Newbie holding questions
Old January 5th 06, 04:43 AM posted to rec.aviation.ifr
Default Newbie holding questions
On Thu, 05 Jan 2006 04:22:11 GMT, Steven P. McNicoll wrote:
If no EFC and radios go belly up while in IMC, when would you know to
leave
the hold?
Without an EFC I wouldn't enter the hold. It's a moot point anyway,
whatever caused my comm radios to go belly up will affect my nav radios the
same way and I won't be able to identify the holding fix.
Not true. Stuck mic comes to mind quickly. Squelch set too high would be
second in mind. Something could fry within the com unit....
NAV still works, and before radios went south, at least the EFC would allow
me to navigate predictably. Again, realizing remotely possible, the rules
and regs did build this in with the EFC feature.
Old January 5th 06, 04:49 AM posted to rec.aviation.ifr
"A Lieberman" wrote in message
A stuck mic is not a situation where the radios have gone belly up, it's a
situation that illuminates a light on the panel and is soon rectified.
Squelch set too high would be second in mind.
I don't set the squelch too high.
....but wouldn't affect the other one.
Old January 5th 06, 05:19 AM posted to rec.aviation.ifr
What light? You have not seen my radios? There are no lights anywhere.
You don't yourself, but that's not to say it doesn't happen especially over
areas where you may be far from a transmitter.
a very real possibility. Otherwise, why would 7600 be an option on the
transponder? I have had to use the IDENT feature once when I had radio
problems. I could hear, but not transmit, so it does happen. I didn't
have to go 7600, since I was able to communicate via the IDENT button.
Old January 5th 06, 02:16 PM posted to rec.aviation.ifr
Are you serious? I don't think I've ever seen a tranceiver of any kind
(not just limited to aviation) which didn't have some sort of visual "Tx"
indication.
Old January 5th 06, 03:56 PM posted to rec.aviation.ifr
indication.
KX-170? ...for one example.
Old January 5th 06, 09:21 PM posted to rec.aviation.ifr
We're not talking about your panel, we're talking about mine. We got to
this point via your question to me; " If no EFC and radios go belly up while
in IMC, when would you know to leave the hold?"
So how does something frying in one com take out the other com but not the
navs or the transponder?
Old January 5th 06, 05:22 AM posted to rec.aviation.ifr
Not all airplanes, particularly trainers have a transmit
light.
James H. Macklin
ATP,CFI,A&P
"Steven P. McNicoll" wrote in
message
news |
belly up, it's a
soon rectified.
Old January 5th 06, 10:58 PM posted to rec.aviation.ifr
"Jim Macklin" wrote in message
news:S32vf.40590$QW2.33132@dukeread08...
light.
We're not talking about all airplanes, we're talking about mine.
Questions from a newbie. Andrew Tubbiolo Home Built 9 September 14th 04 01:40 AM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
Newbie with questions... Mike \(Remove X's to reply\) Piloting 10 February 14th 04 01:16 AM
Newbie questions Rail / Ejector launchers AL Military Aviation 19 November 14th 03 07:47 PM
Basic Stupid Newbie Questions... John Penta Military Aviation 5 September 19th 03 05:23 PM
