Pop-up IFR from Clearance Delivery
Old March 22nd 04, 01:41 AM
John Clonts
ink.net...
"John Clonts" wrote in message
He's on the ground. CD says to him: "...contact approach
when airborne..."
Interesting. A clearance delivery position that won't deliver a clearance
to an aircraft on the ground.
Indeed. To Andrew it was interesting enough to prompt him to post a usenet
question about it!
Old March 22nd 04, 05:33 PM
Steven P. McNicoll
a usenet question about it!
I think most of you folks are thinking of this clearance delivery frequency
as being a separate position in the TRACON. That's extremely unlikely. Any
airport with enough traffic to justify such a position is an airport needing
a control tower. This frequency is almost certainly just an RTR located at
the field because the normal approach control frequency for that area does
not reach aircraft on the ground. It's probably labeled as a clearance
delivery frequency instead of an approach frequency because some other
facility not so far away also uses that frequency and airborne use of it
would interfere.
Old March 23rd 04, 04:36 AM
John Clonts
nk.net...
frequency
Any
needing
at
would interfere.
At my airport it's definitely this way. The guy I talk to at Gray CD is the
same guy I talk to once airborne. That's why I would expect that CD could
give me a clearance just as readily as approach could. And if they told me
"contact FSS or contact approach once airborne", I would wonder about it,
just like Andrew did.
Seems like Roy Smith had a pretty good answer for it, though...
Cheers,
John Clonts
Temple, Texas
N7NZ
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
AFSS clearance delivery Dan Luke Instrument Flight Rules 7 February 9th 04 12:56 AM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
