unsticking cables
Old January 5th 06, 09:58 PM posted to rec.aviation.owning
Default unsticking cables
dlevy wrote:
The defrost cable is stuck on my Musketeer. It's just a wire encased in
another spirally wound wire.
Any suggestions?
Spray lube on as much of the exterior of the cable housing as you can
get to. The lube will soak into the spiral wrap, and free up the wire
core (hopefully!). This technique generally works on the older style
control cables that do not have a plastic inner lining.
Happy Flying!
Scott Skylane
N92054
Cables for LightSpeed Plasma ignition. ELIPPSE Home Built 2 January 14th 05 04:46 AM
Best Prices on Pocket PC and Palm Cables Jim Vincent Soaring 0 April 15th 04 05:52 AM
MiG-29 cables alcatraz Military Aviation 0 March 1st 04 10:01 PM
Copper Cables Work: Update Bud Patterson Owning 0 February 15th 04 01:46 AM
Control cables for gliders mike maskell Soaring 10 January 1st 04 05:08 AM
