Airspeed Indicator Accuracy Tolerance
Old January 7th 06, 06:17 PM posted to rec.aviation.ifr
Default Airspeed Indicator Accuracy Tolerance
If there is no means of adjustment, the question answers itself. Keep in
mind that the blue line is not sacrosanct...actual Vyse will vary with
weight and density altitude. The vertical speed indicator is a much more
accurate means of determining best rate of climb.
Bob Gardner
"O. Sami Saydjari" wrote in message
In my Cessna 421C, the pilot-side airspeed indicator reads 6 nts below the
co-pilot-side airspeed indicator. When I pointed this out to a mechanic,
he said that it was "within toleraance." He said it was possible that one
was 3 nts high and the other 3 nts low and so both could be within
tolerance. He added that there is no real internal adjustment, so there
is not much he could do about it anyway.
Seems to me that when you are talking about a possible 6nt difference and
given the need for accurately maintain blue-line speed in case of a
single-engine failure, it is important to know that one's airpseed
indicator is accurate. Isn't there a way to judge true accuracy of speed
indicators (just as there is for altimeters)? Should I be satisfied with
my mechanic's answer and move on?
-Sami
N5554G, Cessna 421C
Old January 7th 06, 08:49 PM posted to rec.aviation.ifr
Well, not really. My question is whether their is a good way to measure
the absolute accuracy of a ASI. And my concern is that 6 nts is too far
off when it could make a significant difference in performance in
critical situations, like single engine operation.
Bob Gardner
-Sami
N5554G, Cessna 421C
Old January 7th 06, 09:02 PM posted to rec.aviation.ifr
And my point is that absolute accuracy is not important.
Bob
off when it could make a significant difference in performance in critical
Bob Gardner
the co-pilot-side airspeed indicator. When I pointed this out to a
mechanic, he said that it was "within toleraance." He said it was
possible that one was 3 nts high and the other 3 nts low and so both
could be within tolerance. He added that there is no real internal
adjustment, so there is not much he could do about it anyway.
-Sami
N5554G, Cessna 421C
Old January 7th 06, 09:22 PM posted to rec.aviation.ifr
Compare the reading son the airspeed, altimeter and VS while
pressurized and with the cabin vented at ambient. You could
have a static leak inside the pressure cabin that is letting
pressurized cabin air into the pilot's static line.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Bob Gardner" wrote in message
| Bob
in message
will vary with
good way to measure
6 nts is too far
| Bob Gardner
| "O. Sami Saydjari"
reads 6 nts below
this out to a
said it was
low and so both
real internal
anyway.
6nt difference and
in case of a
one's airpseed
accuracy of speed
be satisfied with
| -Sami
| N5554G, Cessna 421C
Old January 8th 06, 12:10 AM posted to rec.aviation.ifr
I wrote an article in Kitplanes magazine 15 years ago or so about using
plastic tubing, a yardstick, and tinted water to make a water manometer for
testing airspeed indicators.
Inaccurate airspeed indicator Wyatt Emmerich Instrument Flight Rules 20 April 20th 04 12:08 AM
Tow plane airspeed vs. glider being towed airspeed? MHende6388 Soaring 2 September 28th 03 09:35 AM
