Add a little sludge, maybe some cold oil and an over-revved
engine, and you get cam lobe /journal failure or the lifter. Can you expand on that a bit, Jim? What, exactly, is an "over-revved engine"? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Start with the throttle 1/2 open, zero rpm to 1800 with no
oil pressure. Etc. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Jay Honeck" wrote in message news ![]() | Add a little sludge, maybe some cold oil and an over-revved | engine, and you get cam lobe /journal failure or the lifter. | | Can you expand on that a bit, Jim? What, exactly, is an "over-revved | engine"? | -- | Jay Honeck | Iowa City, IA | Pathfinder N56993 | www.AlexisParkInn.com | "Your Aviation Destination" | | |
Jim Macklin wrote:
Start with the throttle 1/2 open, zero rpm to 1800 with no oil pressure. Etc. No, I don't start mine like that. On shut down, I set the throttle for 1000 RPM and lock it. The throttle doesn't move again until the engine is warmed up. I preheat religiously below 30F, and I don't leave the preheater plugged in. Also, if it were corrosion that got mine, why only one cam lobe?? My mechanic tells me there have been a rash of problems with newer cams with flaws in the case hardening. I haven't seen evidence to prove it though. |
Even a 1000 rpm could be a little higher than ideal. It is
hard to say what causes problems sometimes. There are manufacturing defects, there is a possibility that an oil passage is partially plugged. Sometimes the mechanic who assembled the engine can have missed getting assembly lube on the cam or journal. If it is on a cam and or lifter, even valve spring tension will effect the load on the wear surfaces. Best you can do is follow the engine manufacturer's recommendations about starting and shutdown, oil changes, etc and save money for the unexpected work. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Ray Andraka" wrote in message news:mQ2wf.41528$Mi5.36676@dukeread07... | Jim Macklin wrote: | | Start with the throttle 1/2 open, zero rpm to 1800 with no | oil pressure. Etc. | | | | No, I don't start mine like that. On shut down, I set the throttle for | 1000 RPM and lock it. The throttle doesn't move again until the engine | is warmed up. I preheat religiously below 30F, and I don't leave the | preheater plugged in. | | Also, if it were corrosion that got mine, why only one cam lobe?? My | mechanic tells me there have been a rash of problems with newer cams | with flaws in the case hardening. I haven't seen evidence to prove it | though. |
oil pressure. Etc. I aim to keep RPMs at 1000 (or less) from start-up to run-up. (My A&P showed me that 1000 RPM is too low to kick up stones, so being patient and taxiing slowly really saves your prop.) What do you think causes a problem like Ray's, Jim? It just seems to, I don't know -- random. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Low rpm does save the prop, it also keeps the load on the
bearings a little less, throttle jockeying is worst, cold oil doesn't flow quickly in response to throttle changes. Also, if you have a constant speed prop, the governor uses engine oil, so avoid taxing the oil pressure with rpm and / or prop changes until the oil has had a chance to warm up a little. It also came to mind, that a sticking valve will cause more wear on that cam/lifter assembly, so that can be a problem to check. Most engines have the oil pump at one end and oil pressure is measured from a point on the other end, probably a cam shaft gallery so that you can tell that oil passages are not blocked. That is one reason for the "shutdown in 30 seconds" if you don't have oil pressure on starting note. I like to idle an engine for a minute (4-5 minutes with turbocharged engine) to allow it to cool before shutdown while still having oil cooling. This would be at 1,000-1,200 rpm so the prop would be blowing some air through the cowl. I then think it is a good idea to throttle back to minimum rpm, to see that the idle is smooth at 500-700 rpm range and I do a mag grounding check at that point and then pull the mixture to shut it down. That should show a slight 25-50 rpm increase just as it shuts down since idle should be a little rich. I start the engine at minimum throttle and using as little priming as possible [wait after priming a few seconds to a minute in cold weather to allow the fuel to vaporize, liquid doesn't burn and it washes the oil off the cylinder walls] then after it starts, advance the throttle smoothly to 1000 rpm to get some prop wash cooling and generator output. Change to oil often, it is a lot cheaper to change the oil than to tear down the engine. Use the best oil you can find and the multi-weight oils do start working/ pumping faster. Oil changes can be done by the pilot/owner as preventative maintenance. A logbook entry is required and you must follow the service manual procedures. Be sure to check for leaks after the change and be sure to safety any drain plugs. A quick drain system makes it a lot easier to do, and an extension hose on the drain will keep the cowl clean. Filters may not need to be changed every time if the oil change is due to calendar time and condensation draining. The oil filter does work on engine time in service since it only functions when the oil is flowing and being filtered. But follow the manual, if it says change the filter with every oil change, you should do so. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Jay Honeck" wrote in message news:_J8wf.714011$xm3.343650@attbi_s21... | Start with the throttle 1/2 open, zero rpm to 1800 with no | oil pressure. Etc. | | I aim to keep RPMs at 1000 (or less) from start-up to run-up. (My A&P | showed me that 1000 RPM is too low to kick up stones, so being patient and | taxiing slowly really saves your prop.) | | What do you think causes a problem like Ray's, Jim? It just seems to, I | don't know -- random. | -- | Jay Honeck | Iowa City, IA | Pathfinder N56993 | www.AlexisParkInn.com | "Your Aviation Destination" | | |
![]() "Jim Macklin" wrote in message news:Wgcwf.40975$QW2.5751@dukeread08... point and then pull the mixture to shut it down. That should show a slight 25-50 rpm increase just as it shuts down since idle should be a little rich. For my TIO540-S1AD, Lycoming says five rpm, not more than ten. Stan |
I'll buy that, always best to use specific data rather than
a generic answer. It takes a pretty good eye and tach to see 5 rpm. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Stan Prevost" wrote in message ... | | "Jim Macklin" wrote in message | news:Wgcwf.40975$QW2.5751@dukeread08... | point and then pull the mixture to shut it down. That | should show a slight 25-50 rpm increase just as it shuts | down since idle should be a little rich. | | | For my TIO540-S1AD, Lycoming says five rpm, not more than ten. | | Stan | | |
![]() "Jim Macklin" wrote in message news:7ilwf.41026$QW2.13106@dukeread08... I'll buy that, always best to use specific data rather than a generic answer. It takes a pretty good eye and tach to see 5 rpm. Sure does. And a digital tach may flicker that much. Sometimes it is called a "barely perceptible rise". Some say it is easier to observe a rise in MP than such a small RPM rise, and that is borne out by my observation. The MP will rise one to two inches, and the MP gauge seems to be more stable than the tach. If the mixture is set to spec, it is not necessary to lean for ground ops, since it is already lean enough to prevent plug fouling. Ground leaning is effective only if leaned back to the edge of idle cutoff, anyway. The Lycoming manual doesn't seem to have any tables for adjusting RPM rise for density altitude. If it is leaned to the 5RPM rise spec at a high altitude airport, I wonder if it might be too lean at a low-altitude airport, with no way to enrichen it. Stan |
Stan Prevost wrote:
"Jim Macklin" wrote in message news:Wgcwf.40975$QW2.5751@dukeread08... point and then pull the mixture to shut it down. That should show a slight 25-50 rpm increase just as it shuts down since idle should be a little rich. For my TIO540-S1AD, Lycoming says five rpm, not more than ten. The mixture on injected engines typically is not as rich at idle as carburetted engines, so the rpm increase should not be as great. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
Nasa Icing courses | Jim Burns | Piloting | 96 | February 1st 06 04:16 AM |
ASRS/ASAP reporting systems - how confidential? | Tim Epstein | Piloting | 7 | August 4th 05 05:20 PM |
NASA Icing Course | [email protected] | Piloting | 3 | December 28th 04 05:18 PM |
About Acellerated Courses for Private | Dudley Henriques | Piloting | 137 | July 22nd 04 04:21 AM |
FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 07:44 PM |
