a TACAN. Electronic "rotation" of the antenna
intuitively makes shipboard use easier, but I might not understand ships
enough!
Wherewhendid dual speed on ias come from Gene Whitt Instrument Flight Rules 7 October 27th 05 12:31 AM
Idents on VOR+DME if one of them is inop Robert M. Gary Instrument Flight Rules 14 January 24th 05 10:10 AM
KRMN ILS 33- Interesting Approach Brad Z Instrument Flight Rules 11 May 21st 04 10:53 PM
