You can get some slightly lower drop diodes and they can handle plenty
of current. 18 amps forward I think was the max listed for the ones I used. Great way to go as you never have to think about batteries while flying. It's always pulling from the best battery and no issues while changing over if using a switch. ContestID67 wrote: I would like to ask the rec.aviation.soaring community for comments about their experiences switching between batteries while in flight. It seems to be common practice to carry two batteries. There is usually a master switch and then an A/B switch to toggle between the batteries. The issue is what will a momentary interruption in power, when you toggle the A/B switch, do to your flight recorder/computer? Most important is the integrity of your flight log, less importantly is your task and other flight data. PDAs are not suseptible to this issue as they come with their own internal ("backup") battery. Also, let's not discuss "well I have this-and-that device as a backup" (handheld GPS, machanical vario, etc). The issue at hand is competition, record or badge flying and quarantee that all important flight log by maintaining power to your flight recorder. I have not seen a ship yet that had two redundant flight recorders (but I will bet they exist). A simple double throw A/B switch is commonly used. My measurements show that this type of switch is completely open (no power) for 10-15ms but this depends greatly on the quality of the switch. There are make-before-break switches in which for a brief period of time both batteries are connected to each other and there is no loss of power. However even briefly connecting two heafty batteries together, with one possibly completely failed, has its own drawbacks (like an onboard fire). This of course all depends on the pilot knowing when to switch. If (s)he first waits until a failure is noticed, then all may be lost. Another approach is having two ship's batteries connected to one another via a "device" which allows each to (safely) supply current and to automatically switch between the two if one fails. A pair of heafty diodes is an obvious and simple choice as one battery cannot "charge" the other but both can supply power. However, you will typically loose 0.6v-0.8v across a silicon power diode. Ultimately it seems to depend on the manufacturer of the recorder and how their electronics handle a temporary loss of power. Some manufacturers support permanent backup batteries which charge from the ship's main battery. This may be the best overall solution. Any of your ideas and solutions are very welcome. Thanks, John |
Battery Source | Mike the Strike | Soaring | 81 | October 28th 05 12:46 AM |
Advice and experts with 400 series Cessnas (414 and 421), purchase and training | [email protected] | Owning | 36 | January 9th 05 02:32 AM |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
boot camp advice | jameson | Military Aviation | 17 | July 22nd 04 05:12 AM |
Rechargable AA batteries and chargers | TripFarmer | General Aviation | 2 | October 17th 03 06:34 PM |
