Check for valve sticking on that cylinder, that would raise
the pressure on the lifter/cam. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Mark Hansen" wrote in message ... | On 1/8/2006 5:51 AM, Jay Honeck wrote: | | And mechanical failures should have simple explanations, no? WHY did | one of the cam lobes fail? Why didn't ALL of the cam lobes fail? | | Timeless issue. www.aviationconsumer.com has hours of reading on the | subject. The common factor is infrequent flying. | | I suppose the *real* issue should be: Why do camshafts work at all? When | you sit down and rationally analyze what is happening inside your engine, | the danged thing should just throw itself to pieces in the first ten minutes | of operation. | | Yet, most of them don't. | | Some, however, like Ray's engine, do -- and in very peculiar ways. (Just | ONE cam lobe went bad?) | | Why? | | I wonder if this was the first cam lobe to actually fail. Have they all | been measured and determined to be within spec? | | -- | Mark Hansen, PP-ASEL, Instrument Airplane | Sacramento, CA |
Nasa Icing courses | Jim Burns | Piloting | 96 | February 1st 06 04:16 AM |
Nasa Icing courses | Jim Burns | Owning | 108 | February 1st 06 04:16 AM |
ASRS/ASAP reporting systems - how confidential? | Tim Epstein | Piloting | 7 | August 4th 05 05:20 PM |
NASA Icing Course | [email protected] | Piloting | 3 | December 28th 04 05:18 PM |
FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 07:44 PM |
