![]() "bstanton" null.com wrote in message ... If you are a Champ owner, have you read about the great bank robbery using a Champ for the getaway, CFI's as bank robbers and bullet holes in the fabric as they escaped? Yes, in "AOPA Pilot" about a year ago. |
If the wing wires are indeed installed, 90% of the work is already done..
We ran wires in Leo's BC12D Tailorcraft using 1/4 x 1/2 inch spruced capstrip stock as a pusher. We worked the wires from one inspection plate to the next. His wings already had the bulbs installed - but no wires. Go figure... Somebody else already mentioned the light socket question. The bulbs (12 volt only) and mounts are available from Aircraft Spruce. A Plain Jane pair of tip lights ruin a hundred bucks or more. Fancy ones are available with built in strobes (!) I'm curious if the strobes would fill the anti collision ewquirement? We didn't rig up a rotating collision light. But a small roller from an EMS/police supplier (or your local truck stop?) should prove serviceable. Or dig deeper and get a "real" one. Mounting it is problematic. Depends on the light, and the airplane. Where would you put it on a Champ? On the belly metal? Your choice of power sources. Wind driven generators are heavy (at least the originals were!) and add a lot of drag. A Gel Cell 12 volt battery is the simplest solution. And it is not necessarily a permanent installation. (Think "Hand Held") One last thought... How will you light the panel? Richard |
Richard Lamb wrote:
I'm curious if the strobes would fill the anti collision ewquirement? Yes. Maules come that way from the factory. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
Would be a lot simpler, wouldn't it...
Richard George Patterson wrote: Richard Lamb wrote: I'm curious if the strobes would fill the anti collision ewquirement? Yes. Maules come that way from the factory. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
On Fri, 06 Jan 2006 03:03:42 GMT, Richard Lamb
wrote in :: A Plain Jane pair of tip lights ruin a hundred bucks or more. I would get a quote from Wentworth Aircraft before deciding where to purchase these parts: http://www.wentworthaircraft.com/inforequest.htm Who knows, they may actually have the certified parts. In my experience, their prices are reasonable. http://www.wentworthaircraft.com/home.htm |
bstanton wrote:
Does anyone here have current draw specs for standard lights and strobes? Whelen makes a small power supply for a single strobe that pulls 1.7 amps at 14 volts. They also make a flasher that will drive two wingtip strobes that pulls 4 amps. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
"George Patterson" wrote in message
news:gKdvf.26704$Uf7.17185@trnddc01... Whelen makes a small power supply for a single strobe that pulls 1.7 amps at 14 volts. They also make a flasher that will drive two wingtip strobes that pulls 4 amps. Here's one that shouldn't draw much in the way of current. http://www.greatplainsas.com/scelectrical.html My first Emeraude had one on the top of the tail and it worked pretty well. I had to replace the transistors once when the leads broke from vibration. I installed two of these in the wingtips of my new Emeraude, but heat would affect them badly, slowing the rate of flashing until it stopped. I had "potted" the transistor leads with clear silicone to prevent breaking, which may have contributed to the heat build-up. They have been replaced with a Whelan unit from http://www.strobesnmore.com/. Rich S. |
FAA PPL night flight requirement - does it have to be DUAL? | Peter Clark | Piloting | 21 | January 6th 05 12:38 AM |
Night solo XC? | G. Burkhart | Piloting | 51 | October 14th 04 03:11 PM |
Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 22nd 04 11:19 PM |
