Rip wrote in
t: VOR test points certainly do still exist. Check the Airport and Facilities Directory for one near you. Keep in mind that up to a 6 degree error is permissible between units when doing an airborn check (as it sounds like you have been doing). Rip It is 6 degrees for an airborne checkpoint. It is only 4 degrees when you are checking one VOR against the other, which is basically what is going on in this case. There are many ways to check which one is correct. You can use a VOT (available at some airports), an approved ground checkpoint, or an approved airborne checkpoint. These are all listed in the AFD. You can also make your own airborne checkpoint, or do the dual VOR check (which doesn't really tell you if the receiver is incorrect, only that the two receivers agree). If you are not going to take it to a shop, I would recommend the VOT first, the the ground checkpoint, then the approved airborne. Jim Weir has also been working on a navigational tester in Kitplanes for the last few months. |
Make that the last three years {;-)
Rich, there ought to be a little tweaky either on the rear of the OBS case or by removing a knob and finding a hollow shaft for a long, tiny screwdriver. Find your appropriate ground checkpoint using (as the fellow suggested) the AFM and tweak it in. Save yourself a few tenths of an AMU. However, you are merely adjusting, not CALIBRATING, which requires a certificated repair station. Jim VOT first, the the ground checkpoint, then the approved airborne. Jim Weir has also been working on a navigational tester in Kitplanes for the last few months. |
"RST Engineering" wrote in message
... Rich, there ought to be a little tweaky either on the rear of the OBS case or by removing a knob and finding a hollow shaft for a long, tiny screwdriver. Find your appropriate ground checkpoint using (as the fellow suggested) the AFM and tweak it in. Save yourself a few tenths of an AMU. However, you are merely adjusting, not CALIBRATING, which requires a certificated repair station. Aha! Yoost like de compass, you betcha. . . I don't suppose there's anything one can do as easily for the bearing displayed on the digital thingy. Thanks, Jim Rich S. |
Dunno. THere was on the one I built, but it was an internal adjustment.
Jim "Rich S." wrote in message ... "RST Engineering" wrote in message ... Rich, there ought to be a little tweaky either on the rear of the OBS case or by removing a knob and finding a hollow shaft for a long, tiny screwdriver. Find your appropriate ground checkpoint using (as the fellow suggested) the AFM and tweak it in. Save yourself a few tenths of an AMU. However, you are merely adjusting, not CALIBRATING, which requires a certificated repair station. Aha! Yoost like de compass, you betcha. . . I don't suppose there's anything one can do as easily for the bearing displayed on the digital thingy. Thanks, Jim Rich S. |
RST Engineering wrote:
Dunno. THere was on the one I built, but it was an internal adjustment. Jim "Rich S." wrote in message ... "RST Engineering" wrote in message . .. Rich, there ought to be a little tweaky either on the rear of the OBS case or by removing a knob and finding a hollow shaft for a long, tiny screwdriver. Find your appropriate ground checkpoint using (as the fellow suggested) the AFM and tweak it in. Save yourself a few tenths of an AMU. However, you are merely adjusting, not CALIBRATING, which requires a certificated repair station. Aha! Yoost like de compass, you betcha. . . I don't suppose there's anything one can do as easily for the bearing displayed on the digital thingy. Thanks, Jim Rich S. "little tweaky?" "digital thingy?" Come on guys, lay off the technical jargon and use plain English. Dan, U.S. Air Force, retired |
