I was aware of the equipment required by the FARs for IFR, but that
isn't real-world. Right? To fly approaches you need substantially more equipment than that, of course. The different types of approaches and equipment make the subject complex at first sight to the neophyte. Andrew Sarangan wrote: The basic requirement for IFR is not a whole lot more than for VFR. You don't need two nav's (or any nav at all), although that would be nice. The FAR outlines what you need to fly IFR. Besides the regular six pack instruments (except the VSI), your altimeter must be accurate to within 75 ft, and your transponder's altitude encoder must have been inspected to IFR standards. |
I seriously considered this advice and looked into the NAV 122. I
talked to a friend of mine and the local avionics shop and they both told me that Narco has a bad rep for service and gouges you badly to fix a 122 - and they do break. As others have pointed out, you don't need a heck of a lot more to make the plane legal for IFR training/flight. Here's what __I'd__ do if I were you. I'd sell the 300XL (since you got it for a steal, you should at least get your money back) and buy a used NARCO NAV-122A on Ebay. You can get a yellow tagged one for about $1300. This is the ONLY piece of equipment you will need to be able to fly IFR legally - it's a VOR, LOC, GS, MKR and CDI all in one 3 1/8" hole. You can then legally do ILS, LOC, and VOR approaches. I did exactly this in order to make my COZY MKIV IFR capable (for training purposes and light IFR). Even if you have to pay someone $500 to install it, it's still the cheapest way there, using the least panel space. |
Ok, here's what I'm thinking now. Critisism of this setup not
discouraged! - 300XL installed *VFR only*. - PSE 6000 Audio panel with marker beacons. - KX-155 nav/com - there's one on Ebay right now I may pick up. - KX 209 Indicator. Local shop tells me no more than $3500 or so for this install, including antenna for 2nd com. Does that sound right? I'd be ditching the 385 nav/com that's in there now, of course. Full cost of this setup assuming used KX-155 and 209 and new audio panel should be $9-$10K. While this is definitely more money than I wanted to spend or figured I'd have to spend, I think it may be worth it. I actually ran a price quote on my plane (aeroprice) with this equipment installed and was pleased to see the value go up by 80% or so of what I'd be putting into it. I plan to keep the plane for probably 4-5 years (until I build my RV-9). Again, what I want to do here is have an aircraft in which I can get my instrument ticket and be able to practice real-world instrument approaches. Subsequent to that, I don't see myself flying hard IMC, but being able to do a lot more flying on those marginal VFR days that keep me grounded now. (MVFR can turn into IFR too damn easily - I've already discovered that.) Tell me if I'm all wet (please). Paul Folbrecht wrote: I've just purchased a '79 152 that is currently VFR only. Avionics consist of a single nav/com and xponder. That's it. At some point in the next year or two I am going to want to get my instrument ticket in this aircraft, so I'm already starting to think about the best way to do that. Trouble is I know precious little about IFR equipment at the moment. If someone has some good resources/links that could get me up to speed I'd appreciate it. Actually, I already started buying stuff. I bought an IFR Garmin 300XL GPS on ebay (it was a steal). That's my start. I'm completely open to suggestions on where to go from there. Maybe a B/K 80 nav? Has everything else I need, right? I know I need an audio (switch) panel and at least one more CDI. I'll be searching for an avionics shop soon to install the GPS, but until then any idea what that will cost me? Might it make some sense to have them do a VFR-only install initially and then do it IFR when I have the rest of my equipment? (I want a GPS now, of course, for VFR flight.) TIA. |
I've got a Nav 122, and I've used Narco to repair it. I honeslty don't know
where the bad rep comes from, the 122 is a solid unit and I've only had good experiences with Narco. My 122 has been to Narco twice. Once in 1996 when it was intermittently losing the localizer. It turned out to be a cracked resistor. That fix was actually two trips to Narco. The first trip, they only saw the problem briefly and after cleaning up the unit and recalibrating it could not reproduce it. After getting it back in the plane, it got more intermittent so it went back. Narco had the unit a total of 8 days including time in shipping. It was 11 days from when I first took it out till I had it back in and working, and a grand total of $152 to fix. There was no charge on the second trip because once they see it, the whole unit goes under warranty. The second time was summer 2003 for a PROM that had gone bad after an alternator overvoltage. The symptom in that case was no localizer on frequencies that ended with .9x and no glide slope on two frequencies (don't recall which ones now). Took them about six weeks and cost me $225. My usual avionics shop told me it wasn't worth repairing and convinced me to replace it with a KX155/KI209. I figured I would send it to Narco for their $90 eval (they'll eval a unit for $90 and then call you to see if you want to repair it, and the $90 is applied to the repair) to see if it could be resurrected to give me a second glideslope. It is back in my airplane now. I've noticed that it is noticibly more sensitive than the KX155 for picking up VORs as well as localizers. Shop measured it to be about 11db more sensitive. The only thing I like better about the kx155 is the digital flip-flop which allows you to set up a second frequency ahead of time. One of the nice things about the 122 is that it will cost you next to nothing to get it installed. It is all-in-one and goes in a standard 3.5" round hole. You just have to hook up power, audio panel, and the antennas. Oh, it also has a marker beacon recevier built in if you don't have one in your audio panel. For about $2200 you could have a Narco rebuild installed. I did my primary instruction and part of my instrument in a BE-77 (beech skipper) that had a single KX-170 nav-com with no glideslope or markers but was IFR certified. The cert was OK for picking up an emergency IFR clearance to get you on the ground, but that's about it. It would be next to reckless launching off into IFR with such a minimal panel. You can't shoot an ILS with it (you can do a localizer only approach though), and identifying intersections requires retuning the NAV and turning the OBS. That is a prescription for disaster when shooting an approach in worse than anticipated weather, especially as a low time instrument pilot. The fact that you don't intend to fly much if any IFR with it should underline that concern. At an absolute bare minimum, you should have at least something with a digital flip-flop NAV/COM so that you can set it up to identify intersections and also to set up your tower/departure frequencies ahead. Even that, is probably going to be too little when the chips are down. Put the Narco 122 in, that'll give you a full ILS capability in one instrument, and your existing Nav/comm will still be there to help with identifying intersections. If your comm is not a digital flip-flop, you should probably also consider a second comm. I think this approach will get you a minimal IFR capability for less than the cost of getting an IFR install on the GX-300 Paul Folbrecht wrote: I seriously considered this advice and looked into the NAV 122. I talked to a friend of mine and the local avionics shop and they both told me that Narco has a bad rep for service and gouges you badly to fix a 122 - and they do break. As others have pointed out, you don't need a heck of a lot more to make the plane legal for IFR training/flight. Here's what __I'd__ do if I were you. I'd sell the 300XL (since you got it for a steal, you should at least get your money back) and buy a used NARCO NAV-122A on Ebay. You can get a yellow tagged one for about $1300. This is the ONLY piece of equipment you will need to be able to fly IFR legally - it's a VOR, LOC, GS, MKR and CDI all in one 3 1/8" hole. You can then legally do ILS, LOC, and VOR approaches. I did exactly this in order to make my COZY MKIV IFR capable (for training purposes and light IFR). Even if you have to pay someone $500 to install it, it's still the cheapest way there, using the least panel space. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
If you're installing the 300xl VFR only, why not just go with a handheld?
Heck, a $300 handheld would beat the 300xl in screen size and features. The difference could buy a nice handheld com radio to use as a backup, with a external antenna wired in. I'm not trying to poop on a decision already made, but if you knew you were going to be using this as a IFR training plaform, why didn't you search out a bird with the necessary avionics? Just curious ![]() I can't count the number of folks who get their private certificate and go out and buy a 150/152, only to wish they bought just a bit more for instrument training, trips, passengers, etc. "Paul Folbrecht" wrote in message k.net... Ok, here's what I'm thinking now. Critisism of this setup not discouraged! - 300XL installed *VFR only*. - PSE 6000 Audio panel with marker beacons. - KX-155 nav/com - there's one on Ebay right now I may pick up. - KX 209 Indicator. Local shop tells me no more than $3500 or so for this install, including antenna for 2nd com. Does that sound right? I'd be ditching the 385 nav/com that's in there now, of course. Full cost of this setup assuming used KX-155 and 209 and new audio panel should be $9-$10K. While this is definitely more money than I wanted to spend or figured I'd have to spend, I think it may be worth it. I actually ran a price quote on my plane (aeroprice) with this equipment installed and was pleased to see the value go up by 80% or so of what I'd be putting into it. I plan to keep the plane for probably 4-5 years (until I build my RV-9). Again, what I want to do here is have an aircraft in which I can get my instrument ticket and be able to practice real-world instrument approaches. Subsequent to that, I don't see myself flying hard IMC, but being able to do a lot more flying on those marginal VFR days that keep me grounded now. (MVFR can turn into IFR too damn easily - I've already discovered that.) Tell me if I'm all wet (please). Paul Folbrecht wrote: I've just purchased a '79 152 that is currently VFR only. Avionics consist of a single nav/com and xponder. That's it. At some point in the next year or two I am going to want to get my instrument ticket in this aircraft, so I'm already starting to think about the best way to do that. Trouble is I know precious little about IFR equipment at the moment. If someone has some good resources/links that could get me up to speed I'd appreciate it. Actually, I already started buying stuff. I bought an IFR Garmin 300XL GPS on ebay (it was a steal). That's my start. I'm completely open to suggestions on where to go from there. Maybe a B/K 80 nav? Has everything else I need, right? I know I need an audio (switch) panel and at least one more CDI. I'll be searching for an avionics shop soon to install the GPS, but until then any idea what that will cost me? Might it make some sense to have them do a VFR-only install initially and then do it IFR when I have the rest of my equipment? (I want a GPS now, of course, for VFR flight.) TIA. |
Thanks for the great reply. You seem to be implying that I won't have a
GS with the setup I proposed - I will. But I see your point in retaining a 2nd nav. Trouble is, I don't have the panel space - unless I go with an all in one unit such as the 122. Ray Andraka wrote: I've got a Nav 122, and I've used Narco to repair it. I honeslty don't know where the bad rep comes from, the 122 is a solid unit and I've only had good experiences with Narco. My 122 has been to Narco twice. Once in 1996 when it was intermittently losing the localizer. It turned out to be a cracked resistor. That fix was actually two trips to Narco. The first trip, they only saw the problem briefly and after cleaning up the unit and recalibrating it could not reproduce it. After getting it back in the plane, it got more intermittent so it went back. Narco had the unit a total of 8 days including time in shipping. It was 11 days from when I first took it out till I had it back in and working, and a grand total of $152 to fix. There was no charge on the second trip because once they see it, the whole unit goes under warranty. The second time was summer 2003 for a PROM that had gone bad after an alternator overvoltage. The symptom in that case was no localizer on frequencies that ended with .9x and no glide slope on two frequencies (don't recall which ones now). Took them about six weeks and cost me $225. My usual avionics shop told me it wasn't worth repairing and convinced me to replace it with a KX155/KI209. I figured I would send it to Narco for their $90 eval (they'll eval a unit for $90 and then call you to see if you want to repair it, and the $90 is applied to the repair) to see if it could be resurrected to give me a second glideslope. It is back in my airplane now. I've noticed that it is noticibly more sensitive than the KX155 for picking up VORs as well as localizers. Shop measured it to be about 11db more sensitive. The only thing I like better about the kx155 is the digital flip-flop which allows you to set up a second frequency ahead of time. One of the nice things about the 122 is that it will cost you next to nothing to get it installed. It is all-in-one and goes in a standard 3.5" round hole. You just have to hook up power, audio panel, and the antennas. Oh, it also has a marker beacon recevier built in if you don't have one in your audio panel. For about $2200 you could have a Narco rebuild installed. I did my primary instruction and part of my instrument in a BE-77 (beech skipper) that had a single KX-170 nav-com with no glideslope or markers but was IFR certified. The cert was OK for picking up an emergency IFR clearance to get you on the ground, but that's about it. It would be next to reckless launching off into IFR with such a minimal panel. You can't shoot an ILS with it (you can do a localizer only approach though), and identifying intersections requires retuning the NAV and turning the OBS. That is a prescription for disaster when shooting an approach in worse than anticipated weather, especially as a low time instrument pilot. The fact that you don't intend to fly much if any IFR with it should underline that concern. At an absolute bare minimum, you should have at least something with a digital flip-flop NAV/COM so that you can set it up to identify intersections and also to set up your tower/departure frequencies ahead. Even that, is probably going to be too little when the chips are down. Put the Narco 122 in, that'll give you a full ILS capability in one instrument, and your existing Nav/comm will still be there to help with identifying intersections. If your comm is not a digital flip-flop, you should probably also consider a second comm. I think this approach will get you a minimal IFR capability for less than the cost of getting an IFR install on the GX-300 Paul Folbrecht wrote: I seriously considered this advice and looked into the NAV 122. I talked to a friend of mine and the local avionics shop and they both told me that Narco has a bad rep for service and gouges you badly to fix a 122 - and they do break. As others have pointed out, you don't need a heck of a lot more to make the plane legal for IFR training/flight. Here's what __I'd__ do if I were you. I'd sell the 300XL (since you got it for a steal, you should at least get your money back) and buy a used NARCO NAV-122A on Ebay. You can get a yellow tagged one for about $1300. This is the ONLY piece of equipment you will need to be able to fly IFR legally - it's a VOR, LOC, GS, MKR and CDI all in one 3 1/8" hole. You can then legally do ILS, LOC, and VOR approaches. I did exactly this in order to make my COZY MKIV IFR capable (for training purposes and light IFR). Even if you have to pay someone $500 to install it, it's still the cheapest way there, using the least panel space. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
It took me long enough to find a plane - my #1 priority was a good,
mid-time engine with full logs. That I got. As for going handheld GPS - doesn't the integration with the COM help a lot? Autoselecting frequencies and such? I already have a GPS 295 - I was planning on selling it. They fetch nearly $1000 used still. Brad Z wrote: If you're installing the 300xl VFR only, why not just go with a handheld? Heck, a $300 handheld would beat the 300xl in screen size and features. The difference could buy a nice handheld com radio to use as a backup, with a external antenna wired in. I'm not trying to poop on a decision already made, but if you knew you were going to be using this as a IFR training plaform, why didn't you search out a bird with the necessary avionics? Just curious ![]() I can't count the number of folks who get their private certificate and go out and buy a 150/152, only to wish they bought just a bit more for instrument training, trips, passengers, etc. "Paul Folbrecht" wrote in message k.net... Ok, here's what I'm thinking now. Critisism of this setup not discouraged! - 300XL installed *VFR only*. - PSE 6000 Audio panel with marker beacons. - KX-155 nav/com - there's one on Ebay right now I may pick up. - KX 209 Indicator. Local shop tells me no more than $3500 or so for this install, including antenna for 2nd com. Does that sound right? I'd be ditching the 385 nav/com that's in there now, of course. Full cost of this setup assuming used KX-155 and 209 and new audio panel should be $9-$10K. While this is definitely more money than I wanted to spend or figured I'd have to spend, I think it may be worth it. I actually ran a price quote on my plane (aeroprice) with this equipment installed and was pleased to see the value go up by 80% or so of what I'd be putting into it. I plan to keep the plane for probably 4-5 years (until I build my RV-9). Again, what I want to do here is have an aircraft in which I can get my instrument ticket and be able to practice real-world instrument approaches. Subsequent to that, I don't see myself flying hard IMC, but being able to do a lot more flying on those marginal VFR days that keep me grounded now. (MVFR can turn into IFR too damn easily - I've already discovered that.) Tell me if I'm all wet (please). Paul Folbrecht wrote: I've just purchased a '79 152 that is currently VFR only. Avionics consist of a single nav/com and xponder. That's it. At some point in the next year or two I am going to want to get my instrument ticket in this aircraft, so I'm already starting to think about the best way to do that. Trouble is I know precious little about IFR equipment at the moment. If someone has some good resources/links that could get me up to speed I'd appreciate it. Actually, I already started buying stuff. I bought an IFR Garmin 300XL GPS on ebay (it was a steal). That's my start. I'm completely open to suggestions on where to go from there. Maybe a B/K 80 nav? Has everything else I need, right? I know I need an audio (switch) panel and at least one more CDI. I'll be searching for an avionics shop soon to install the GPS, but until then any idea what that will cost me? Might it make some sense to have them do a VFR-only install initially and then do it IFR when I have the rest of my equipment? (I want a GPS now, of course, for VFR flight.) TIA. |
My club has a bird with an IFR certified 300XL and a 430. While it does
have the database that contains runways and frequencies, I don't recall the 300XL doing any frequency autoselection. My personal opinion is that if you're not using it as an IFR installation, it's wasting space on the panel that could be used for a useable navcom. I think you'll be sorely disappointed if you trade your color 295 for a tiny green screen 300xl. "Paul Folbrecht" wrote in message k.net... It took me long enough to find a plane - my #1 priority was a good, mid-time engine with full logs. That I got. As for going handheld GPS - doesn't the integration with the COM help a lot? Autoselecting frequencies and such? I already have a GPS 295 - I was planning on selling it. They fetch nearly $1000 used still. Brad Z wrote: If you're installing the 300xl VFR only, why not just go with a handheld? Heck, a $300 handheld would beat the 300xl in screen size and features. The difference could buy a nice handheld com radio to use as a backup, with a external antenna wired in. I'm not trying to poop on a decision already made, but if you knew you were going to be using this as a IFR training plaform, why didn't you search out a bird with the necessary avionics? Just curious ![]() I can't count the number of folks who get their private certificate and go out and buy a 150/152, only to wish they bought just a bit more for instrument training, trips, passengers, etc. "Paul Folbrecht" wrote in message k.net... Ok, here's what I'm thinking now. Critisism of this setup not discouraged! - 300XL installed *VFR only*. - PSE 6000 Audio panel with marker beacons. - KX-155 nav/com - there's one on Ebay right now I may pick up. - KX 209 Indicator. Local shop tells me no more than $3500 or so for this install, including antenna for 2nd com. Does that sound right? I'd be ditching the 385 nav/com that's in there now, of course. Full cost of this setup assuming used KX-155 and 209 and new audio panel should be $9-$10K. While this is definitely more money than I wanted to spend or figured I'd have to spend, I think it may be worth it. I actually ran a price quote on my plane (aeroprice) with this equipment installed and was pleased to see the value go up by 80% or so of what I'd be putting into it. I plan to keep the plane for probably 4-5 years (until I build my RV-9). Again, what I want to do here is have an aircraft in which I can get my instrument ticket and be able to practice real-world instrument approaches. Subsequent to that, I don't see myself flying hard IMC, but being able to do a lot more flying on those marginal VFR days that keep me grounded now. (MVFR can turn into IFR too damn easily - I've already discovered that.) Tell me if I'm all wet (please). Paul Folbrecht wrote: I've just purchased a '79 152 that is currently VFR only. Avionics consist of a single nav/com and xponder. That's it. At some point in the next year or two I am going to want to get my instrument ticket in this aircraft, so I'm already starting to think about the best way to do that. Trouble is I know precious little about IFR equipment at the moment. If someone has some good resources/links that could get me up to speed I'd appreciate it. Actually, I already started buying stuff. I bought an IFR Garmin 300XL GPS on ebay (it was a steal). That's my start. I'm completely open to suggestions on where to go from there. Maybe a B/K 80 nav? Has everything else I need, right? I know I need an audio (switch) panel and at least one more CDI. I'll be searching for an avionics shop soon to install the GPS, but until then any idea what that will cost me? Might it make some sense to have them do a VFR-only install initially and then do it IFR when I have the rest of my equipment? (I want a GPS now, of course, for VFR flight.) TIA. |
Well, I've not yet seen a 300XL up close, but I wouldn't have thought
the quality of the display would pale compared to my 295 (although I knew I'd lose the color - not a big deal to me - I've seen several grey-scale handhelds that I thought were fine). This is more food for thought. Brad Z wrote: My club has a bird with an IFR certified 300XL and a 430. While it does have the database that contains runways and frequencies, I don't recall the 300XL doing any frequency autoselection. My personal opinion is that if you're not using it as an IFR installation, it's wasting space on the panel that could be used for a useable navcom. I think you'll be sorely disappointed if you trade your color 295 for a tiny green screen 300xl. "Paul Folbrecht" wrote in message k.net... It took me long enough to find a plane - my #1 priority was a good, mid-time engine with full logs. That I got. As for going handheld GPS - doesn't the integration with the COM help a lot? Autoselecting frequencies and such? I already have a GPS 295 - I was planning on selling it. They fetch nearly $1000 used still. Brad Z wrote: If you're installing the 300xl VFR only, why not just go with a handheld? Heck, a $300 handheld would beat the 300xl in screen size and features. The difference could buy a nice handheld com radio to use as a backup, with a external antenna wired in. I'm not trying to poop on a decision already made, but if you knew you were going to be using this as a IFR training plaform, why didn't you search out a bird with the necessary avionics? Just curious ![]() I can't count the number of folks who get their private certificate and go out and buy a 150/152, only to wish they bought just a bit more for instrument training, trips, passengers, etc. "Paul Folbrecht" wrote in message link.net... Ok, here's what I'm thinking now. Critisism of this setup not discouraged! - 300XL installed *VFR only*. - PSE 6000 Audio panel with marker beacons. - KX-155 nav/com - there's one on Ebay right now I may pick up. - KX 209 Indicator. Local shop tells me no more than $3500 or so for this install, including antenna for 2nd com. Does that sound right? I'd be ditching the 385 nav/com that's in there now, of course. Full cost of this setup assuming used KX-155 and 209 and new audio panel should be $9-$10K. While this is definitely more money than I wanted to spend or figured I'd have to spend, I think it may be worth it. I actually ran a price quote on my plane (aeroprice) with this equipment installed and was pleased to see the value go up by 80% or so of what I'd be putting into it. I plan to keep the plane for probably 4-5 years (until I build my RV-9). Again, what I want to do here is have an aircraft in which I can get my instrument ticket and be able to practice real-world instrument approaches. Subsequent to that, I don't see myself flying hard IMC, but being able to do a lot more flying on those marginal VFR days that keep me grounded now. (MVFR can turn into IFR too damn easily - I've already discovered that.) Tell me if I'm all wet (please). Paul Folbrecht wrote: I've just purchased a '79 152 that is currently VFR only. Avionics consist of a single nav/com and xponder. That's it. At some point in the next year or two I am going to want to get my instrument ticket in this aircraft, so I'm already starting to think about the best way to do that. Trouble is I know precious little about IFR equipment at the moment. If someone has some good resources/links that could get me up to speed I'd appreciate it. Actually, I already started buying stuff. I bought an IFR Garmin 300XL GPS on ebay (it was a steal). That's my start. I'm completely open to suggestions on where to go from there. Maybe a B/K 80 nav? Has everything else I need, right? I know I need an audio (switch) panel and at least one more CDI. I'll be searching for an avionics shop soon to install the GPS, but until then any idea what that will cost me? Might it make some sense to have them do a VFR-only install initially and then do it IFR when I have the rest of my equipment? (I want a GPS now, of course, for VFR flight.) TIA. |
On Fri, 26 Mar 2004 02:12:50 GMT, Paul Folbrecht
wrote: Ok, here's what I'm thinking now. Critisism of this setup not discouraged! - 300XL installed *VFR only*. - PSE 6000 Audio panel with marker beacons. - KX-155 nav/com - there's one on Ebay right now I may pick up. - KX 209 Indicator. Local shop tells me no more than $3500 or so for this install, including antenna for 2nd com. Does that sound right? I'd be ditching the 385 nav/com that's in there now, of course. Full cost of this setup assuming used KX-155 and 209 and new audio panel should be $9-$10K. While this is definitely more money than I wanted to spend or figured I'd have to spend, I think it may be worth it. I actually ran a price quote on my plane (aeroprice) with this equipment installed and was pleased to see the value go up by 80% or so of what I'd be putting into it. I plan to keep the plane for probably 4-5 years (until I build my RV-9). Paul, I see little value add by installing the 300XL VFR only. Did you get a quote to see how much more an IFR install would be? -Nathan |
Making your own canopy | c hinds | Home Built | 6 | November 22nd 04 09:10 AM |
need advice with composite for making glare shield | bubba | Home Built | 1 | July 7th 04 05:44 AM |
Making my landing gear | Lou Parker | Home Built | 8 | March 31st 04 10:34 PM |
