Aspen at night
Old January 4th 06, 09:07 PM posted to rec.aviation.ifr
Default Aspen at night
Jim Macklin wrote:
All missed approach gradients are based on engine out climb,
which is very weak because jets climb at high speed and thus
have a lower gradient.
Nothing in TERPs, including missed approach procedures, consider engine
out climb.
Old January 4th 06, 09:42 PM posted to rec.aviation.ifr
Standard climb gradients are based on 150'/ NM (if I
remember correctly) and if a departure is greater than that,
it will be noted on the chart. FAR 135 and 121 require that
the most adverse performance be considered when operating,
gross weight must be reduced to meet the performance
requirement. Often you will see airliners with half the
seats empty because the airplane can't meet the take-off
requirements.
I did not say it very well the first time.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
news:3NWuf.6579$V.94@fed1read04...
climb,
thus
consider engine
| out climb.
Old January 4th 06, 11:20 PM posted to rec.aviation.ifr
requirements.
Departures are standard if they do not exceed 200 feet per mile.
Missed approach surfaces are 40:1, which is 152 feet per mile. That is
probably the 150 per mile you're thinking of. The current FAA thinking
is that a missed approach requires 200 feet per mile, and the AIM so
states. (AIM 5-4-20 b)
One-engine climb gradient requirements apply on the commercial
operators. (121.189 for air carriers). But, the air carrier, under
121.189, is not required to look at the missed approach procedure's
entire area of protected airspace. If the carrier finds that will not
penalize them they are free to simply accept the missed approach as a
missed-approach OEI flight path.
As you know, the 121.189 issues are far more pronounced on departure
than they are on the typical missed approach.
Old January 5th 06, 12:36 AM posted to rec.aviation.ifr
KISS WAG SWAG PDC
150/152 even 200 ft/nm is shallow, but most light aircraft
and many jets with an engine out can't do it at altitudes
above 5,000 feet.
James H. Macklin
ATP,CFI,A&P
news:AJYuf.6585$V.412@fed1read04...
that,
that
operating,
| requirements.
mile.
mile. That is
FAA thinking
the AIM so
commercial
carrier, under
procedure's
that will not
approach as a
departure
Old January 5th 06, 12:54 AM posted to rec.aviation.ifr
Jim Macklin wrote:
KISS WAG SWAG PDC
above 5,000 feet.
Then, there are the high-end biz jets that can do 700 feet per mile (SL,
standard day) with OEI.
Old January 5th 06, 01:32 AM posted to rec.aviation.ifr
Yes, the modern biz jet is very over-powered and they can
climb at moderate speed. But with an engine out, even the
hot-rod Lear jet climbs out flat.
Just as a point, I once had the opportunity to depart
Wichita (1332 feet MSL) single pilot in a King Air 300, no
passengers or baggage and only 1/2 fuel. I was taking the
plane to Oklahoma City for a salesman to show. Departed
runway 1R and did a 130 kt. IAS chandelle to the right from
rotation, circling around the airport radar antenna. Rolled
out southbound at 5,000 over the Cessna plant. Approach
asked where I was, apparently I stayed in their dead zone
from just after lift-off until I rolled out of my turn,
about 45 seconds after take-off.
I could have been higher but 5,000 was my take-off limit,
approach cleared my to 15,000 and I was there before I was
10 miles south. Love that big King Air, only problem was my
chart bag ended up in the baggage area, lucky for me, it was
a route I flew weekly and the necessary charts were on my
knee. I use a cheap steno pad holder with a "third-hand"
from Sporty's, cost very little, has a clear window on the
flap and a 5x8 yellow pad.
James H. Macklin
ATP,CFI,A&P
some support
news:26_uf.6816$V.287@fed1read04...
| Jim Macklin wrote:
| KISS WAG SWAG PDC
aircraft
altitudes
| above 5,000 feet.
per mile (SL,
FAA PPL night flight requirement - does it have to be DUAL? Peter Clark Piloting 21 January 6th 05 12:38 AM
Night solo XC? G. Burkhart Piloting 51 October 14th 04 03:11 PM
Night of the bombers - the most daring special mission of Finnishbombers in WW2 Jukka O. Kauppinen Military Aviation 4 March 22nd 04 11:19 PM
