Nasa Icing courses
Old January 8th 06, 07:04 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Default Engine Making Metal (Was: Nasa Icing courses)
Jim Macklin wrote:
Start with the throttle 1/2 open, zero rpm to 1800 with no
oil pressure. Etc.
No, I don't start mine like that. On shut down, I set the throttle for
1000 RPM and lock it. The throttle doesn't move again until the engine
is warmed up. I preheat religiously below 30F, and I don't leave the
preheater plugged in.
Also, if it were corrosion that got mine, why only one cam lobe?? My
mechanic tells me there have been a rash of problems with newer cams
with flaws in the case hardening. I haven't seen evidence to prove it
though.
Old January 8th 06, 05:18 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Even a 1000 rpm could be a little higher than ideal. It is
hard to say what causes problems sometimes. There are
manufacturing defects, there is a possibility that an oil
passage is partially plugged. Sometimes the mechanic who
assembled the engine can have missed getting assembly lube
on the cam or journal. If it is on a cam and or lifter,
even valve spring tension will effect the load on the wear
surfaces.
Best you can do is follow the engine manufacturer's
recommendations about starting and shutdown, oil changes,
etc and save money for the unexpected work.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Ray Andraka" wrote in message
news:mQ2wf.41528$Mi5.36676@dukeread07...
no
| oil pressure. Etc.
throttle for
until the engine
don't leave the
lobe?? My
newer cams
to prove it
| though.
Nasa Icing courses Jim Burns Piloting 96 February 1st 06 04:16 AM
ASRS/ASAP reporting systems - how confidential? Tim Epstein Piloting 7 August 4th 05 05:20 PM
NASA Icing Course [email protected] Piloting 3 December 28th 04 05:18 PM
About Acellerated Courses for Private Dudley Henriques Piloting 137 July 22nd 04 04:21 AM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
